BLE timeout when SAADC sample rate is high
Hi, I'm sending SAADC data via BLE. If my SAADC_SAMPLE_RATE is high(e.g. 250ms), the code works perfectly fine. However, if I sample at a fast rate (e.g. 10ms), there will be a BLE ERROR 8 (0x8) GATT CONN TIMEOUT issue.
1) Does the error caused by BLE MTU, or SAADC dual Buffer, or something else?
2) If I set SAADC buffer = 4 and 4 channels, does that mean SAADC will save the past 4 data in the 4 channels (in total 16 data), and give return averaged data for 4 channels?
3) I use the timer to interrupt SAADC. For each interrupt, there will be only 1 SAADC reading. If SAADC_SAMPLE_RATE = 250ms and buffer = 4, does that mean SAADC returns the data at 1 second ago (250ms*4 = 1sec)?
4) BLE min/max connection interval is 10ms to 20ms. If my SAADC timer interrupts every 250ms, what data will BLE send during most of the connection intervals? Just empty packages?
5) If the BLE min/max connection interval is 10ms to 20ms, and my SAADC timer interrupts every 5ms, does that mean there will be 2-4 packets (Rx+Tx is 1 packet) for each connection interval?
6) My custom board uses an internal RC oscillator (32.768kHz), Why does SAADC uses NRF_TIMER_FREQ_31250Hz, but not 32.768kHz?
Thank you very much!
Here is my code.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_drv_saadc.h"
#include "nrf_drv_ppi.h"
#include "nrf_drv_timer.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION                0                                           /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
The connection interval is the amount of time between two connection events
in units of 1.25 ms.
The connection interval can range from a minimum value of 6 (7.5 ms) to a maximum of 3200 (4.0 s).
e.g.
If the slave device sends connection update request MIN_CONN = 15ms and MAX_CONN = 40ms,
that means the master has freedom to choose connection interval between 15ms and 40ms.
So 30ms is normal.
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(10, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
Slave Latency gives the slave (peripheral) device the option of skipping a number of connection events.
If the peripheral does not have any data to send, it can skip connection events, stay asleep, and save power.
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
Supervision Time-out is the maximum amount of time between two successful connection events.
If this time passes without a successful connection event, the device terminates the connection and returns to an unconnected state.
This parameter value is represented in units of 10 ms.
The supervision time-out value can range from a minimum of 10 (100 ms) to 3200 (32.0 s). \
The time-out must be larger than the effective connection interval.
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
#define SAADC_SAMPLES_IN_BUFFER         4
#define SAADC_SAMPLE_RATE               10                                           /**< SAADC sample rate in ms. */
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
volatile uint8_t state = 1;
static const nrf_drv_timer_t   m_timer = NRF_DRV_TIMER_INSTANCE(3);
static nrf_saadc_value_t       m_buffer_pool[2][SAADC_SAMPLES_IN_BUFFER];
static nrf_ppi_channel_t       m_ppi_channel;
static uint32_t                m_adc_evt_counter;
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for initializing the timer module.
static void timers_init(void)
 *          the device. It also sets the permissions and appearance.
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_evt       Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
        uint32_t err_code;
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
            do
                err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
            } while (err_code == NRF_ERROR_BUSY);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
    uint32_t           err_code;
    ble_nus_init_t     nus_init;
    // Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
    // Prepare wakeup buttons.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            NRF_LOG_INFO("Disconnected");
            // Auto/1Mbps/2Mbps/Coded/not-configured
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
            // Pairing not supported
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    ret_code_t err_code;
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') ||
                (data_array[index - 1] == '\r') ||
                (index >= m_ble_nus_max_data_len))
                if (index > 1)
                    do
                    } while (err_code == NRF_ERROR_RESOURCES);
                index = 0;
        case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_115200
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
    ble_advertising_init_t init;
    init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
    UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
    nrf_pwr_mgmt_run();
void timer_handler(nrf_timer_event_t event_type, void* p_context)
    nrf_drv_timer_config_t timer_config = NRF_DRV_TIMER_DEFAULT_CONFIG;
    timer_config.frequency = NRF_TIMER_FREQ_31250Hz;
    err_code = nrf_drv_timer_init(&m_timer, &timer_config, timer_handler);
    /* setup m_timer for compare event */
    uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer,SAADC_SAMPLE_RATE);
    nrf_drv_timer_extended_compare(&m_timer, NRF_TIMER_CC_CHANNEL0, ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
    uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer, NRF_TIMER_CC_CHANNEL0);
    uint32_t saadc_sample_event_addr = nrf_drv_saadc_sample_task_get();
    err_code = nrf_drv_ppi_channel_assign(m_ppi_channel, timer_compare_event_addr, saadc_sample_event_addr);
        uint16_t adc_value;
        uint8_t value[SAADC_SAMPLES_IN_BUFFER*2];
        uint16_t bytes_to_send;
        // set buffers
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAADC_SAMPLES_IN_BUFFER);
        // print samples on hardware UART and parse data for BLE transmission
        printf("ADC event number: %d\r\n",(int)m_adc_evt_counter);
        for (int i = 0; i < SAADC_SAMPLES_IN_BUFFER; i++)
            printf("%d\r\n", p_event->data.done.p_buffer[i]);
            adc_value = p_event->data.done.p_buffer[i];
            value[i*2] = adc_value;
            value[(i*2)+1] = adc_value >> 8;
         // Send data over BLE via NUS service. Create string from samples and send string with correct length.
