I want to use NCS to acquire RSSI with a total of two nRF51s, one central and one peripheral.
I want to use ncs to get the RSSI at 10ms intervals.
For example, central receives an empty packet from peripheral at 10ms interval.
I would like to know if there is a sample project or code that has the necessary connection intervals, functions for sending empty packets, or functions for this purpose.
The following is the code for peripheral.
 * Copyright (c) 2018 Nordic Semiconductor ASA
/** @file
 *  @brief Nordic UART Bridge Service (NUS) sample
#include <stdio.h>
#include <zephyr/types.h>
#include <zephyr.h>
#include <drivers/uart.h>
#include <device.h>
#include <soc.h>
#include <bluetooth/bluetooth.h>
#include <bluetooth/uuid.h>
#include <bluetooth/gatt.h>
#include <bluetooth/hci.h>
#include <bluetooth/services/nus.h>
#include <dk_buttons_and_leds.h>
#include <settings/settings.h>
#include <stdio.h>
#include <logging/log.h>
#define LOG_MODULE_NAME peripheral_uart
LOG_MODULE_REGISTER(LOG_MODULE_NAME);
#define STACKSIZE CONFIG_BT_NUS_THREAD_STACK_SIZE
#define PRIORITY 7
#define DEVICE_NAME CONFIG_BT_DEVICE_NAME
#define DEVICE_NAME_LEN	(sizeof(DEVICE_NAME) - 1)
#define RUN_STATUS_LED DK_LED1
#define RUN_LED_BLINK_INTERVAL 1000
#define CON_STATUS_LED DK_LED2
#define KEY_PASSKEY_ACCEPT DK_BTN1_MSK
#define KEY_PASSKEY_REJECT DK_BTN2_MSK
#define UART_BUF_SIZE CONFIG_BT_NUS_UART_BUFFER_SIZE
#define UART_WAIT_FOR_BUF_DELAY K_MSEC(50)
#define UART_WAIT_FOR_RX CONFIG_BT_NUS_UART_RX_WAIT_TIME
static K_SEM_DEFINE(ble_init_ok, 0, 1);
static struct bt_conn *current_conn;
static struct bt_conn *auth_conn;
static const struct device *uart;
static struct k_delayed_work uart_work;
struct uart_data_t {
	void *fifo_reserved;
	uint8_t data[UART_BUF_SIZE];
	uint16_t len;
static K_FIFO_DEFINE(fifo_uart_tx_data);
static K_FIFO_DEFINE(fifo_uart_rx_data);
static const struct bt_data ad[] = {
	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
static const struct bt_data sd[] = {
	BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_NUS_VAL),
device型はname,config設定のアドレス,API構造体のアドレス,コモンデバイスの状態のアドレス,デバイスインスタンスのプライベートデータのアドレス
デバイスに関連するハンドルへの任意のポインタを持つ
uart_evnetは現在のイベントに関する情報を含む構造体
static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
	ARG_UNUSED(dev);
	static uint8_t *current_buf;
	static size_t aborted_len;
	static bool buf_release;
	struct uart_data_t *buf;
	static uint8_t *aborted_buf;
	switch (evt->type) {
	case UART_TX_DONE:
		if ((evt->data.tx.len == 0) ||
		    (!evt->data.tx.buf)) {
			return;
		if (aborted_buf) {
			buf = CONTAINER_OF(aborted_buf, struct uart_data_t,
					   data);
			aborted_buf = NULL;
			aborted_len = 0;
		} else {
			buf = CONTAINER_OF(evt->data.tx.buf, struct uart_data_t,
					   data);
		k_free(buf);
		buf = k_fifo_get(&fifo_uart_tx_data, K_NO_WAIT);
		if (!buf) {
			return;
		if (uart_tx(uart, buf->data, buf->len, SYS_FOREVER_MS)) {
			LOG_WRN("Failed to send data over UART");
	case UART_RX_RDY:
		buf = CONTAINER_OF(evt->data.rx.buf, struct uart_data_t, data);
		buf->len += evt->data.rx.len;
		buf_release = false;
		if (buf->len == UART_BUF_SIZE) {
			k_fifo_put(&fifo_uart_rx_data, buf);
		} else if ((evt->data.rx.buf[buf->len - 1] == '\n') ||
			  (evt->data.rx.buf[buf->len - 1] == '\r')) {
