calling ble_bas_battery_level_update freeze nRF51822
every time i try to call ble_bas_battery_level_update(&m_bas, 1); my application freeze and i can't get any response
Here is what i did:
1- copying ble_app_template_s110 keil project
2- adding static m_bas and ble_bas_on_ble_evt(&m_bas, p_ble_evt); to ble_evt_dispatch()
3- copying bas_init(); from ble_app_hids_keyboard to services_init()
4- Uncomment the calls to app_button_enable() and app_button_disable()
5- I checked on my Master Control Panel battery service was available to me before calling ble_bas_battery_level_update()
6- After that i just called ble_bas_battery_level_update(&m_bas, 1); on one of my interrupt handlers and i just lost my connection to ble device and everything freezed
Can you tell me which part i did wrong?
and here is source code for my main.c file
/* Copyright (c) 2014 Nordic Semiconductor. All Rights Reserved.
 * The information contained herein is property of Nordic Semiconductor ASA.
 * Terms and conditions of usage are described in detail in NORDIC
 * SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
 * Licensees are granted free, non-transferable use of the information. NO
 * WARRANTY of ANY KIND is provided. This heading must NOT be removed from
 * the file.
/** @file
 * @defgroup ble_sdk_app_template_main main.c
 * @ingroup ble_sdk_app_template
 * @brief Template project main file.
 * This file contains a template for creating a new application. It has the code necessary to wakeup
 * from button, advertise, get a connection restart advertising on disconnect and if no new
 * connection created go back to system-off mode.
 * It can easily be used as a starting point for creating a new application, the comments identified
 * with 'YOUR_JOB' indicates where and how you can customize.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "nrf_gpio.h"
#include "nrf51_bitfields.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "app_scheduler.h"
#include "softdevice_handler.h"
#include "app_timer_appsh.h"
#include "bsp.h"
#include "ble_bas.h"
#include "nrf_drv_gpiote.h"
#define IS_SRVC_CHANGED_CHARACT_PRESENT 0                                           /**< Include or not the service_changed characteristic. if not enabled, the server's database cannot be changed for the lifetime of the device*/
#define WAKEUP_BUTTON_ID                0                                           /**< Button used to wake up the application. */
// YOUR_JOB: Define any other buttons to be used by the applications:
// #define MY_BUTTON_ID                   1
#define DEVICE_NAME                     "A"         				                /**< Name of device. Will be included in the advertising data. */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_TIMEOUT_IN_SECONDS      180                                         /**< The advertising timeout (in units of seconds). */
// YOUR_JOB: Modify these according to requirements.
#define APP_TIMER_PRESCALER             0                                           /**< Value of the RTC1 PRESCALER register. */
#define APP_TIMER_MAX_TIMERS            (2 + BSP_APP_TIMERS_NUMBER)                 /**< Maximum number of simultaneously created timers. */
#define APP_TIMER_OP_QUEUE_SIZE         4                                           /**< Size of timer operation queues. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(500, UNIT_1_25_MS)            /**< Minimum acceptable connection interval (0.5 seconds). */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(1000, UNIT_1_25_MS)           /**< Maximum acceptable connection interval (1 second). */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER)  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                  1                                           /**< Perform bonding. */
#define SEC_PARAM_MITM                  0                                           /**< Man In The Middle protection not required. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                        /**< No I/O capabilities. */
#define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                          /**< Maximum encryption key size. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
// YOUR_JOB: Modify these according to requirements (e.g. if other event types are to pass through
//           the scheduler).
#define SCHED_MAX_EVENT_DATA_SIZE       sizeof(app_timer_event_t)                   /**< Maximum size of scheduler events. Note that scheduler BLE stack events do not contain any data, as the events are being pulled from the stack in the event handler. */
#define SCHED_QUEUE_SIZE                10                                          /**< Maximum number of events in the scheduler queue. */
#define LED0							18
#define LED1							19
#define LED2							20
#define LED3							21
#define LED4							22
#define CLS_1							0
#define CLS_2							1
#define RCP								2
static ble_gap_sec_params_t             m_sec_params;                               /**< Security requirements for this application. */
static uint16_t                         m_conn_handle = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
static ble_bas_t                        m_bas;
int counter;
bool cls;
// YOUR_JOB: Initialize UUIDs for service(s) used in your application.
ble_uuid_t m_adv_uuids[] = {{BLE_UUID_BATTERY_SERVICE, BLE_UUID_TYPE_BLE}};         /**< Universally unique service identifiers. */
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in] line_num   Line number of the failing ASSERT call.