        uint8_t nus_string[20];
        bytes_to_send = sprintf(nus_string,
                                "%d,%d,%d,%d",
                                p_event->data.done.p_buffer[0],
                                p_event->data.done.p_buffer[1],
                                p_event->data.done.p_buffer[2],
                                p_event->data.done.p_buffer[3]);
        err_code = ble_nus_data_send(&m_nus, nus_string, &bytes_to_send, m_conn_handle);
        if ((err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_NOT_FOUND))
        m_adc_evt_counter++;
void saadc_init(void)
    nrf_drv_saadc_config_t saadc_config = NRF_DRV_SAADC_DEFAULT_CONFIG;
    saadc_config.resolution = NRF_SAADC_RESOLUTION_12BIT;
    nrf_saadc_channel_config_t channel_0_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN4);
    channel_0_config.gain = NRF_SAADC_GAIN1_4;
    channel_0_config.reference = NRF_SAADC_REFERENCE_VDD4;
    nrf_saadc_channel_config_t channel_1_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN5);
    channel_1_config.gain = NRF_SAADC_GAIN1_4;
    channel_1_config.reference = NRF_SAADC_REFERENCE_VDD4;
    nrf_saadc_channel_config_t channel_2_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN6);
    channel_2_config.gain = NRF_SAADC_GAIN1_4;
    channel_2_config.reference = NRF_SAADC_REFERENCE_VDD4;
    nrf_saadc_channel_config_t channel_3_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN7);
    channel_3_config.gain = NRF_SAADC_GAIN1_4;
    channel_3_config.reference = NRF_SAADC_REFERENCE_VDD4;
    err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);
    err_code = nrf_drv_saadc_channel_init(0, &channel_0_config);
    err_code = nrf_drv_saadc_channel_init(1, &channel_1_config);
    err_code = nrf_drv_saadc_channel_init(2, &channel_2_config);
    err_code = nrf_drv_saadc_channel_init(3, &channel_3_config);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0],SAADC_SAMPLES_IN_BUFFER);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1],SAADC_SAMPLES_IN_BUFFER);
/**@brief Application main function.
    bool erase_bonds;
    // Initialize.
    uart_init();
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    saadc_sampling_event_init();
    saadc_init();
    // Start execution.
    printf("\r\nUART started2.\r\n");
    advertising_start();
    // Enter main loop.
    for (;;)
        idle_state_handle();
    I am not sure what you are asking here, are you getting an error? If so, what error is generated?
    Please make sure to have DEBUG defined in your preprocessor defines, like shown in the included image, to have the logger output a detailed error message whenever a non-NRF_SUCCSS error code is passed to an APP_ERROR_CHECK.
    EDIT: I see now that you say you are getting a GATT timeout error. This means that your connection times out - i.e the central or peripheral is not hearing from its peer in the time configured as the timeout. Are the devices still within range? Is both devices always powered on?
    No, if you set SAADC buffer to 4, it will be big enough to contain 4 samples.
    If you are using the SAADC in scan mode, it will sample once from every enabled channel each time the SAMPLE task is triggered, which will then produce 4 samples, immediately filling up the buffer.
    If you would like the SAADC to average over a number of samples you will have to enable oversampling on the channels. Please be advised that oversampling must be configured together with burst mode, in order to work when the SAADC is in scan mode.
