nRF52810 flashing problem: NOT_AVAILABLE_BECAUSE_PROTECTION (ffffffa6)
I'm trying to program a custom board with a nRF52810 via nRF Connect. I keep getting the following error messages:
Error when getting device info: Error: Error: Error occured when get device info. Errorcode: CouldNotCallFunction (0x9) Lowlevel error: NOT_AVAILABLE_BECAUSE_PROTECTION (ffffffa6)
20:06:57.641	Could not fetch memory size of target devkit: Cannot read property 'family' of undefined
I followed this post and tried the following commands:
$ nrfjprog.exe --coprocessor CP_APPLICATION --memrd 0x00FF8000
ERROR: The operation attempted is unavailable due to readback protection in
ERROR: your device. Please use --recover to unlock the device.
$ nrfjprog.exe --coprocessor CP_APPLICATION --recover
Recovering device. This operation might take 30s.
ERROR: Recover failed. Please make sure that the correct device family is given
ERROR: and try again.
I'm using a Segger j-link debugger with a 6-pin-needle adapter to connect the board with my PC via SWD.
Any advice on how to solve this problem is very much appreciated!
    Generally speaking, if you are developing for the custom board, you ask to be provided with a blank chip without protections from the manufacturer, if possible. But if what you are trying to do is overwrite the software of a custom board, aka not a DK or dev/ev board, that already had software programmed in it with lock bits for write/read protection, there are ways to do it. One way was the one mentioned before, but I forgot to say it uses debuggers from ST.
    A more generic way to erasing a board is specified here that can work with most programmers. It involves writing directly to register bits related to memory protection. I don't think I've done this before, so I'm unsure if this will fit your case.
  • Hi tmllr,
    Please use J-Link Commander to check the VTref and make sure it could be detected as 3.300V. If this cannot help, please execute nrfjprog.exe -f NRF52 --recover -log and provide the log.
    -Amanda H.
  • Hi Amanda,
    Thanks for your suggestions. I manually set the VTref to 3.3V but connecting to the device still didn't work.
    SEGGER J-Link Commander V7.50a (Compiled Jul  8 2021 18:22:32)
    DLL version V7.50a, compiled Jul  8 2021 18:21:11
    Connecting to J-Link via USB...O.K.
    Firmware: J-Link V9 compiled May  7 2021 16:26:12
    Hardware version: V9.30
    S/N: 269303476
    License(s): FlashBP, GDB
    OEM: SEGGER-EDU
    VTref=0.000V
    Type "connect" to establish a target connection, '?' for help
    J-Link>VTREF 3300
    New fixed VTref = 3300mV
    The new configuration applies after power cycling the probe.
    J-Link>connect
    Please specify device / core. <Default>: ARM9
    Type '?' for selection dialog
    Device>?
    Please specify target interface:
      J) JTAG (Default)
      S) SWD
      T) cJTAG
    TIF>
    Device position in JTAG chain (IRPre,DRPre) <Default>: -1,-1 => Auto-detect
    JTAGConf>
    Specify target interface speed [kHz]. <Default>: 4000 kHz
    Speed>
    Device "NRF52810_XXAA" selected.
    Connecting to target via JTAG
    InitTarget() start
    InitTarget() end
    TotalIRLen = ?, IRPrint = 0x..000000000000000000000000
    InitTarget() start
    InitTarget() end
    InitTarget() start
    InitTarget() end
    InitTarget() start
    InitTarget() end
    Cannot connect to target.
    J-Link>
    The log from nrfjprog is this:
    $ nrfjprog.exe -f NRF52 --recover --log
    ERROR: [  nRF52] - Access protection is enabled, can't read device version.
    ERROR: [  nRF52] - Failed to write UICR after recovering.
    Seem you don't connect the VTref pin of the J-Link to the VDD of the nRF. Can you check it?
    -Amanda
  • Hi Amanda,
    The VTref pin is connected with the VDD of the chip. I checked that.
    However, I started the J-Link Commander before connecting the board, that is why VTref=0.000V was detected. Doing it in the right order, it seems that the debugger detects some voltage:
    S/N: 269303476
    OEM: SEGGER-EDU
    VTref=4.817V
    J-Link>
    Connecting still doesn't work, though.
    Best,
    Thilo
