I'm openning a new case (following the proposal of Einar Thorsrud).
I want to do a BLE NUS project with custom service 128bits and with custom characteristics also differents fro the service.
You can found my project with this link: drive.google.com/.../view
I use the TEST\examples\ble_central\ble_app_uart_c\pca10040\s132\ses\ble_app_uart_c_pca10040_s132 for the central board (NRF52-DK)
and TEST\examples\ble_peripheral\ble_app_uart\pca10056\s140\ses\ble_app_uart_pca10056_s140 for the peripheral board (NRF52840-DK )
My problem is during the scan process or during the activation of notification.
In the function uint32_t ble_nus_c_init(ble_nus_c_t * p_ble_nus_c, ble_nus_c_init_t * p_ble_nus_c_init) I have tried with differents solutions (adding or not the "sd_ble_uuid_vs_add() function) but result are not relevant.
My bloc code:
//AJOUT
ble_uuid128_t tx_base_uuid = {BLE_UUID_COMMANDE_TX_UUID};
VERIFY_PARAM_NOT_NULL(p_ble_nus_c);
VERIFY_PARAM_NOT_NULL(p_ble_nus_c_init);
err_code = sd_ble_uuid_vs_add(&tx_base_uuid, &p_ble_nus_c->uuid_type);
VERIFY_SUCCESS(err_code);
ble_uuid128_t rx_base_uuid = {BLE_UUID_COMMANDE_RX_UUID};
err_code = sd_ble_uuid_vs_add(&rx_base_uuid, &p_ble_nus_c->uuid_type);
// FIN AJOUT
1) If I comment the bloc code (function is similar to the example project function)
Log:
<info> app_timer: RTC: initialized. <debug> ble_scan: Added filter on UUID 4778 <info> app: BLE UART central example started. <debug> ble_scan: Scanning <debug> ble_scan: Connecting <debug> ble_scan: Connection status: 0 <debug> nrf_ble_gatt: Requesting to update ATT MTU to 247 bytes on connection 0x0. <debug> nrf_ble_gatt: Updating data length to 251 on connection 0x0. <info> app: Connecting to target 542667A20DCA <debug> nrf_ble_gq: Registering connection handle: 0x0000 <debug> ble_db_disc: Starting discovery of service with UUID 0x4778 on connection handle 0x0. <debug> nrf_ble_gq: Adding item to the request queue <debug> nrf_ble_gq: GATTC Primary Services Discovery Request <debug> nrf_ble_gq: SD is currently busy. The GATT request procedure will be attempted again later. <debug> nrf_ble_gq: Processing the request queue... <debug> nrf_ble_gatt: ATT MTU updated to 247 bytes on connection 0x0 (response). <info> app: ATT MTU exchange completed. <info> app: Ble NUS max data length set to 0xF4(244) <debug> nrf_ble_gq: Processing the request queue... <debug> nrf_ble_gq: GATTC Primary Service Discovery Request <debug> nrf_ble_gq: SD GATT procedure (2) succeeded on connection handle: 0. <debug> nrf_ble_gatt: Data length updated to 251 on connection 0x0. <debug> nrf_ble_gatt: max_rx_octets: 251 <debug> nrf_ble_gatt: max_tx_octets: 251 <debug> nrf_ble_gatt: max_rx_time: 2120 <debug> nrf_ble_gatt: max_tx_time: 2120 <debug> ble_db_disc: Found service UUID 0x4778. <debug> nrf_ble_gq: Adding item to the request queue <debug> nrf_ble_gq: GATTC Characteristic Discovery Request <debug> nrf_ble_gq: SD GATT procedure (3) succeeded on connection handle: 0. <debug> nrf_ble_gq: Processing the request queue... <debug> nrf_ble_gq: Adding item to the request queue <debug> nrf_ble_gq: GATTC Characteristic Discovery Request <debug> nrf_ble_gq: SD GATT procedure (3) succeeded on connection handle: 0. <debug> nrf_ble_gq: Processing the request queue... <debug> nrf_ble_gq: Adding item to the request queue <debug> nrf_ble_gq: GATTC Characteristic Descriptor Request <debug> nrf_ble_gq: SD GATT procedure (4) succeeded on connection handle: 0. <debug> nrf_ble_gq: Processing the request queue... <debug> nrf_ble_gq: Adding item to the request queue <debug> nrf_ble_gq: GATTC Characteristic Descriptor Request <debug> nrf_ble_gq: SD GATT procedure (4) succeeded on connection handle: 0. <debug> nrf_ble_gq: Processing the request queue... <debug> ble_db_disc: Discovery of service with UUID 0x4778 completed with success on connection handle 0x0. <info> app: Discovery complete. <error> app: ERROR 8 [NRF_ERROR_INVALID_STATE] at C:\Users\julien.HORIZONTELECOM\Downloads\TEST\examples\ble_central\ble_app_uart_c\main.c:336 PC at: 0x0002F797 <error> app: End of error report
The problem is "err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);"(main.c line 335). I can't enable notification. When I debbug, I see uuid = 0. And I don't know why...
