Device: NRF53
I'm trying to send 3 notify packets in a 15ms connection internal but I can send 2.
I'm using Nrf connect and Zephyr. is there a limit or a define to set this.
Thank you for any guidance and help
Regards
I will try to get you a sniifer trace but I do remember the more data flag being set to false on the second packet.
I also thought that Simon had tried this test with two nrf dk's. Could you do a sniifer trace of it working with an nrf dk central please. If it's a limitation of the central then I can explain this to my customer.
Thanks
There is a chance that it's hitting the limit of the stack. But we do need a sniffer trace to really understand the situation.
Please also look at the throughput example. As far as I know you can reach around 700kbps at 1Mbps.given that the ATT_MTU is configured correctly and Data length extension is applied.
I've created the same issue that i've been having with a basic hr example using NCS 1.6.1. in the 1st example I loop round 3 packets then sleep 5ms the other I sleep 30ms. See attached 2 sniffer traces. You can see in the 4ms trace it sends two packets per connection interval to one with 30ms sleep it sends 3 per con interval.hr_example_3packetLoop30ms_sleep.pcapnghr_example_3packetLoop5ms_sleep.pcapng
Hi Neil,
Attached you can find my example of sending 25 notifications in a 15ms interval connection.
It's not the maximum limit I believe. If you increase CONFIG_BT_CONN_TX_MAX you should have more but the CONFIG_BT_CTLR_RX_BUFFERS is limited to 18.
I found that what slowing down the rate in the original centralhr example was the printk inside notify_func() that causing the central to NACK the packet from the peripheral.
In my test with my Galaxy S10 it achieved similar number of packets.
Please try the example I provided here and if it works please follow the configuration in my projects.
