IDE: Segger Embedded Studio
SDK: nRF5 SDK for Thread
Example: MQTTSN client publisher
Board: nRF52840 DK
I am currently using MQTT-SN demo example given in nRF5 SDK for Thread and would like to know how can i publish a payload of say 1024 bytes. Currently i have tried and tested publishing 247 bytes of data in a single shot and everything works fine till that point.
But suppose i try to send a payload of size 250 ("HelloWorld" 25 times), it throws me error of publish message couldn't be send: 0x04 which indeed is a NRF No Memory error. Here is my findings while debugging the issue.
In mqttsn_packet_sender.c file in function name mqttsn_packet_sender_publish, the first call to nrf_malloc(packet_len); do allocate a pointer to buffer and isn't a NULL pointer as it doesn't throw me "NO_MEM_ERROR" at that point of time.
Now in the call to function MQTTSNSerialize_publish in the same above function (mqttsn_packet_sender_publish), the below block of code direct throws me to exit stage.
Code:
if ((len = MQTTSNPacket_len(MQTTSNSerialize_publishLength(payloadlen, topic, qos))) > buflen)
rc = MQTTSNPACKET_BUFFER_TOO_SHORT;
goto exit;
Now thing is if you pass a buffer size of pass a payload of 250, the bufflen in above function becomes 257(payload length + MQTTSN_PACKET_PUBLISH_LENGTH). Now the MQTTSNSerialize_publishLength function will return 256 (250+6) which is passed into MQTTSNPacket_len(256) which will increment it by 3, so resulting value will be 259 which indeed is greater than my buffer_length of 257 which gives me error of MQTTSNPACKET_BUFFER_TOO_SHORT.
So i would like to know how can i solve this issue. I have allocated HEAP Size in Runtime memory section of Common App configuration. I have also increased the memory blocks in sdk_config.h file. Still unable to resolve the issue.
I have attached below necessary files to generate the same error:
My main.c file:
* Copyright (c) 2017 - 2020, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup thread_mqttsn_publisher_example_main main.c
* @ingroup thread_mqttsn_publisher_example
* @brief Thread MQTT-SN Client Publisher Example Application main file.
* @details This example demonstrates an MQTT-SN client publisher application that enables to toggle
* BSP_LED_2 on a board with related MQTT-SN client subscriber application via MQTT-SN messages.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "app_scheduler.h"
#include "app_timer.h"
#include "bsp_thread.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "mqttsn_client.h"
#include "thread_utils.h"
#include <openthread/thread.h>
#define SEARCH_GATEWAY_TIMEOUT 5 /**< MQTT-SN Gateway discovery procedure timeout in [s]. */
#define SCHED_QUEUE_SIZE 32 /**< Maximum number of events in the scheduler queue. */
#define SCHED_EVENT_DATA_SIZE APP_TIMER_SCHED_EVENT_DATA_SIZE /**< Maximum app_scheduler event size. */
static mqttsn_client_t m_client; /**< An MQTT-SN client instance. */
static mqttsn_remote_t m_gateway_addr; /**< A gateway address. */
static uint8_t m_gateway_id; /**< A gateway ID. */
static mqttsn_connect_opt_t m_connect_opt; /**< Connect options for the MQTT-SN client. */
static uint8_t m_led_state = 0; /**< Previously sent BSP_LED_2 command. */
static uint16_t m_msg_id = 0; /**< Message ID thrown with MQTTSN_EVENT_TIMEOUT. */
static char m_client_id[] = "nRF52840_publisher"; /**< The MQTT-SN Client's ID. */
static char m_topic_name[] = "nRF52840_resources/led3"; /**< Name of the topic corresponding to subscriber's BSP_LED_2. */
static mqttsn_topic_t m_topic = /**< Topic corresponding to subscriber's BSP_LED_2. */
.p_topic_name = (unsigned char *)m_topic_name,
.topic_id = 0,
* @section MQTT-SN
/**@brief Turns the MQTT-SN network indication LED on.
* @details This LED is on when an MQTT-SN client is in connected or awake state.
static void light_on(void)
LEDS_ON(BSP_LED_3_MASK);
/**@brief Turns the MQTT-SN network indication LED off.
* @details This LED is on when an MQTT-SN client is in disconnected or asleep state.
static void light_off(void)
LEDS_OFF(BSP_LED_3_MASK);
/**@brief Initializes MQTT-SN client's connection options.
static void connect_opt_init(void)
m_connect_opt.alive_duration = MQTTSN_DEFAULT_ALIVE_DURATION,
m_connect_opt.clean_session = MQTTSN_DEFAULT_CLEAN_SESSION_FLAG,
m_connect_opt.will_flag = MQTTSN_DEFAULT_WILL_FLAG,
m_connect_opt.client_id_len = strlen(m_client_id),
memcpy(m_connect_opt.p_client_id, (unsigned char *)m_client_id, m_connect_opt.client_id_len);
/**@brief Processes GWINFO message from a gateway.
