Error including libraries
I'm building a project for a nRF5340 and i need to use the mesh_stack.h library to reset device mesh configuration however every time i try to include it i get a CMake error on command terminal while compiling. The SES doesn't even let me add the library itself.
What can i do to surpass this?
Thank you for your help.
  • Hello, David!
    Could you please provide the whole build log here so that I can investigate the error? You should not have to add libraries through SES yourself, so I guess there is a configuration error here.
    Carl Richard
  • Hi Carl,
    The build log that identifies the error is the following:
    Building ‘C:/Users/david/ncs/v1.6.0/zephyr/include/dt-bindings/gpio/gpio.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘C:/Users/david/ncs/v1.6.0/zephyr/include/dt-bindings/i2c/i2c.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/misc/generated/syscalls.json’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/misc/generated/struct_tags.json’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/parse_syscalls_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/parse_syscalls_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/driver-validation.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/kobj-types-enum.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/otype-to-str.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/otype-to-size.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/syscall_list.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/syscall_dispatch.c’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_offsets’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/offsets’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/offsets.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/offsets_h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/offsets_h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/zephyr_generated_headers’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_app’ from solution ‘build’ in configuration ‘Common’
    Building ‘app/libapp.a’ from solution ‘build’ in configuration ‘Common’
    1> Compiling ‘main.c’
    2> Compiling ‘model_handler.c’
    1> ../src/main.c:14:10: fatal error: mesh_stack.h: No such file or directory
    1> compilation terminated.
    Build failed
    I can't get to the discovery of this because in the api reference it says that mesh_stack.h should be a library but i can't use it. Probably doing something wrong.
    David Abreu
  • Hi again, David!
    Thank you for your long patience here. I could not find any reference to "mesh_stack.h" in NCS/Zephyr. However, could the bt_mesh_reset function suit your needs? This resets a node to an unprovisioned state.
    From what I can see mesh_stack.h is a part of the old Mesh SDK, which isn't compatible with the nRF5340.
    Carl Richard
