Unable to Connect nRF5340DK with BMI270 Over I2C
I am attempting to get the BMI270 sample working on an nRF5340DK, using nRF Connect SDK v1.6.0, but all attempts at device_get_binding("BMI270"), device_get_binding(DT_LABEL(DT_INST(0, bosch_bmi270))), and similar return null.  I am using the following config and overlay files
#prj.conf
CONFIG_UART_CONSOLE=n
CONFIG_USE_SEGGER_RTT=y
CONFIG_RTT_CONSOLE=y
CONFIG_I2C=y
CONFIG_SENSOR=y
CONFIG_BMI270=y
/* nrf5340dk_nrf5340_cpuapp.overlay - no shield */
&arduino_i2c {
	status = "okay";
	bmi270@68 {
		compatible = "bosch,bmi270";
		reg = <0x68>;
		label = "BMI270";
On the hardware side I'm using a BMI270 breakout connecting SDA to P1.02 and SCL to P1.03.
I have also used a shield that sends SDA to P0.25 and SCL to P0.26, with the following overlay
/* nrf5340dk_nrf5340_cpuapp.overlay - with shield */
&i2c1 {
    sda-pin = <25>;
    scl-pin = <26>;
&arduino_i2c {
	status = "okay";
	bmi270@68 {
		reg = <0x68>;
		label = "BMI270";
In all attempted cases
#include <zephyr.h>
#include <device.h>
#include <drivers/sensor.h>
#include <stdio.h>
void main(void)
	const struct device *dev;
	dev = device_get_binding("BMI270");
	if (dev == NULL) {
		printf("Could not get %s device\n",
		       DT_LABEL(DT_INST(0, bosch_bmi270)));
		return;
gives the output
00> *** Booting Zephyr OS build v2.6.0-rc1-ncs1  ***
00> Could not get BMI270 device
in J-Link RTT Viewer.
Any help would be greatly appreciated.
  • Hello, Jonathan!
    Thanks for reaching out!  Could you please share the Zephyr.dts file (located in build/zephyr/) so that I can verify that the hardware configuration?
    Carl Richard
  • Hi Carl,
    Here is zephyr.dts from the build folder:
    /dts-v1/;
    	#address-cells = < 0x1 >;
    	#size-cells = < 0x1 >;
    	model = "Nordic NRF5340 DK NRF5340 Application";
    	compatible = "nordic,nrf5340-dk-nrf5340-cpuapp";
    	chosen {
    		zephyr,entropy = &cryptocell;
    		zephyr,flash-controller = &flash_controller;
    		zephyr,console = &uart0;
    		zephyr,shell-uart = &uart0;
    		zephyr,uart-mcumgr = &uart0;
    		zephyr,bt-mon-uart = &uart0;
    		zephyr,bt-c2h-uart = &uart0;
    		zephyr,ipc_shm = &sram0_shared;
    		zephyr,sram = &sram0_image;
    		zephyr,flash = &flash0;
    		zephyr,code-partition = &slot0_partition;
    		zephyr,sram-secure-partition = &sram0_s;
    		zephyr,sram-non-secure-partition = &sram0_ns;
    	aliases {
    		led0 = &led0;
    		led1 = &led1;
    		led2 = &led2;
    		led3 = &led3;
    		pwm-led0 = &pwm_led0;
    		sw0 = &button0;
    		sw1 = &button1;
    		sw2 = &button2;
    		sw3 = &button3;
    		bootloader-led0 = &led0;
    	soc {
    		compatible = "nordic,nRF5340-CPUAPP-QKAA", "nordic,nRF5340-CPUAPP", "nordic,nRF53", "simple-bus";
    		interrupt-parent = < &nvic >;
    		ranges;
    		nvic: interrupt-controller@e000e100 {
    			compatible = "arm,v8m-nvic";
    			reg = < 0xe000e100 0xc00 >;