                        /* k_fifo_putは第二引数のbufを
                          fifo先入れ先出しのアドレスに追加している
			current_buf = evt->data.rx.buf;
			buf_release = true;
			uart_rx_disable(uart);
	case UART_RX_DISABLED:
		buf = k_malloc(sizeof(*buf));
		if (buf) {
			buf->len = 0;
		} else {
			LOG_WRN("Not able to allocate UART receive buffer");
			k_delayed_work_submit(&uart_work,
					      UART_WAIT_FOR_BUF_DELAY);
			return;
		uart_rx_enable(uart, buf->data, sizeof(buf->data),
			       UART_WAIT_FOR_RX);
	case UART_RX_BUF_REQUEST:
		if (buf) {
			buf->len = 0;
			uart_rx_buf_rsp(uart, buf->data, sizeof(buf->data));
		} else {
	case UART_RX_BUF_RELEASED:
		buf = CONTAINER_OF(evt->data.rx_buf.buf, struct uart_data_t,
				   data);
		if (buf_release && (current_buf != evt->data.rx_buf.buf)) {
			k_free(buf);
			current_buf = NULL;
	case UART_TX_ABORTED:
			if (!aborted_buf) {
				aborted_buf = (uint8_t *)evt->data.tx.buf;
			aborted_len += evt->data.tx.len;
					   data);
			uart_tx(uart, &buf->data[aborted_len],
				buf->len - aborted_len, SYS_FOREVER_MS);
static void uart_work_handler(struct k_work *item)
	if (buf) {
		buf->len = 0;
	} else {
		k_delayed_work_submit(&uart_work, UART_WAIT_FOR_BUF_DELAY);
		return;
	uart_rx_enable(uart, buf->data, sizeof(buf->data), UART_WAIT_FOR_RX);
static int uart_init(void)
	int err;
	struct uart_data_t *rx;
	uart = device_get_binding(DT_LABEL(DT_NODELABEL(uart0)));
	if (!uart) {
		return -ENXIO;
	rx = k_malloc(sizeof(*rx));
	if (rx) {
		rx->len = 0;
	} else {
		return -ENOMEM;
	k_delayed_work_init(&uart_work, uart_work_handler);
	err = uart_callback_set(uart, uart_cb, NULL);
	if (err) {
		return err;
	return uart_rx_enable(uart, rx->data, sizeof(rx->data), 50);
static void connected(struct bt_conn *conn, uint8_t err)
	if (err) {
		LOG_ERR("Connection failed (err %u)", err);
		return;
	LOG_INF("Connected %s", log_strdup(addr));
	current_conn = bt_conn_ref(conn);
	dk_set_led_on(CON_STATUS_LED);
	LOG_INF("Disconnected: %s (reason %u)", log_strdup(addr), reason);
	if (auth_conn) {
		bt_conn_unref(auth_conn);
		auth_conn = NULL;
	if (current_conn) {
		bt_conn_unref(current_conn);
		current_conn = NULL;
		dk_set_led_off(CON_STATUS_LED);
#ifdef CONFIG_BT_NUS_SECURITY_ENABLED
static void security_changed(struct bt_conn *conn, bt_security_t level,
			     enum bt_security_err err)
	if (!err) {
		LOG_INF("Security changed: %s level %u", log_strdup(addr),
			level);
	} else {
		LOG_WRN("Security failed: %s level %u err %d", log_strdup(addr),
			level, err);
static struct bt_conn_cb conn_callbacks = {
	.connected    = connected,
	.disconnected = disconnected,
	.security_changed = security_changed,
#if defined(CONFIG_BT_NUS_SECURITY_ENABLED)
static void auth_passkey_display(struct bt_conn *conn, unsigned int passkey)
	LOG_INF("Passkey for %s: %06u", log_strdup(addr), passkey);
static void auth_passkey_confirm(struct bt_conn *conn, unsigned int passkey)
	auth_conn = bt_conn_ref(conn);
	LOG_INF("Press Button 1 to confirm, Button 2 to reject.");
static void auth_cancel(struct bt_conn *conn)
	LOG_INF("Pairing cancelled: %s", log_strdup(addr));
static void pairing_confirm(struct bt_conn *conn)
	bt_conn_auth_pairing_confirm(conn);