 * @param[in] file_name  File name of the failing ASSERT call.
/**@brief Function for handling Service errors.
// YOUR_JOB: Uncomment this function and make it handle error situations sent back to your
//           application by the services it uses.
static void service_error_handler(uint32_t nrf_error)
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module.
static void timers_init(void)
    // Initialize timer module, making it use the scheduler
    APP_TIMER_APPSH_INIT(APP_TIMER_PRESCALER, APP_TIMER_MAX_TIMERS, APP_TIMER_OP_QUEUE_SIZE, true);
    /* YOUR_JOB: Create any timers to be used by the application.
                 Below is an example of how to create a timer.
                 For every new timer needed, increase the value of the macro APP_TIMER_MAX_TIMERS by
                 one.
    err_code = app_timer_create(&m_app_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler);
    APP_ERROR_CHECK(err_code); */
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
    uint32_t                err_code;
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    /* YOUR_JOB: Use an appearance value matching the application's use case.
    err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_);
/**@brief Function for initializing Battery Service.
static void bas_init(void)
    uint32_t       err_code;
    ble_bas_init_t bas_init_obj;
    memset(&bas_init_obj, 0, sizeof(bas_init_obj));
    bas_init_obj.evt_handler          = NULL;
    bas_init_obj.support_notification = true;
    bas_init_obj.p_report_ref         = NULL;
    bas_init_obj.initial_batt_level   = 100;
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&bas_init_obj.battery_level_char_attr_md.cccd_write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&bas_init_obj.battery_level_char_attr_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&bas_init_obj.battery_level_char_attr_md.write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&bas_init_obj.battery_level_report_read_perm);
    err_code = ble_bas_init(&m_bas, &bas_init_obj);
    // YOUR_JOB: Add code to initialize the services used by the application.
	bas_init();
/**@brief Function for initializing security parameters.
static void sec_params_init(void)
    m_sec_params.bond         = SEC_PARAM_BOND;
    m_sec_params.mitm         = SEC_PARAM_MITM;
    m_sec_params.io_caps      = SEC_PARAM_IO_CAPABILITIES;
    m_sec_params.oob          = SEC_PARAM_OOB;
    m_sec_params.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
    m_sec_params.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail config parameter, but instead we use the event
 *                handler mechanism to demonstrate its use.
    uint32_t err_code;
    if(p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED)
/**@brief Function for handling a Connection Parameters error.
/**@brief Function for starting timers.
static void timers_start(void)
    /* YOUR_JOB: Start your timers. below is an example of how to start a timer.
    uint32_t err_code;
    err_code = app_timer_start(m_app_timer_id, TIMER_INTERVAL, NULL);
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
/**@brief Function for handling the Application's BLE Stack events.
static void on_ble_evt(ble_evt_t * p_ble_evt)
    uint32_t                         err_code;
    static ble_gap_evt_auth_status_t m_auth_status;
    bool                             master_id_matches;
    ble_gap_sec_kdist_t *            p_distributed_keys;
    ble_gap_enc_info_t *             p_enc_info;
    ble_gap_irk_t *                  p_id_info;
    ble_gap_sign_info_t *            p_sign_info;
    static ble_gap_enc_key_t         m_enc_key;           /**< Encryption Key (Encryption Info and Master ID). */
    static ble_gap_id_key_t          m_id_key;            /**< Identity Key (IRK and address). */
    static ble_gap_sign_info_t       m_sign_key;          /**< Signing Key (Connection Signature Resolving Key). */
    static ble_gap_sec_keyset_t      m_keys = {.keys_periph = {&m_enc_key, &m_id_key, &m_sign_key}};
        case BLE_GAP_EVT_CONNECTED:
            /* YOUR_JOB: Uncomment this part if you are using the app_button module to handle button
                         events (assuming that the button events are only needed in connected
                         state). If this is uncommented out here,
                            1. Make sure that app_button_disable() is called when handling
                               BLE_GAP_EVT_DISCONNECTED below.