    			interrupt-controller;
    			#interrupt-cells = < 0x2 >;
    			arm,num-irq-priority-bits = < 0x3 >;
    			phandle = < 0x1 >;
    		systick: timer@e000e010 {
    			compatible = "arm,armv8m-systick";
    			reg = < 0xe000e010 0x10 >;
    			status = "disabled";
    		sram0: memory@20000000 {
    			compatible = "mmio-sram";
    			reg = < 0x20000000 0x80000 >;
    		sram1: memory@21000000 {
    			reg = < 0x21000000 0x10000 >;
    		peripheral@50000000 {
    			ranges = < 0x0 0x50000000 0x10000000 >;
    			flash_controller: flash-controller@39000 {
    				compatible = "nordic,nrf53-flash-controller";
    				reg = < 0x39000 0x1000 >;
    				label = "NRF_FLASH_DRV_NAME";
    				flash0: flash@0 {
    					compatible = "soc-nv-flash";
    					label = "NRF_FLASH";
    					erase-block-size = < 0x1000 >;
    					write-block-size = < 0x4 >;
    					reg = < 0x0 0x100000 >;
    					partitions {
    						boot_partition: partition@0 {
    							label = "mcuboot";
    							reg = < 0x0 0x10000 >;
    						slot0_partition: partition@10000 {
    							label = "image-0";
    							reg = < 0x10000 0x40000 >;
    						slot0_ns_partition: partition@50000 {
    							label = "image-0-nonsecure";
    							reg = < 0x50000 0x30000 >;
    						slot1_partition: partition@80000 {
    							label = "image-1";
    							reg = < 0x80000 0x40000 >;
    						slot1_ns_partition: partition@c0000 {
    							label = "image-1-nonsecure";
    							reg = < 0xc0000 0x30000 >;
    						scratch_partition: partition@f0000 {
    							label = "image-scratch";
    							reg = < 0xf0000 0xa000 >;
    						storage_partition: partition@fa000 {
    							label = "storage";
    							reg = < 0xfa000 0x6000 >;
    			adc: adc@e000 {
    				compatible = "nordic,nrf-saadc";
    				reg = < 0xe000 0x1000 >;
    				interrupts = < 0xe 0x1 >;
    				status = "okay";
    				label = "ADC_0";
    				#io-channel-cells = < 0x1 >;
    				phandle = < 0x6 >;
    			dppic: dppic@17000 {
    				compatible = "nordic,nrf-dppic";
    				reg = < 0x17000 0x1000 >;
    				status = "okay";
    				label = "DPPIC";
    			egu0: egu@1b000 {
    				compatible = "nordic,nrf-egu";
    				reg = < 0x1b000 0x1000 >;
    				interrupts = < 0x1b 0x1 >;
    				status = "okay";
    			egu1: egu@1c000 {
    				reg = < 0x1c000 0x1000 >;
    				interrupts = < 0x1c 0x1 >;
    				status = "okay";
    			egu2: egu@1d000 {
    				reg = < 0x1d000 0x1000 >;
    				interrupts = < 0x1d 0x1 >;
    				status = "okay";
    			egu3: egu@1e000 {
    				reg = < 0x1e000 0x1000 >;
    				interrupts = < 0x1e 0x1 >;
    				status = "okay";
    			egu4: egu@1f000 {
    				reg = < 0x1f000 0x1000 >;
    				interrupts = < 0x1f 0x1 >;
    				status = "okay";
    			egu5: egu@20000 {
    				reg = < 0x20000 0x1000 >;
    				interrupts = < 0x20 0x1 >;
    				status = "okay";
    			i2s0: i2s@28000 {
