Bluetooth disconnects after being connected for 18 hours
I am working with nrf5281 and its bluetooth connection, the connection is established well and the chip and the nrf connect application stay connected, however the connection is lost after about 18 hours or so, what I want to achieve is to keep the connection for several days or weeks.
I have not been able to debug for the same reason that the disconnection occurs too long after the connection is established.
I leave here the parameters that I am using for the connection, I would like to know if to achieve the connection for several days can be accomplished only by changing some of these parameters.
#define APP_ADV_INTERVAL                625
#define BATTERY_LEVEL_MEAS_INTERVAL     APP_TIMER_TICKS(5000)
#define APP_ADV_DURATION                8000
#define APP_BLE_OBSERVER_PRIO           3
#define APP_BLE_CONN_CFG_TAG            1
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)
#define SLAVE_LATENCY                   0
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(6000, UNIT_10_MS)
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)
#define MAX_CONN_PARAMS_UPDATE_COUNT    5
#define SEC_PARAM_BOND                  1
#define SEC_PARAM_MITM                  0
#define SEC_PARAM_LESC                  0
#define SEC_PARAM_KEYPRESS              0
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE
#define SEC_PARAM_OOB                   0
#define SEC_PARAM_MIN_KEY_SIZE          7
#define SEC_PARAM_MAX_KEY_SIZE          16
    bool erase_bonds;
            sleep_mode_enter();
        case BLE_GAP_EVT_CONNECTED:
            bsp_indication_set(BSP_INDICATE_CONNECTED);
            nrf_ble_qwr_conn_handle_assign(&m_qwr, m_conn_handle);