                            2. Make sure the app_button module is initialized.*/
            err_code = app_button_enable();
                         events. This should be done to save power when not connected
                         to a peer.*/
            err_code = app_button_disable();
            err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
                                                   BLE_GAP_SEC_STATUS_SUCCESS,
                                                   &m_sec_params,
                                                   &m_keys);
            err_code = sd_ble_gatts_sys_attr_set(m_conn_handle,
                                                 NULL,
                                                 0,
                                                 BLE_GATTS_SYS_ATTR_FLAG_SYS_SRVCS | BLE_GATTS_SYS_ATTR_FLAG_USR_SRVCS);
        case BLE_GAP_EVT_AUTH_STATUS:
            m_auth_status = p_ble_evt->evt.gap_evt.params.auth_status;
        case BLE_GAP_EVT_SEC_INFO_REQUEST:
            master_id_matches  = memcmp(&p_ble_evt->evt.gap_evt.params.sec_info_request.master_id,
                                        &m_enc_key.master_id,
                                        sizeof(ble_gap_master_id_t)) == 0;
            p_distributed_keys = &m_auth_status.kdist_periph;
            p_enc_info  = (p_distributed_keys->enc  && master_id_matches) ? &m_enc_key.enc_info : NULL;
            p_id_info   = (p_distributed_keys->id   && master_id_matches) ? &m_id_key.id_info   : NULL;
            p_sign_info = (p_distributed_keys->sign && master_id_matches) ? &m_sign_key         : NULL;
            err_code = sd_ble_gap_sec_info_reply(m_conn_handle, p_enc_info, p_id_info, p_sign_info);
            // No implementation needed.
/**@brief Function for dispatching a BLE stack event to all modules with a BLE stack event handler.
 * @details This function is called from the scheduler in the main loop after a BLE stack
 *          event has been received.
 * @param[in] p_ble_evt  Bluetooth stack event.
static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
    on_ble_evt(p_ble_evt);
    ble_conn_params_on_ble_evt(p_ble_evt);
    ble_advertising_on_ble_evt(p_ble_evt);
    YOUR_JOB: Add service ble_evt handlers calls here, like, for example:
/**@brief Function for dispatching a system event to interested modules.
 * @details This function is called from the System event interrupt handler after a system
 * @param[in] sys_evt  System stack event.
static void sys_evt_dispatch(uint32_t sys_evt)
    ble_advertising_on_sys_evt(sys_evt);
    uint32_t err_code;
    // Initialize the SoftDevice handler module.
    SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_20_PPM, NULL);
#if defined(S110) || defined(S130)
    // Enable BLE stack
    ble_enable_params_t ble_enable_params;
    memset(&ble_enable_params, 0, sizeof(ble_enable_params));
#ifdef S130
    ble_enable_params.gatts_enable_params.attr_tab_size   = BLE_GATTS_ATTR_TAB_SIZE_DEFAULT;
    ble_enable_params.gatts_enable_params.service_changed = IS_SRVC_CHANGED_CHARACT_PRESENT;
    err_code = sd_ble_enable(&ble_enable_params);
    // Register with the SoftDevice handler module for BLE events.
    err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
    err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
    uint32_t      err_code;
    ble_advdata_t advdata;
    // Build advertising data struct to pass into @ref ble_advertising_init.
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    advdata.include_appearance      = true;
    advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    advdata.uuids_complete.p_uuids  = m_adv_uuids;
    ble_adv_modes_config_t options = {0};
    options.ble_adv_fast_enabled  = BLE_ADV_FAST_ENABLED;
    options.ble_adv_fast_interval = APP_ADV_INTERVAL;
    options.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
    err_code = ble_advertising_init(&advdata, NULL, &options, on_adv_evt, NULL);
/**@brief Function for the Event Scheduler initialization.
static void scheduler_init(void)
    APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
/**@brief Function for handling a bsp event.
 * @param[in]     evt                        BSP event.
