Device: NRF53
I'm trying to send 3 notify packets in a 15ms connection internal but I can send 2.
I'm using Nrf connect and Zephyr. is there a limit or a define to set this.
Thank you for any guidance and help
Regards
Hi Neil
I can try to reproduce the issue here, yes. My first test wasn't very fruitful as it showed a lot more notifications sent per connection event, but I was testing with a higher connection interval. I will spend some more time with this tomorrow and see if I can make an example demonstrating higher throughput with 15ms connection interval.
Best regards
Torbjørn
Hi Neil
Checking my test results again I realized it was still only sending two packets pr connection interval, it is just the interval that was much shorter than I expected. In other words I got the same issue as you.
Discussing this with the software team it seems there is a limit in the SoftDevice controller on how many packets it can queue, which is set by the SDC_DEFAULT_TX_PACKET_COUNT define in \v1.6.1\nrfxlib\softdevice_controller\include\sdc.h:
/** @brief Default maximum Link Layer TX packet count per connection. * * With the default count, the application is able to refill the buffers during a connection event. */ #define SDC_DEFAULT_TX_PACKET_COUNT 3
Normally this isn't a big limitation, as it is possible to upload new data while the connection event is active, but in your case you are sending very short packets, which makes the timing much tighter.
On the nRF52 this works, but on the nRF53 there is some additional overhead because the packets have to be transferred from the Bluetooth host running on the application core to the Bluetooth controller in the network core.
If you change the number above and recompile you should see that you can send more packets pr connection event. I set it to 5, which gave me 4 packets pr connection event consistently.
Alternatively, if you send longer packets you should be able to send more of them, but I don't how long they need to be. The throughput example uses packets > 200 bytes, and doesn't have this problem (if it did the issue would probably have been spotted earlier).
I will discuss this with the team and see if we can get a better solution in the future, such as a configuration parameter that you can set in the project, so that editing the library header files is not necessary.
Best regards
Torbjørn
Hi Neil
Looking at his sniffer trace I see that he sent longer packets (35 bytes, including the 3 byte attribute header).
Clearly this is long enough to loosen the timing enough so that you can upload more packets during the connection event.
If your end goal is to maximize throughput, rather than sending many small packets, this is a simple fix to the problem. Just ensure you use a characteristic that supports longer packets (the heart rate measurement characteristic does not).
Best regards
Torbjørn