2) When I add my bloc code just before the line "return ble_db_discovery_evt_register(&uart_uuid);" in the "uint32_t ble_nus_c_init(ble_nus_c_t * p_ble_nus_c, ble_nus_c_init_t * p_ble_nus_c_init)" function:
Log:
<info> app_timer: RTC: initialized. <debug> ble_scan: Added filter on UUID 4778 <info> app: BLE UART central example started. <debug> ble_scan: Scanning <debug> ble_scan: Connecting <debug> ble_scan: Connection status: 0 <debug> nrf_ble_gatt: Requesting to update ATT MTU to 247 bytes on connection 0x0. <debug> nrf_ble_gatt: Updating data length to 251 on connection 0x0. <info> app: Connecting to target 542667A20DCA <debug> nrf_ble_gq: Registering connection handle: 0x0000 <debug> ble_db_disc: Starting discovery of service with UUID 0x4778 on connection handle 0x0. <debug> nrf_ble_gq: Adding item to the request queue <debug> nrf_ble_gq: GATTC Primary Services Discovery Request U of 247 bytes. <debug> nrf_ble_gatt: Updating ATT MTU to 247 bytes (desired: 247) on connection 0x0. <debug> nrf_ble_gq: Processing the request queue... <debug> nrf_ble_gq: GATTC Primary Service Discovery Request <debug> nrf_ble_gq: SD is currently busy. The GATT request procedure will be attempted again later. <debug> nrf_ble_gatt: ATT MTU updated to 247 bytes on connection 0x0 (response). <info> app: ATT MTU exchange completed. <info> app: Ble NUS max data length set to 0xF4(244) <debug> nrf_ble_gq: Processing the request queue... <debug> nrf_ble_gq: GATTC Primary Service Discovery Request <debug> nrf_ble_gq: SD GATT procedure (2) succeeded on connection handle: 0. <debug> nrf_ble_gatt: Data length updated to 251 on connection 0x0. <debug> nrf_ble_gatt: max_rx_octets: 251 <debug> nrf_ble_gatt: max_tx_octets: 251 <debug> nrf_ble_gatt: max_rx_time: 2120 <debug> nrf_ble_gatt: max_tx_time: 2120 <debug> ble_db_disc: Found service UUID 0x4778. <debug> nrf_ble_gq: Adding item to the request queue <debug> nrf_ble_gq: GATTC Characteristic Discovery Request <debug> nrf_ble_gq: SD GATT procedure (3) succeeded on connection handle: 0. <debug> nrf_ble_gq: Processing the request queue... <debug> nrf_ble_gq: Adding item to the request queue <debug> nrf_ble_gq: GATTC Characteristic Discovery Request <debug> nrf_ble_gq: SD GATT procedure (3) succeeded on connection handle: 0. <debug> nrf_ble_gq: Processing the request queue... <debug> nrf_ble_gq: Adding item to the request queue <debug> nrf_ble_gq: GATTC Characteristic Descriptor Request <debug> nrf_ble_gq: SD GATT procedure (4) succeeded on connection handle: 0. <debug> nrf_ble_gq: Processing the request queue... <debug> nrf_ble_gq: Adding item to the request queue <debug> nrf_ble_gq: GATTC Characteristic Descriptor Request <debug> nrf_ble_gq: SD GATT procedure (4) succeeded on connection handle: 0. <debug> nrf_ble_gq: Processing the request queue... <debug> ble_db_disc: Discovery of service with UUID 0x4778 completed with success on connection handle 0x0. <debug> nrf_ble_gq: Processing the request queue...
