I am using nRF5340DK for development. Currently, I have two problems:
QS1:When I use fun nrfx_gpiote_out_toggle(), it reports Assert error on NRFX_ASSERT(!pin_in_use_by_te(pin)). I have asked your agents, but they know nothing about it. So far, the way I've dealt with it is ://NRFX_ASSERT(!pin_in_use_by_te(pin));(it's in nrfx_gpiote.c)
QS2:when CONFIG_BOARD_ENABLE_CPUNET=y in prj.conf
The data received by I2S via serial port printing (the nrfx_I2S driver is called) works fine, but when try to run a network core(add CONFIG_BOARD_ENABLE_CPNET = Y in prj.conf ), both the network core and the application core will run, but the I2S IRQ of the application core can't interrupt . I simulated with SES and found that only one interrupt was entered after I2S initialization (nrfx_i2s_start had not been executed at this time), and no more interrupts were entered after that .
Looking forward to your answers.
Code information:
1、APP CORE:
prj.conf
#GPIO
CONFIG_GPIO=n
CONFIG_NRFX_GPIOTE=y
#I2S
CONFIG_NRFX_I2S=y
CONFIG_SPM_NRF_I2S0_NS=y
#LOG
CONFIG_LOG=y
CONFIG_LOG_PRINTK=y
CONFIG_LOG_BACKEND_SHOW_COLOR=n
#use RTT logging
CONFIG_ASSERT=y
CONFIG_ASSERT_LEVEL=2
CONFIG_LOG=y
CONFIG_LOG_DEFAULT_LEVEL=4
CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=100
CMakeLists
cmake_minimum_required(VERSION 3.8.2)
include($ENV{ZEPHYR_BASE}/cmake/app/boilerplate.cmake NO_POLICY_SCOPE)
project(loopone)
# NORDIC SDK APP START
target_sources(app PRIVATE src/main.c)
# NORDIC SDK APP END
2、NET CORE:
CMakeLists:
# Copyright (c) 2018 Nordic Semiconductor
# SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
cmake_minimum_required(VERSION 3.13.1)
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(NONE)
target_sources(app PRIVATE ../lib/esb.c)
target_sources(app PRIVATE ../lib/radio.c)
zephyr_include_directories(../lib)
kconfig:
# Copyright (c) 2020 Nordic Semiconductor
source "Kconfig.zephyr"
rsource "../lib/Kconfig"
menu "Enhanced ShockBurst: Transmitter"
config APP_LOG_LEVEL
int "Log level for the ESB sample"
default 4
endmenu
menu "Radio Ramp up"
config RADIO_FAST_RAMP
bool "Radio fast ramp up"
default y
endmenu
prj:
# Copyright (c) 2019 Nordic Semiconductor ASA
CONFIG_NCS_SAMPLES_DEFAULTS=y
