Trouble programming nrf5340dk
I am following the guide on this page: https://github.com/project-chip/connectedhomeip/tree/master/examples/lock-app/nrfconnect
I can build the firmware, but having trouble to program the nRF5340DK.
west flash --recover
ERROR: The --family option given with the command (or the default from nrfjprog.ini) does not match the device connected.
FATAL ERROR: command exited with status 18: nrfjprog --recover -f NRF53 --coprocessor CP_NETWORK --snr 960138681
nrfjprog version: 10.13.0
JLinkARM.dll version: 7.50a
- OS: macOS (11.5) darwin x64
- Versions
- kernel: 20.6.0
- git: 2.30.1
- node: 12.13.0
- python: 2.7.16
- python3: 3.8.2
- Connected devices:
- /dev/tty.usbmodem0009601386815: 000960138681 PCA10095
  • Hi Hongfeng!
    Thats odd. Do you know what chip version are you using?
    And what does it output when you run:
    nrfjprog --recover --coprocessor CP_NETWORK -f NRF53
    Elfving
  • nrfjprog --recover --coprocessor CP_NETWORK -f NRF53
    nrfjprog --recover -f NRF53 --log
    ERROR: [  nRF53] - Debug probe is not connected to an NRF53 series device.
    The sticker on the board:
    PCA10095
    0.11.0
    2020.51
    960138681
    FYI, I was able to program nRF52840 Dongle on the same laptop setup
  • Could you give me that logfile that was generated?
    And could you try "nrfjprog --eraseall", as well as checking the Programmer in the nRF Connect App?
    Elfving
  • nrfjprog --eraseall --log
    ERROR: [  nRFXX] - Device does not have an ARM debug port.
    ERROR: nrfjprog could not identify the target device...
    nRF connect programmer: when target is selected:
    2021-07-22T17:53:05.026Z INFO Using nrfjprog library 10.12.1, pc-nrfjprog-js 1.7.6
    2021-07-22T17:53:05.103Z DEBUG App pc-nrfconnect-programmer v1.4.11 official
    2021-07-22T17:53:05.103Z DEBUG App path: /Users/hongfeng/.nrfconnect-apps/node_modules/pc-nrfconnect-programmer
    2021-07-22T17:53:05.103Z DEBUG nRFConnect 3.7.0, required by the app is (^3.6.0)
    2021-07-22T17:53:05.104Z DEBUG nRFConnect path: /Applications/nRF Connect.app/Contents/Resources/app.asar
    2021-07-22T17:53:05.104Z DEBUG HomeDir: /Users/hongfeng
    2021-07-22T17:53:05.104Z DEBUG TmpDir: /var/folders/5m/7jg_758d6bd7qv9p_89fv1dr0000gp/T/
    2021-07-22T17:53:11.543Z INFO Using nrfjprog to communicate with target
    2021-07-22T17:53:12.311Z ERROR Could not fetch memory size of target devkit: Error: Error occured when get library info. Errorcode: CouldNotOpenDevice (0x4)
    Lowlevel error: Unknown value (fffffffa)
    # nRFConnect System Report - 2021-07-20T23-03-29.533Z
    - System: Apple Inc. MacBookPro14,3
    - BIOS: Apple Inc. 429.140.8.0.0
    - CPU: 1 x Intel® CoreTm i7-7820HQ 2.9 GHz 8 cores (4 physical)
    - Memory: 1.4 GB free of 16 GB total
    - Filesystem: /dev/disk1s5s1 (APFS) 465 GB 29.1% used
    - Versions
    - kernel: 20.6.0
    - git: 2.30.1
    - node: 12.13.0
    - python: 2.7.16
    - python3: 3.8.2
    Thanks for the help!
  • It got even worse. Now I can't even detect the usb serial port.I start to suspect the board is bad. How can I get a replacement? I bought it from DigiKey.