	LOG_INF("Pairing confirmed: %s", log_strdup(addr));
static void pairing_complete(struct bt_conn *conn, bool bonded)
	LOG_INF("Pairing completed: %s, bonded: %d", log_strdup(addr),
		bonded);
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
	LOG_INF("Pairing failed conn: %s, reason %d", log_strdup(addr),
		reason);
static struct bt_conn_auth_cb conn_auth_callbacks = {
	.passkey_display = auth_passkey_display,
	.passkey_confirm = auth_passkey_confirm,
	.cancel = auth_cancel,
	.pairing_confirm = pairing_confirm,
	.pairing_complete = pairing_complete,
	.pairing_failed = pairing_failed
#else
static struct bt_conn_auth_cb conn_auth_callbacks;
static void bt_receive_cb(struct bt_conn *conn, const uint8_t *const data,
			  uint16_t len)
	int err;
	char addr[BT_ADDR_LE_STR_LEN] = {0};
	bt_addr_le_to_str(bt_conn_get_dst(conn), addr, ARRAY_SIZE(addr));
	LOG_INF("Received data from: %s", log_strdup(addr));
	for (uint16_t pos = 0; pos != len;) {
		struct uart_data_t *tx = k_malloc(sizeof(*tx));
		if (!tx) {
			LOG_WRN("Not able to allocate UART send data buffer");
			return;
		/* Keep the last byte of TX buffer for potential LF char. */
		size_t tx_data_size = sizeof(tx->data) - 1;
		if ((len - pos) > tx_data_size) {
			tx->len = tx_data_size;
		} else {
			tx->len = (len - pos);
		memcpy(tx->data, &data[pos], tx->len);
		pos += tx->len;
		/* Append the LF character when the CR character triggered
		 * transmission from the peer.
		if ((pos == len) && (data[len - 1] == '\r')) {
			tx->data[tx->len] = '\n';
			tx->len++;
		err = uart_tx(uart, tx->data, tx->len, SYS_FOREVER_MS);
		if (err) {
			k_fifo_put(&fifo_uart_tx_data, tx);
static struct bt_nus_cb nus_cb = {
	.received = bt_receive_cb,
void error(void)
	dk_set_leds_state(DK_ALL_LEDS_MSK, DK_NO_LEDS_MSK);
	while (true) {
		/* Spin for ever */
		k_sleep(K_MSEC(1000));
static void num_comp_reply(bool accept)
	if (accept) {
		bt_conn_auth_passkey_confirm(auth_conn);
		LOG_INF("Numeric Match, conn %p", (void *)auth_conn);
	} else {
		bt_conn_auth_cancel(auth_conn);
		LOG_INF("Numeric Reject, conn %p", (void *)auth_conn);
	auth_conn = NULL;
void button_changed(uint32_t button_state, uint32_t has_changed)
	uint32_t buttons = button_state & has_changed;
	if (auth_conn) {
		if (buttons & KEY_PASSKEY_ACCEPT) {
			num_comp_reply(true);
		if (buttons & KEY_PASSKEY_REJECT) {
			num_comp_reply(false);
static void configure_gpio(void)
	int err;
	err = dk_buttons_init(button_changed);
	if (err) {
		LOG_ERR("Cannot init buttons (err: %d)", err);
	err = dk_leds_init();
	if (err) {
		LOG_ERR("Cannot init LEDs (err: %d)", err);
void main(void)
	int blink_status = 0;
	int err = 0;
	configure_gpio();
	err = uart_init();
	if (err) {
		error();
	bt_conn_cb_register(&conn_callbacks);
	if (IS_ENABLED(CONFIG_BT_NUS_SECURITY_ENABLED)) {
		bt_conn_auth_cb_register(&conn_auth_callbacks);
	err = bt_enable(NULL);
	if (err) {
		error();
	LOG_INF("Bluetooth initialized");
	k_sem_give(&ble_init_ok);
	if (IS_ENABLED(CONFIG_SETTINGS)) {
		settings_load();
	err = bt_nus_init(&nus_cb);
	if (err) {
		LOG_ERR("Failed to initialize UART service (err: %d)", err);
		return;
	err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad), sd,
			      ARRAY_SIZE(sd));
	if (err) {