    				compatible = "nordic,nrf-i2s";
    				#size-cells = < 0x0 >;
    				reg = < 0x28000 0x1000 >;
    				interrupts = < 0x28 0x1 >;
    				label = "I2S_0";
    			ipc: ipc@2a000 {
    				compatible = "nordic,nrf-ipc";
    				reg = < 0x2a000 0x1000 >;
    				interrupts = < 0x2a 0x1 >;
    				status = "okay";
    				label = "IPC";
    			kmu: kmu@39000 {
    				compatible = "nordic,nrf-kmu";
    				interrupts = < 0x39 0x1 >;
    				status = "okay";
    			pdm0: pdm@26000 {
    				compatible = "nordic,nrf-pdm";
    				reg = < 0x26000 0x1000 >;
    				interrupts = < 0x26 0x1 >;
    				label = "PDM_0";
    			qdec0: qdec@33000 {
    				compatible = "nordic,nrf-qdec";
    				reg = < 0x33000 0x1000 >;
    				interrupts = < 0x33 0x1 >;
    				label = "QDEC_0";
    			qdec1: qdec@34000 {
    				reg = < 0x34000 0x1000 >;
    				interrupts = < 0x34 0x1 >;
    				label = "QDEC_1";
    			regulators: regulator@4000 {
    				compatible = "nordic,nrf-regulators";
    				reg = < 0x4000 0x1000 >;
    				status = "okay";
    			vmc: vmc@81000 {
    				compatible = "nordic,nrf-vmc";
    				reg = < 0x81000 0x1000 >;
    				status = "okay";
    			uart0: uart@8000 {
    				reg = < 0x8000 0x1000 >;
    				interrupts = < 0x8 0x1 >;
    				status = "okay";
    				label = "UART_0";
    				current-speed = < 0x1c200 >;
    				tx-pin = < 0x14 >;
    				rx-pin = < 0x16 >;
    				rts-pin = < 0x13 >;
    				cts-pin = < 0x15 >;
    			uart1: arduino_serial: uart@9000 {
    				reg = < 0x9000 0x1000 >;
    				interrupts = < 0x9 0x1 >;
    				label = "UART_1";
    				tx-pin = < 0x21 >;
    				rx-pin = < 0x20 >;
    			uart2: uart@b000 {
    				reg = < 0xb000 0x1000 >;
    				interrupts = < 0xb 0x1 >;
    				label = "UART_2";
    			uart3: uart@c000 {
    				reg = < 0xc000 0x1000 >;
    				interrupts = < 0xc 0x1 >;
    				label = "UART_3";
    			i2c0: i2c@8000 {
    				clock-frequency = < 0x186a0 >;
    				label = "I2C_0";
    			i2c1: arduino_i2c: i2c@9000 {
    				status = "okay";
    				label = "I2C_1";
    				sda-pin = < 0x22 >;
    				scl-pin = < 0x23 >;
    				bmi270@68 {
    					reg = < 0x68 >;
    					label = "BMI270";
    			i2c2: i2c@b000 {
    				label = "I2C_2";
    			i2c3: i2c@c000 {
    				label = "I2C_3";
    			spi0: spi@8000 {
    				label = "SPI_0";
    			spi1: spi@9000 {
    				label = "SPI_1";
    			spi2: spi@b000 {
    				status = "okay";
    				label = "SPI_2";
    				sck-pin = < 0x2f >;
    				miso-pin = < 0x2e >;
    				mosi-pin = < 0x2d >;
    			spi3: spi@c000 {
    				label = "SPI_3";
    			spi4: arduino_spi: spi@a000 {
    				reg = < 0xa000 0x1000 >;
    				interrupts = < 0xa 0x1 >;
    				label = "SPI_4";
    				sck-pin = < 0x2f >;
    				cs-gpios = < &arduino_header 0x10 0x1 >;
    			pwm0: pwm@21000 {
    				compatible = "nordic,nrf-pwm";
    				reg = < 0x21000 0x1000 >;