Discovery seems to be ok but no event "BLE_NUS_C_EVT_DISCOVERY_COMPLETE"
3) f i move the bloc code before "uart_uuid.type = p_ble_nus_c->uuid_type;"
Log:
<info> app_timer: RTC: initialized. <debug> ble_scan: Added filter on UUID 4778 <info> app: BLE UART central example started. <debug> ble_scan: Scanning <debug> ble_scan: Connecting <debug> ble_scan: Connection status: 0 <debug> nrf_ble_gatt: Requesting to update ATT MTU to 247 bytes on connection 0x0. <debug> nrf_ble_gatt: Updating data length to 251 on connection 0x0. <info> app: Connecting to target 542667A20DCA <debug> nrf_ble_gq: Registering connection handle: 0x0000 <debug> ble_db_disc: Starting discovery of service with UUID 0x4778 on connection handle 0x0. <debug> nrf_ble_gq: Adding item to the request queue <debug> nrf_ble_gq: GATTC Primary Services Discovery Request dure will be attempted again later. <debug> nrf_ble_gq: Processing the request queue... <debug> nrf_ble_gq: GATTC Primary Service Discovery Request <debug> nrf_ble_gq: SD is currently busy. The GATT request proce<debug> nrf_ble_gatt: ATT MTU updated to 247 bytes on connection 0x0 (response). <info> app: ATT MTU exchange completed. <info> app: Ble NUS max data length set to 0xF4(244) <debug> nrf_ble_gq: Processing the request queue... <debug> nrf_ble_gq: GATTC Primary Service Discovery Request <debug> nrf_ble_gq: SD GATT procedure (2) succeeded on connection handle: 0. <debug> nrf_ble_gatt: Data length updated to 251 on connection 0x0. <debug> nrf_ble_gatt: max_rx_octets: 251 <debug> nrf_ble_gatt: max_tx_octets: 251 <debug> nrf_ble_gatt: max_rx_time: 2120 <debug> nrf_ble_gatt: max_tx_time: 2120 <debug> ble_db_disc: Service UUID 0x4778 not found. <debug> nrf_ble_gq: Processing the request queue...
Discovery failed...
I don't know if sd_ble_uuid_vs_add() function is a good solution. Like Einar says, I store the ID in the same variable (&p_ble_nus_c->uuid_type). Do you have a way to do correctly do the storage and solve my problem?
I have found a solution but it's a cheating way... I comment my bloc code in ble_nus_c_init(..) function and I add some line in ble_nus_c_on_db_disc_evt() function :
void ble_nus_c_on_db_disc_evt(ble_nus_c_t * p_ble_nus_c, ble_db_discovery_evt_t * p_evt)
ble_nus_c_evt_t nus_c_evt;
memset(&nus_c_evt,0,sizeof(ble_nus_c_evt_t));
ble_gatt_db_char_t * p_chars = p_evt->params.discovered_db.charateristics;
// Check if the NUS was discovered.
if ( (p_evt->evt_type == BLE_DB_DISCOVERY_COMPLETE)
&& (p_evt->params.discovered_db.srv_uuid.uuid == BLE_UUID_COMMANDE_SERVICE) //BLE_UUID_NUS_SERVICE)
&& (p_evt->params.discovered_db.srv_uuid.type == p_ble_nus_c->uuid_type))
NRF_LOG_INFO("nbr: %x", p_evt->params.discovered_db.char_count);
for (uint32_t i = 0; i < p_evt->params.discovered_db.char_count; i++)
//START
if( p_evt->params.discovered_db.charateristics[i].characteristic.handle_value == 0x0010)
p_evt->params.discovered_db.charateristics[i].characteristic.uuid.uuid = BLE_UUID_COMMANDE_RX_CHARACTERISTIC;
p_chars[i].characteristic.uuid.uuid =p_evt->params.discovered_db.charateristics[i].characteristic.uuid.uuid;
}else if( p_evt->params.discovered_db.charateristics[i].characteristic.handle_value == 0x000D)
p_evt->params.discovered_db.charateristics[i].characteristic.uuid.uuid = BLE_UUID_COMMANDE_TX_CHARACTERISTIC;
//END
NRF_LOG_INFO("uuid: %x", p_chars[i].characteristic.uuid.uuid);
NRF_LOG_INFO("ccd: %x", p_chars[i].cccd_handle);
NRF_LOG_INFO("handle_value: %x", p_chars[i].characteristic.handle_value);
switch (p_chars[i].characteristic.uuid.uuid)
case BLE_UUID_COMMANDE_RX_CHARACTERISTIC: //BLE_UUID_NUS_RX_CHARACTERISTIC:
nus_c_evt.handles.nus_rx_handle = p_chars[i].characteristic.handle_value;
case BLE_UUID_COMMANDE_TX_CHARACTERISTIC: //BLE_UUID_NUS_TX_CHARACTERISTIC:
nus_c_evt.handles.nus_tx_handle = p_chars[i].characteristic.handle_value;
nus_c_evt.handles.nus_tx_cccd_handle = p_chars[i].cccd_handle;
case BLE_UUID_INFO_MOTEUR_RX_CHARACTERISTIC:
// nus_c_evt.handles.nus_rx_mot_handle = p_chars[i].characteristic.handle_value;
NRF_LOG_INFO("Nordic UART Service discovered at peer.\r\n");
if (p_ble_nus_c->evt_handler != NULL)
nus_c_evt.conn_handle = p_evt->conn_handle;
nus_c_evt.evt_type = BLE_NUS_C_EVT_DISCOVERY_COMPLETE;
p_ble_nus_c->evt_handler(p_ble_nus_c, &nus_c_evt);
So uuid is not null and I can enable notification and doing uart over BLE. But, I think is not a proper solution.
Thanks.
