nrf52833 P0.0 will output high level strangely
SDK17.0.2+NRF52833
I use nrf52833 to do some thing, P1.09 and p0.11 as two pwm singals to drive two motor and P0.0 as a led pin (high made led light).
the code as following:
static void pwm0_init(void)
    uint32_t err_code;
    nrf_drv_pwm_config_t const config0 =
        .output_pins =
            MOTOR_CTRL_PIN_0 | NRF_DRV_PWM_PIN_INVERTED, //P1.09
            MOTOR_CTRL_PIN_1 | NRF_DRV_PWM_PIN_INVERTED, //P0.11
        .irq_priority = APP_IRQ_PRIORITY_LOWEST,
        .base_clock   = NRF_PWM_CLK_500kHz,
        .count_mode   = NRF_PWM_MODE_UP,
        .top_value    = PWM_TOP_VALUE,
        .load_mode    = NRF_PWM_LOAD_INDIVIDUAL,
        .step_mode    = NRF_PWM_STEP_AUTO
    err_code = nrf_drv_pwm_init(&m_pwm0, &config0, NULL);
    m_used |= USED_PWM(0);
    //board_light_red();
    m_pwm_seq_values.channel_0 = 0;
    m_pwm_seq_values.channel_1 = 0;
    nrf_drv_pwm_simple_playback(&m_pwm0, &m_pwm_seq, 1, NRF_DRV_PWM_FLAG_LOOP);//why execute this, the P0.0 output high level.
void motor_ctrl_init(void)
    uint8_t i = 0;
	uint32_t motor_ctrls[] = MOTOR_PINS_LIST;
	for (i = 0; i < MOTOR_CTRLS_NUMBER; i++)
		nrf_gpio_cfg_output(motor_ctrls[i]);
        nrf_gpio_pin_write(motor_ctrls[i],0);
    pwm0_init();
	NRF_LOG_DEBUG("%s return ok.\n", __FUNCTION__);
	uint32_t err_code;
	log_init();
	NRF_LOG_INFO("apps start......");
	motor_ctrl_init();
I want light the LED after pwm init. but the led(connected P0.0)lighted before my code to output the p0.0 high level-when the pwm0_init function executed. It's not match my desire.
additional: Softdevice burninged(s140_nrf52_7.2.0_softdevice.hex)