* @details This function updates MQTT-SN Gateway information.
* @param[in] p_event Pointer to MQTT-SN event.
static void gateway_info_callback(mqttsn_event_t * p_event)
m_gateway_addr = *(p_event->event_data.connected.p_gateway_addr);
m_gateway_id = p_event->event_data.connected.gateway_id;
/**@brief Processes CONNACK message from a gateway.
* @details This function launches the topic registration procedure if necessary.
static void connected_callback(void)
light_on();
uint32_t err_code = mqttsn_client_topic_register(&m_client,
m_topic.p_topic_name,
strlen(m_topic_name),
&m_msg_id);
if (err_code != NRF_SUCCESS)
NRF_LOG_ERROR("REGISTER message could not be sent. Error code: 0x%x\r\n", err_code);
/**@brief Processes DISCONNECT message from a gateway. */
static void disconnected_callback(void)
light_off();
/**@brief Processes REGACK message from a gateway.
static void regack_callback(mqttsn_event_t * p_event)
m_topic.topic_id = p_event->event_data.registered.packet.topic.topic_id;
NRF_LOG_INFO("MQTT-SN event: Topic has been registered with ID: %d.\r\n",
p_event->event_data.registered.packet.topic.topic_id);
/**@brief Processes retransmission limit reached event. */
static void timeout_callback(mqttsn_event_t * p_event)
NRF_LOG_INFO("MQTT-SN event: Timed-out message: %d. Message ID: %d.\r\n",
p_event->event_data.error.msg_type,
p_event->event_data.error.msg_id);
/**@brief Processes results of gateway discovery procedure. */
static void searchgw_timeout_callback(mqttsn_event_t * p_event)
NRF_LOG_INFO("MQTT-SN event: Gateway discovery result: 0x%x.\r\n", p_event->event_data.discovery);
/**@brief Function for handling MQTT-SN events. */
void mqttsn_evt_handler(mqttsn_client_t * p_client, mqttsn_event_t * p_event)
switch(p_event->event_id)
case MQTTSN_EVENT_GATEWAY_FOUND:
NRF_LOG_INFO("MQTT-SN event: Client has found an active gateway.\r\n");
gateway_info_callback(p_event);
case MQTTSN_EVENT_CONNECTED:
NRF_LOG_INFO("MQTT-SN event: Client connected.\r\n");
connected_callback();
case MQTTSN_EVENT_DISCONNECT_PERMIT:
NRF_LOG_INFO("MQTT-SN event: Client disconnected.\r\n");
disconnected_callback();
case MQTTSN_EVENT_REGISTERED:
NRF_LOG_INFO("MQTT-SN event: Client registered topic.\r\n");
regack_callback(p_event);
case MQTTSN_EVENT_PUBLISHED:
NRF_LOG_INFO("MQTT-SN event: Client has successfully published content.\r\n");
case MQTTSN_EVENT_TIMEOUT:
NRF_LOG_INFO("MQTT-SN event: Retransmission retries limit has been reached.\r\n");
timeout_callback(p_event);
case MQTTSN_EVENT_SEARCHGW_TIMEOUT:
NRF_LOG_INFO("MQTT-SN event: Gateway discovery procedure has finished.\r\n");
searchgw_timeout_callback(p_event);
* @section State
static void state_changed_callback(uint32_t flags, void * p_context)
NRF_LOG_INFO("State changed! Flags: 0x%08x Current role: %d\r\n",
flags, otThreadGetDeviceRole(p_context));
* @section Buttons
static void led_state_pub(uint8_t led_state)
uint32_t err_code = mqttsn_client_publish(&m_client, m_topic.topic_id, &led_state, 1, &m_msg_id);
NRF_LOG_ERROR("PUBLISH message could not be sent. Error code: 0x%x\r\n", err_code)
static void publish(void)
//m_led_state = m_led_state == 1 ? 0 : 1;
//led_state_pub(m_led_state);
char buff[250] = "HelloWorldHelloWorldHelloWorldHelloWorldHelloWorldHelloWorldHelloWorldHelloWorldHelloWorldHelloWorldHelloWorldHelloWorldHelloWorldHelloWorldHelloWorldHelloWorldHelloWorldHelloWorldHelloWorldHelloWorldHelloWorldHelloWorldHelloWorldHelloWorldHelloWorld";
(uint8_t*)buff, 250, &m_msg_id);
printf("PUBLISH message could not be sent. Error code: 0x%x\r\n", err_code);
else{
//printf("%s\r\n",buff);
static void bsp_event_handler(bsp_event_t event)
if (otThreadGetDeviceRole(thread_ot_instance_get()) < OT_DEVICE_ROLE_CHILD )
(void)event;
return;
switch (event)
case BSP_EVENT_KEY_1:
uint32_t err_code = mqttsn_client_search_gateway(&m_client, SEARCH_GATEWAY_TIMEOUT);
NRF_LOG_ERROR("SEARCH GATEWAY message could not be sent. Error: 0x%x\r\n", err_code);
case BSP_EVENT_KEY_2:
uint32_t err_code;
if (mqttsn_client_state_get(&m_client) == MQTTSN_CLIENT_CONNECTED)
err_code = mqttsn_client_disconnect(&m_client);
NRF_LOG_ERROR("DISCONNECT message could not be sent. Error: 0x%x\r\n", err_code);
err_code = mqttsn_client_connect(&m_client, &m_gateway_addr, m_gateway_id, &m_connect_opt);
NRF_LOG_ERROR("CONNECT message could not be sent. Error: 0x%x\r\n", err_code);
case BSP_EVENT_KEY_3:
publish();
* @section Initialization
/**@brief Function for initializing the Application Timer Module.
