Actually in my program I have a serial uart interface that cause an interrupt when a message is receive. During the interrupt, I send a mesh model command and its works.
But if I put my serial messages in a queue and then I dequeue them in the main loop, I got an "Assertion Failed Error at: 0" when I try to send a mesh model command, especially if I need to change the publish address of the model before sending the command. But even if I just send the command without using the dsm function to change the publish address, I got the same error.
So how can I send a mesh model message (using the dsm to change the publish address of a model before sending) from the main loop ?
Regards
The command sending code that works when its called from uart interrupt and not from main loop.
The assertions are raised by "dsm_address_publish_add" and "access_model_publish_address_set"
uint8_t send_hx_cmd(uint16_t dest, uint8_t* cmd)
dsm_handle_t hdl;
uint32_t res = dsm_address_publish_add(dest, &hdl);
if (res != NRF_SUCCESS)
return SERIAL_ERROR;
res = access_model_publish_address_set(m_hx_model_control.model_handle, hdl);
static uint8_t cmd_data[SERIAL_COMMAND_SIZE];
cmd_data[0] = 0x00;
memcpy( &cmd_data[1], &cmd[0], 29 );
res = hx_model_client_opcode_tx(&m_hx_model_control.client_model, cmd_data, SERIAL_COMMAND_SIZE);
return SERIAL_CMD_SUCCESS;
The function that cause the assertion error (in mesh_config.c) .
The assertion is raised by "dirty_entries_process();"
static uint32_t entry_store(const mesh_config_entry_params_t * p_params, mesh_config_entry_id_t id, const void * p_entry)
uint32_t status = p_params->callbacks.setter(id, p_entry);
if (status == NRF_SUCCESS)
mesh_config_entry_flags_t * p_flags = entry_flags_get(p_params, id);
*p_flags |= (mesh_config_entry_flags_t)(MESH_CONFIG_ENTRY_FLAG_DIRTY | MESH_CONFIG_ENTRY_FLAG_ACTIVE);
const mesh_config_file_params_t * p_file = file_params_find(p_params->p_id->file);
NRF_MESH_ASSERT(p_file != NULL);
listeners_notify(p_params, MESH_CONFIG_CHANGE_REASON_SET, id, p_entry);
return status;
Used sdk :
- nRF5_SDK_16.0.0_98a08e2
- nrf5_SDK_for_Mesh_v4.2.0_src
Board used :
- nrf52840 evaluation board v2.0.1
