In porting over my project from Keil to GCC using SDK 8.1.0 I can build and run just fine when I build with Keil but when I build with GCC and try to run sd_softdevice_enable hangs. I have been combing over the linker scripts and everything looking for clues but I cannot figure out what the issue is.
- Yes, I do have stack 8.0.0 flashed to the chip.
- I am using a linker file that has the same ram/flash addresses as the Keil project
Another oddity is that the device advertises ok but when I connect it crashes. When using Keil it works perfectly.
If there is anything I can post here to clarify the situation, please let me know.
Thanks!
Answer:
I defined SPI_MASTER_0 instead of SPI_MASTER_0_ENABLE in my makefile which is why Keil and GCC exhibited different behavior. Pretty embarrassing. Don't do this.