    				interrupts = < 0x21 0x1 >;
    				status = "okay";
    				label = "PWM_0";
    				#pwm-cells = < 0x1 >;
    				ch0-pin = < 0x1c >;
    				phandle = < 0x4 >;
    			pwm1: pwm@22000 {
    				reg = < 0x22000 0x1000 >;
    				interrupts = < 0x22 0x1 >;
    				label = "PWM_1";
    			pwm2: pwm@23000 {
    				reg = < 0x23000 0x1000 >;
    				interrupts = < 0x23 0x1 >;
    				label = "PWM_2";
    			pwm3: pwm@24000 {
    				reg = < 0x24000 0x1000 >;
    				interrupts = < 0x24 0x1 >;
    				label = "PWM_3";
    			gpio0: gpio@842500 {
    				compatible = "nordic,nrf-gpio";
    				gpio-controller;
    				reg = < 0x842500 0x300 >;
    				#gpio-cells = < 0x2 >;
    				label = "GPIO_0";
    				status = "okay";
    				port = < 0x0 >;
    				phandle = < 0x3 >;
    			gpio1: gpio@842800 {
    				gpio-controller;
    				reg = < 0x842800 0x300 >;
    				ngpios = < 0x10 >;
    				label = "GPIO_1";
    				status = "okay";
    				port = < 0x1 >;
    				phandle = < 0x5 >;
    			qspi: qspi@2b000 {
    				compatible = "nordic,nrf-qspi";
    				reg = < 0x2b000 0x1000 >;
    				interrupts = < 0x2b 0x1 >;
    				status = "okay";
    				label = "QSPI";
    				sck-pin = < 0x11 >;
    				io-pins = < 0xd >, < 0xe >, < 0xf >, < 0x10 >;
    				csn-pins = < 0x12 >;
    				mx25r64: mx25r6435f@0 {
    					compatible = "nordic,qspi-nor";
    					reg = < 0x0 >;
    					writeoc = "pp4io";
    					readoc = "read4io";
    					sck-frequency = < 0x7a1200 >;
    					label = "MX25R64";
    					jedec-id = [ C2 28 17 ];
    					sfdp-bfp = [ E5 20 F1 FF FF FF FF 03 44 EB 08 6B 08 3B 04 BB EE FF FF FF FF FF 00 FF FF FF 00 FF 0C 20 0F 52 10 D8 00 FF 23 72 F5 00 82 ED 04 CC 44 83 68 44 30 B0 30 B0 F7 C4 D5 5C 00 BE 29 FF F0 D0 FF FF ];
    					size = < 0x4000000 >;
    					has-dpd;
    					t-enter-dpd = < 0x2710 >;
    					t-exit-dpd = < 0x88b8 >;
    			rtc0: rtc@14000 {
    				compatible = "nordic,nrf-rtc";
    				reg = < 0x14000 0x1000 >;
    				cc-num = < 0x4 >;
    				interrupts = < 0x14 0x1 >;
    				status = "okay";
    				clock-frequency = < 0x8000 >;
    				prescaler = < 0x1 >;
    				label = "RTC_0";
    			rtc1: rtc@15000 {
    				reg = < 0x15000 0x1000 >;
    				cc-num = < 0x4 >;
    				interrupts = < 0x15 0x1 >;
    				status = "okay";
    				label = "RTC_1";
    			clock: clock@5000 {
    				compatible = "nordic,nrf-clock";
    				reg = < 0x5000 0x1000 >;
    				interrupts = < 0x5 0x1 >;
    				status = "okay";
    				label = "CLOCK";
    			power: power@5000 {
    				compatible = "nordic,nrf-power";
    				status = "okay";
    			wdt: wdt0: watchdog@18000 {
    				compatible = "nordic,nrf-watchdog";
    				reg = < 0x18000 0x1000 >;
    				interrupts = < 0x18 0x1 >;
    				status = "okay";
    				label = "WDT";
    			wdt1: watchdog@19000 {
    				reg = < 0x19000 0x1000 >;
    				interrupts = < 0x19 0x1 >;