/* YOUR_JOB: Uncomment this function if you need to handle button events.
static void bsp_event_handler(bsp_event_t evt)
        switch (evt)
            case BSP_EVENT_KEY_0:
                // Code to handle BSP_EVENT_KEY_0
            // Handle any other event
                APP_ERROR_HANDLER(evt);
/**@brief Function for the Power manager.
static void power_manage(void)
    uint32_t err_code = sd_app_evt_wait();
/**@brief Function for initializing bsp module.
static void bsp_module_init(void)
    uint32_t err_code;
    // Note: If the only use of buttons is to wake up, bsp_event_handler can be NULL.
    err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS, APP_TIMER_TICKS(100, APP_TIMER_PRESCALER), NULL);
    // Note: If the buttons will be used to do some task, assign bsp_event_handler, as shown below.
    //  err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS, APP_TIMER_TICKS(100, APP_TIMER_PRESCALER), bsp_event_handler);
    //  APP_ERROR_CHECK(err_code);
    // You can (if you configured an event handler) choose to assign events to buttons beyond the default configuration.
    // E.g:
    //  uint32_t err_code = bsp_event_to_button_assign(BUTTON_0_ID, BSP_EVENT_KEY_SLEEP);
void cls_fall_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
	counter = 0;
	cls = 0;
	//nrf_drv_gpiote_out_clear(LED0);
	//nrf_drv_gpiote_out_clear(LED1);
	//nrf_drv_gpiote_out_clear(LED2);
	nrf_drv_gpiote_out_clear(LED3);
void cls_rise_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
	cls = 1;
	if (counter == 242)
		nrf_drv_gpiote_out_set(LED3);
void rcp_fall_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
	counter++;
static void gpiote_init(void)
	nrf_drv_gpiote_init();
    //nrf_drv_gpiote_out_config_t led0_config = GPIOTE_CONFIG_OUT_SIMPLE(false);
	//nrf_drv_gpiote_out_init(LED0, &led0_config);
	//nrf_drv_gpiote_out_config_t led1_config = GPIOTE_CONFIG_OUT_SIMPLE(false);
	//nrf_drv_gpiote_out_init(LED1, &led1_config);
	//nrf_drv_gpiote_out_config_t led2_config = GPIOTE_CONFIG_OUT_SIMPLE(false);
	//nrf_drv_gpiote_out_init(LED2, &led2_config);
	nrf_drv_gpiote_out_config_t led3_config = GPIOTE_CONFIG_OUT_SIMPLE(false);
	nrf_drv_gpiote_out_init(LED3, &led3_config);
    nrf_drv_gpiote_in_config_t cls_1_config = GPIOTE_CONFIG_IN_SENSE_HITOLO(true);
    cls_1_config.pull = NRF_GPIO_PIN_PULLUP;
	nrf_drv_gpiote_in_init(CLS_1, &cls_1_config, cls_fall_handler);
    nrf_drv_gpiote_in_event_enable(CLS_1, true);
    nrf_drv_gpiote_in_config_t cls_2_config = GPIOTE_CONFIG_IN_SENSE_LOTOHI(true);
    cls_2_config.pull = NRF_GPIO_PIN_PULLUP;
	nrf_drv_gpiote_in_init(CLS_2, &cls_2_config, cls_rise_handler);
    nrf_drv_gpiote_in_event_enable(CLS_2, true);
	nrf_drv_gpiote_in_config_t rcp_config = GPIOTE_CONFIG_IN_SENSE_HITOLO(true);
    rcp_config.pull = NRF_GPIO_PIN_PULLUP;
	nrf_drv_gpiote_in_init(RCP, &rcp_config, rcp_fall_handler);
    nrf_drv_gpiote_in_event_enable(RCP, true);
/**@brief Function for application main entry.
    uint32_t err_code;
    // Initialize
    timers_init();
	gpiote_init();
    ble_stack_init();
    bsp_module_init();
    scheduler_init();
    gap_params_init();
    advertising_init();
    services_init();
    conn_params_init();
    sec_params_init();
    // Start execution
    timers_start();
    err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
    // Enter main loop
    for (;;)
        app_sched_execute();
        power_manage();