static void timer_init(void)
uint32_t err_code = app_timer_init();
/**@brief Function for initializing the LEDs.
static void leds_init(void)
LEDS_CONFIGURE(LEDS_MASK);
LEDS_OFF(LEDS_MASK);
static void log_init(void)
/**@brief Function for initializing the Thread Board Support Package.
static void thread_bsp_init(void)
uint32_t err_code;
err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
err_code = bsp_thread_init(thread_ot_instance_get());
/**@brief Function for initializing the Thread Stack.
static void thread_instance_init(void)
thread_configuration_t thread_configuration =
.radio_mode = THREAD_RADIO_MODE_RX_ON_WHEN_IDLE,
.autocommissioning = true,
thread_init(&thread_configuration);
thread_cli_init();
thread_state_changed_callback_set(state_changed_callback);
/**@brief Function for initializing the MQTTSN client.
static void mqttsn_init(void)
uint32_t err_code = mqttsn_client_init(&m_client,
MQTTSN_DEFAULT_CLIENT_PORT,
mqttsn_evt_handler,
connect_opt_init();
/**@brief Function for initializing scheduler module.
static void scheduler_init(void)
APP_SCHED_INIT(SCHED_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
* @section Main
int main(int argc, char *argv[])
log_init();
scheduler_init();
timer_init();
leds_init();
thread_instance_init();
thread_bsp_init();
mqttsn_init();
while (true)
thread_process();
app_sched_execute();
thread_sleep();
Here is memory manager config in sdk_config.h file.
// </h> //========================================================== // </e> // <e> MEM_MANAGER_ENABLED - mem_manager - Dynamic memory allocator //========================================================== #ifndef MEM_MANAGER_ENABLED #define MEM_MANAGER_ENABLED 1 #endif // <o> MEMORY_MANAGER_SMALL_BLOCK_COUNT - Size of each memory blocks identified as 'small' block. <0-255> #ifndef MEMORY_MANAGER_SMALL_BLOCK_COUNT #define MEMORY_MANAGER_SMALL_BLOCK_COUNT 16 #endif // <o> MEMORY_MANAGER_SMALL_BLOCK_SIZE - Size of each memory blocks identified as 'small' block. // <i> Size of each memory blocks identified as 'small' block. Memory block are recommended to be word-sized. #ifndef MEMORY_MANAGER_SMALL_BLOCK_SIZE #define MEMORY_MANAGER_SMALL_BLOCK_SIZE 128 #endif // <o> MEMORY_MANAGER_MEDIUM_BLOCK_COUNT - Size of each memory blocks identified as 'medium' block. <0-255> #ifndef MEMORY_MANAGER_MEDIUM_BLOCK_COUNT #define MEMORY_MANAGER_MEDIUM_BLOCK_COUNT 8 #endif // <o> MEMORY_MANAGER_MEDIUM_BLOCK_SIZE - Size of each memory blocks identified as 'medium' block. // <i> Size of each memory blocks identified as 'medium' block. Memory block are recommended to be word-sized. #ifndef MEMORY_MANAGER_MEDIUM_BLOCK_SIZE #define MEMORY_MANAGER_MEDIUM_BLOCK_SIZE 256 #endif // <o> MEMORY_MANAGER_LARGE_BLOCK_COUNT - Size of each memory blocks identified as 'large' block. <0-255> #ifndef MEMORY_MANAGER_LARGE_BLOCK_COUNT #define MEMORY_MANAGER_LARGE_BLOCK_COUNT 16 #endif // <o> MEMORY_MANAGER_LARGE_BLOCK_SIZE - Size of each memory blocks identified as 'large' block. // <i> Size of each memory blocks identified as 'large' block. Memory block are recommended to be word-sized. #ifndef MEMORY_MANAGER_LARGE_BLOCK_SIZE #define MEMORY_MANAGER_LARGE_BLOCK_SIZE 512 #endif // <o> MEMORY_MANAGER_XLARGE_BLOCK_COUNT - Size of each memory blocks identified as 'extra large' block. <0-255> #ifndef MEMORY_MANAGER_XLARGE_BLOCK_COUNT #define