    				label = "WDT_1";
    			timer0: timer@f000 {
    				compatible = "nordic,nrf-timer";
    				status = "okay";
    				reg = < 0xf000 0x1000 >;
    				cc-num = < 0x6 >;
    				interrupts = < 0xf 0x1 >;
    				prescaler = < 0x0 >;
    				label = "TIMER_0";
    			timer1: timer@10000 {
    				status = "okay";
    				reg = < 0x10000 0x1000 >;
    				cc-num = < 0x6 >;
    				interrupts = < 0x10 0x1 >;
    				label = "TIMER_1";
    			timer2: timer@11000 {
    				status = "okay";
    				reg = < 0x11000 0x1000 >;
    				cc-num = < 0x6 >;
    				interrupts = < 0x11 0x1 >;
    				label = "TIMER_2";
    			usbd: usbd@36000 {
    				compatible = "nordic,nrf-usbd";
    				reg = < 0x36000 0x1000 >;
    				interrupts = < 0x36 0x1 >;
    				num-bidir-endpoints = < 0x1 >;
    				num-in-endpoints = < 0x7 >;
    				num-out-endpoints = < 0x7 >;
    				num-isoin-endpoints = < 0x1 >;
    				num-isoout-endpoints = < 0x1 >;
    				status = "okay";
    				label = "USBD";
    		cryptocell: crypto@50844000 {
    			compatible = "nordic,nrf-cc312";
    			reg = < 0x50844000 0x1000 >;
    			label = "CRYPTOCELL";
    			status = "okay";
    			cryptocell312: crypto@50845000 {
    				compatible = "arm,cryptocell-312";
    				reg = < 0x50845000 0x1000 >;
    				interrupts = < 0x44 0x1 >;
    				label = "CRYPTOCELL312";
    		gpiote: gpiote@5000d000 {
    			compatible = "nordic,nrf-gpiote";
    			reg = < 0x5000d000 0x1000 >;
    			interrupts = < 0xd 0x5 >;
    			status = "okay";
    			label = "GPIOTE_0";
    		spu: spu@50003000 {
    			compatible = "nordic,nrf-spu";
    			reg = < 0x50003000 0x1000 >;
    			interrupts = < 0x3 0x1 >;
    			status = "okay";
    		ficr: ficr@ff0000 {
    			compatible = "nordic,nrf-ficr";
    			reg = < 0xff0000 0x1000 >;
    			status = "okay";
    		uicr: uicr@ff8000 {
    			compatible = "nordic,nrf-uicr";
    			reg = < 0xff8000 0x1000 >;
    			status = "okay";
    	cpus {
    		cpu@0 {
    			device_type = "cpu";
    			compatible = "arm,cortex-m33f";
    			reg = < 0x0 >;
    			swo-ref-frequency = < 0x3d09000 >;
    			mpu: mpu@e000ed90 {
    				compatible = "arm,armv8m-mpu";
    				reg = < 0xe000ed90 0x40 >;
    				arm,num-mpu-regions = < 0x8 >;
    	leds {
    		compatible = "gpio-leds";
    		led0: led_0 {
    			gpios = < &gpio0 0x1c 0x1 >;
    			label = "Green LED 0";
    		led1: led_1 {
    			gpios = < &gpio0 0x1d 0x1 >;
    			label = "Green LED 1";
    		led2: led_2 {
    			gpios = < &gpio0 0x1e 0x1 >;
    			label = "Green LED 2";
    		led3: led_3 {
    			gpios = < &gpio0 0x1f 0x1 >;
    			label = "Green LED 3";
    	pwmleds {
    		compatible = "pwm-leds";
    		pwm_led0: pwm_led_0 {
    			pwms = < &pwm0 0x1c >;
    	buttons {
    		compatible = "gpio-keys";
    		button0: button_0 {
    			gpios = < &gpio0 0x17 0x11 >;
    			label = "Push button 1";
    		button1: button_1 {
