receiving BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION when trying to connect to bonded HRS POLAR watch
I am using the softdevice S132 with my nRF52832 and am running into a problem with a heart rate band by POLAR.
The Problem is that I get a disconnect from the HRS side (BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION).
It occurs when I first bond with the HRS, then turn the HRS off and on again. My device will send a connect request since it has the HRS saved as a peer and it is advertising again.
But then after the connect request and the first read request of characteristics, the HRS send BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION. This can be seen in the wireshark log file attached. message 1115 is the reconnect and message 1125 is the deconnection triggers by the HRS band.
Notes:
- other HRS like a HRS belt work fine
- when using the HRS band with nRF connect and trying to bond, a PIN is required. when I bond I do it with Just Works
- its not due to connection parameters (I set exactly the requested ones)
- strangely the HRS band will show that it's connected by my device is not connected. the HRS deletes my device as a peer after this second connection but before had it as peer
- I also tried with LESC but its not working
Thank you for any help.
wireshark in google drive: https://drive.google.com/file/d/1vEPYtHKzu5OBJZjGI4GQ6MgVzPxHwEtg/view?usp=sharing
  • I could somehow solve the problem with a workaround.
    What I did previously was to initiate bonding as soon as I connected even with already bonded devices. The bonding caused an error on my side.
    Now upon successful connection when in "whitelist scanning mode" and I don't want to connect to a new device, I do not bond anymore and just start the service discovery instead.
    - My device has the watch saved as a peer and finds it in the whitelist and then connects to it when the HRS advertises
    - The HRS does NOT have my device as a peer. But since I do no longer start a new bonding this is no problem
    - The HRS still sends a disconnect but somehow this doesn't matter