    No, each time SAMPLE is triggered it will sample all enabled channels, which here is 4. 4 samples will therefore be generated every sampling.
    Yes. If there is no data to be sent when a connection event is upcoming both devices will send an empty packet to maintain the connection. In these cases you should either increase your connection interval, or make use of the slave latency feature in order to save power.
    This depends on your connection event length configuration. If there is more packets to send, the devices will keep on sending packets for the entire duration of the configured connection event length. You can use the Online Power profiler to see how different size TX payloads are transferred depending on the configured connection event length and connection interval.
    The TIMER peripheral uses the HFCLK, not the LFCLK. The frequency therefore have to be a multiple of the HFCLK frequency, since the lower frequencies are implemented by prescaling the HFCLK tick rate. You can find the available prescaler values here.
    Karl
  • Thank you so much for your detailed support, Karl!
    My SAADC uses timer1 and PPI to generate interruption every XXX ms. If 50ms, my BLE works perfectly fine. However, if I shorten the interruption time, for example 10ms, BLE seems to be very unstable (BLE will disconnect after 2-20 seconds). I only send a very small amount of data (about 10-15 bytes) every time.
    I have read another post on a Chinese website. The author says that the reason is: Device hasn't completed transmitting the current data, and the device tries to send another new data. The solution is to add a flag in BLE. The device only allows sending the next data until the previous data has been sent successfully.
    Do you support his/her opinion? How to add this "BLE transmitting is completed flag", please?
    Thanks, Karl
    Thank you for your continued patience with this. I have been out of office for some time now, but now I am back.
    No problem at all, I am happy to help!
    Thank you for elaborating.
    What do you mean what you say unstable? What reason do you get for the disconnect?
    Could you possibly provide a sniffer trace of the on-air BLE traffic when this happens? You could use the nRF Sniffer tool to capture this trace.
    This will not be the case when working with the SoftDevice. The SoftDevice handles all this for you, behind the scenes. What I could imagine might be happening is that the SoftDevice returns an error code (non-NRF_SUCCESS) to the application after a function call, and that the application then resets due to this error, thus disrupting the BLE connection and everything else. Could this be the case?
    Karl
  • Thanks for your help, Karl.
    I used Nordic UART Service --> Tx Characteristic in nRF Connect App to receive BLE data. When SAADC interrupt time = 50ms, both BLE advertising and receiving data are very stable. It will never disconnect.
    However, if I change to SAADC interrupt time = 20ms, BLE advertising and connection are very unstable. BLE advertising and connection are fine. But after selecting receiving data, BLE will disconnect automatically after 1-20 seconds. The Error message is: Error 8 (0x8): GATT CONN TIMEOUTBecause in 50ms SAADC interrupt case, BLE works fine. So I think that my code has no problem.
    In my code, I used TWI, SAADC (PPI interruption), UART and BLE. I used the internal clock, clock calibration in SDK is configured.
    I used the nRF52 DK as the BLE sniffer. Here are 2 sniffer log files:
    Sniffer 1) stable BLE connection (50ms SAADC interrupt)
    Sniffer 2) unstable BLE connection (20ms SAADC interrupt)
    Unstable BLE.pcapngStable BLE.pcapng
    Thank you for providing the sniffer traces, this makes it a lot easier for me to see what is happening.
    It seems to me that your peripheral device abruptly stops responding in the unstable trace - this is very helpful for debugging purposes.
    This behavior makes me suspect that the device might be encountering an error that causes it to reset, could this be the case?
    Are you able to monitor what is happening on the peripheral side of the link when this behavior occurs?
    I see from your included main.c code that you are initializing the logger. Are you seeing the logger's RTT output? You should be able to see this either in the SES Debug terminal or in the standalone SEGGER RTT Viewer desktop application.
    Based on the information we have so far I am suspecting that the increased sampling rate is causing a buffer to overflow, which in turn resets the device.
    The default error handling of the APP_ERROR_CHECK is to reset the device, so unless you have implemented specific error handling for it this is what will happen whenever a non-NRF_SUCCESS error code is passed to an APP_ERROR_CHECK.
    Please make sure to have DEBUG defined in your preprocessor defines for the common build configuration like described in my initial reply, and check what the RTT log reads when this behavior occurs. Please let me know what the logger says.
    Looking forward to resolving this issue together!
    Karl