MEMORY_MANAGER_XLARGE_BLOCK_COUNT 5 #endif // <o> MEMORY_MANAGER_XLARGE_BLOCK_SIZE - Size of each memory blocks identified as 'extra large' block. // <i> Size of each memory blocks identified as 'extra large' block. Memory block are recommended to be word-sized. #ifndef MEMORY_MANAGER_XLARGE_BLOCK_SIZE #define MEMORY_MANAGER_XLARGE_BLOCK_SIZE 2816 #endif // <o> MEMORY_MANAGER_XXLARGE_BLOCK_COUNT - Size of each memory blocks identified as 'extra extra large' block. <0-255> #ifndef MEMORY_MANAGER_XXLARGE_BLOCK_COUNT #define MEMORY_MANAGER_XXLARGE_BLOCK_COUNT 0 #endif // <o> MEMORY_MANAGER_XXLARGE_BLOCK_SIZE - Size of each memory blocks identified as 'extra extra large' block. // <i> Size of each memory blocks identified as 'extra extra large' block. Memory block are recommended to be word-sized. #ifndef MEMORY_MANAGER_XXLARGE_BLOCK_SIZE #define MEMORY_MANAGER_XXLARGE_BLOCK_SIZE 3444 #endif // <o> MEMORY_MANAGER_XSMALL_BLOCK_COUNT - Size of each memory blocks identified as 'extra small' block. <0-255> #ifndef MEMORY_MANAGER_XSMALL_BLOCK_COUNT #define MEMORY_MANAGER_XSMALL_BLOCK_COUNT 16 #endif // <o> MEMORY_MANAGER_XSMALL_BLOCK_SIZE - Size of each memory blocks identified as 'extra small' block. // <i> Size of each memory blocks identified as 'extra large' block. Memory block are recommended to be word-sized. #ifndef MEMORY_MANAGER_XSMALL_BLOCK_SIZE #define MEMORY_MANAGER_XSMALL_BLOCK_SIZE 64 #endif // <o> MEMORY_MANAGER_XXSMALL_BLOCK_COUNT - Size of each memory blocks identified as 'extra extra small' block. <0-255> #ifndef MEMORY_MANAGER_XXSMALL_BLOCK_COUNT #define MEMORY_MANAGER_XXSMALL_BLOCK_COUNT 16 #endif // <o> MEMORY_MANAGER_XXSMALL_BLOCK_SIZE - Size of each memory blocks identified as 'extra extra small' block. // <i> Size of each memory blocks identified as 'extra extra small' block. Memory block are recommended to be word-sized. #ifndef MEMORY_MANAGER_XXSMALL_BLOCK_SIZE #define MEMORY_MANAGER_XXSMALL_BLOCK_SIZE 32 #endif
Below is the code mentioned in MQTTSNSerialize_Publish function:
int MQTTSNSerialize_publish(unsigned char* buf, int buflen, unsigned char dup, int qos, unsigned char retained, unsigned short packetid,
MQTTSN_topicid topic, unsigned char* payload, int payloadlen)
unsigned char *ptr = buf;
MQTTSNFlags flags;
int len = 0;
int rc = 0;
FUNC_ENTRY;
goto exit;
ptr += MQTTSNPacket_encode(ptr, len); /* write length */
writeChar(&ptr, MQTTSN_PUBLISH); /* write message type */
flags.all = 0;
flags.bits.dup = dup;
flags.bits.QoS = qos;
flags.bits.retain = retained;
flags.bits.topicIdType = topic.type;
writeChar(&ptr, flags.all);
if (topic.type == MQTTSN_TOPIC_TYPE_NORMAL && qos == 3)
/* special arrangement for long topic names in QoS -1 publishes. The length of the topic is in the topicid field */
writeInt(&ptr, topic.data.long_.len); /* topic length */
else if (topic.type == MQTTSN_TOPIC_TYPE_NORMAL || topic.type == MQTTSN_TOPIC_TYPE_PREDEFINED)
writeInt(&ptr, topic.data.id);
writeChar(&ptr, topic.data.short_name[0]);
writeChar(&ptr, topic.data.short_name[1]);
writeInt(&ptr, packetid);
memcpy(ptr, topic.data.long_.name, topic.data.long_.len);
ptr += topic.data.long_.len;
memcpy(ptr, payload, payloadlen);
ptr += payloadlen;
rc = ptr - buf;
exit:
FUNC_EXIT_RC(rc);
return rc;
Kindly assist and help me to resolve this issue. Issue seems more of miss configuraton in memory config in sdk_config.h.
