Connect to device in 2 different ways to distinguish between masters
My device is the slave, that is being connected (not always in the same order) by 2 masters.
I would like to create two different connection ways/points to distinguish between the masters.
MASTER1 will always connect through "way1."
MASTER 2 will always connect through "way2."
And I could map the connection handles according to the way they connected.
What could "way1" and "way2" be?
I was thinking about changing the MAC address/Name I am advertising periodically, by that creating 2 connection points.
First master will always connect through MAC1/NAME1.
Second master will always connect via MAC2/NAME2.
Is it possible? Could I see that info in the message I am reviving?
Is there another way?
Thanks.
  • This solution sounds great, but I feel it might not be prefect.
    "On the slave side you will need to reconfigure the BLE device address periodically. Whenever the connected event occurs you know that the master that connected to you did it over the currently configured BLE device address (which you can map to MAC1 and MAC2)."
    My concern about this solution is of a race.
    By the time the connection ISR occurs, I may already change the system MAC.
    Is there a way to get this 100% accurate?
    Maybe a different ISR? Or a  way to read the destination MAC address from the masters packets? Or any other way..
    Thanks
  • Hi
    You make a fair point, there is a risk if the master connects to you just as you are changing advertise type.
    I took a closer look at the ble_gap_evt_connected_t struct:
    /**@brief Event structure for @ref BLE_GAP_EVT_CONNECTED. */
    typedef struct
      ble_gap_addr_t        peer_addr;              /**< Bluetooth address of the peer device. If the peer_addr resolved: @ref ble_gap_addr_t::addr_id_peer is set to 1
                                                         and the address is the device's identity address. */
      uint8_t               role;                   /**< BLE role for this connection, see @ref BLE_GAP_ROLES */
      ble_gap_conn_params_t conn_params;            /**< GAP Connection Parameters. */
      uint8_t               adv_handle;             /**< Advertising handle in which advertising has ended.
                                                         This variable is only set if role is set to @ref BLE_GAP_ROLE_PERIPH. */
      ble_gap_adv_data_t    adv_data;               /**< Advertising buffers corresponding to the terminated
                                                         advertising set. The advertising buffers provided in
                                                         @ref sd_ble_gap_adv_set_configure are now released.
    } ble_gap_evt_connected_t;
    It seems that when the master connects to you you will get the advertising handle and data corresponding to the advertising packet that the master connected to.
    This means that if your two types of advertising use two unique advertising handles, you should be able to safely determine which advertising packet the master responded to by looking at this field in the connected event.
    Please note I haven't tested this myself, since your use case is not a very common one.
    Best regards
    Torbjørn
  • Thanks, seems like a good solution, and I would like to try it.
    Can you tell me how can I read the handle number from my advertisement packets?
    Its location, or an API I can use to get/set it.
  • Hi
    When you configure the advertising payload you can set the handle, and you just need to make sure that you use two unique handle numbers that you can refer to later.
    Below is an excerpt from the ble_app_uart example, showing how the handle is set:
    In most examples the handle is just set to 1, since there is only one type of advertise packet defined.
    In your case you can just use 1 and 2.
    Best regards
    Torbjørn