    			gpios = < &gpio0 0x18 0x11 >;
    			label = "Push button 2";
    		button2: button_2 {
    			gpios = < &gpio0 0x8 0x11 >;
    			label = "Push button 3";
    		button3: button_3 {
    			gpios = < &gpio0 0x9 0x11 >;
    			label = "Push button 4";
    	arduino_header: connector {
    		compatible = "arduino-header-r3";
    		gpio-map-mask = < 0xffffffff 0xffffffc0 >;
    		gpio-map-pass-thru = < 0x0 0x3f >;
    		gpio-map = < 0x0 0x0 &gpio0 0x4 0x0 >, < 0x1 0x0 &gpio0 0x5 0x0 >, < 0x2 0x0 &gpio0 0x6 0x0 >, < 0x3 0x0 &gpio0 0x7 0x0 >, < 0x4 0x0 &gpio0 0x19 0x0 >, < 0x5 0x0 &gpio0 0x1a 0x0 >, < 0x6 0x0 &gpio1 0x0 0x0 >, < 0x7 0x0 &gpio1 0x1 0x0 >, < 0x8 0x0 &gpio1 0x4 0x0 >, < 0x9 0x0 &gpio1 0x5 0x0 >, < 0xa 0x0 &gpio1 0x6 0x0 >, < 0xb 0x0 &gpio1 0x7 0x0 >, < 0xc 0x0 &gpio1 0x8 0x0 >, < 0xd 0x0 &gpio1 0x9 0x0 >, < 0xe 0x0 &gpio1 0xa 0x0 >, < 0xf 0x0 &gpio1 0xb 0x0 >, < 0x10 0x0 &gpio1 0xc 0x0 >, < 0x11 0x0 &gpio1 0xd 0x0 >, < 0x12 0x0 &gpio1 0xe 0x0 >, < 0x13 0x0 &gpio1 0xf 0x0 >, < 0x14 0x0 &gpio1 0x2 0x0 >, < 0x15 0x0 &gpio1 0x3 0x0 >;
    		phandle = < 0x2 >;
    	arduino_adc: analog-connector {
    		compatible = "arduino,uno-adc";
    		io-channel-map = < 0x0 &adc 0x0 >, < 0x1 &adc 0x1 >, < 0x2 &adc 0x2 >, < 0x3 &adc 0x3 >, < 0x4 &adc 0x4 >, < 0x5 &adc 0x5 >;
    	reserved-memory {
    		ranges;
    		sram0_image: image@20000000 {
    			reg = < 0x20000000 0x70000 >;
    		sram0_s: image_s@20000000 {
    			reg = < 0x20000000 0x40000 >;
    		sram0_ns: image_ns@20040000 {
    			reg = < 0x20040000 0x30000 >;
    		sram0_shared: memory@20070000 {
    			reg = < 0x20070000 0x10000 >;
  • As an update, we had the BMI270 printing valid data on an Arduino Duo in 10 minutes to confirm the problem was not the IMU.  Similarly the BMI270 sample suggest this should run with a simple build and flash on a 52840DK.  After 3 days we've had no progress getting a simple IMU measurement data stream from the 5340DK.  Should we be developing on an nRF52 chip?  It seems that Zephyr support for nRF53 is not mature.
  • Hello again!
    Thank you for the Zephyr.dts. It looks good to me, so the issue isn't there likely. Some more questions:
    - Which board are your targeting, nrf5340dk_nrf5340_cpuapp or nrf5340dk_nrf5340_cpuappns?
    - Are you able verify there is actually some activity on the I2C pins using a logic analyzer, oscilloscope or similar?
    - Have you verified that you are using the correct I2C address? I have a I2C Scanner sample that can be used for checking for I2C addresses on the bus. Some changes might be needed, including an overlay for your target board.
    There is production support for the nRF5340 in the current release of NCS/Zephyr, but you can consider using the nRF52840 if that's more fitting for your application. The two devices are very different and interchanging samples won't necessarily out-of-the box.
    Best regards,
    Carl Richard