		LOG_ERR("Advertising failed to start (err %d)", err);
	printk("Starting Nordic UART service example\n");
	for (;;) {
		dk_set_led(RUN_STATUS_LED, (++blink_status) % 2);
		k_sleep(K_MSEC(RUN_LED_BLINK_INTERVAL));
                          uint32_t radio_rssi_get(void);
void ble_write_thread(void)
	/* Don't go any further until BLE is initialized */
	k_sem_take(&ble_init_ok, K_FOREVER);
                                      uint32_t rssi;
                                      char buf2[15];
	for (;;) {
		/* Wait indefinitely for data to be sent over bluetooth*/
		struct uart_data_t *buf = k_fifo_get(&fifo_uart_rx_data,
						     K_FOREVER);       /*K_FOREVERは無限のタイムアウト遅延を発生させる
                このマクロは、要求された操作を実行するのに必要な時間だけ待つように、カーネルAPIに指示するタイムアウト遅延を生成します。
		if (bt_nus_send(NULL, buf->data, buf->len)) {
			LOG_WRN("Failed to send data over BLE connection");
		k_free(buf);
                                          rssi = radio_rssi_get();
                                          sprintf(buf2,"%012d\r\n",rssi);
                                          bt_nus_send(NULL,buf2,14);
K_THREAD_DEFINE(ble_write_thread_id, STACKSIZE, ble_write_thread, NULL, NULL,
		NULL, PRIORITY, 0, 0);
  • I know it's not supported and may not work properly, but I'm asking for the following.
    I want to make it work under my responsibility.
    The version of NCS is 1.6.
    /** @file
    #include <stdio.h>
    #include <zephyr.h>
    #include <device.h>
    #include <soc.h>
    #include <stdio.h>
    #define PRIORITY 7
    	uint16_t len;
    	ARG_UNUSED(dev);
    	case UART_TX_DONE:
    			return;
    		if (aborted_buf) {
    					   data);
    			aborted_buf = NULL;
    			aborted_len = 0;
    		} else {
    					   data);
    		k_free(buf);
    		if (!buf) {
    			return;
    	case UART_RX_RDY:
    			buf_release = true;
    		if (buf) {
    			buf->len = 0;
    		} else {
    			return;
    			       UART_WAIT_FOR_RX);
    		if (buf) {
    			buf->len = 0;
    		} else {
    				   data);
    			k_free(buf);
    			current_buf = NULL;
    			if (!aborted_buf) {
    					   data);
    	if (buf) {
    		buf->len = 0;
    	} else {
    		return;
    	int err;
    	if (!uart) {
    		return -ENXIO;
    	if (rx) {
    		rx->len = 0;
    	} else {
    		return -ENOMEM;
    	if (err) {
    		return err;
    	if (err) {
    		return;
    	if (auth_conn) {
    		auth_conn = NULL;
    	if (current_conn) {
    	if (!err) {
    			level);
    	} else {
    			level, err);
    		bonded);
    		reason);
    #else
    			  uint16_t len)
    	int err;
    		if (!tx) {
    			return;
    		} else {
    		pos += tx->len;
    			tx->len++;
    		if (err) {
    void error(void)
    	while (true) {
    		/* Spin for ever */
    	if (accept) {
    	} else {
    	auth_conn = NULL;
    	if (auth_conn) {
    	int err;
    	if (err) {
    	if (err) {
    void main(void)
    	int err = 0;
    	configure_gpio();
    	err = uart_init();
    	if (err) {
    		error();
    	if (err) {
    		error();
    		settings_load();
    	if (err) {
    		return;
    			      ARRAY_SIZE(sd));
    	if (err) {
    	for (;;) {
        int64_t k_uptime_get(void);
        uint64_t time_stamp;
        uint64_t milliseconds_spent;
        /* capture initial time stamp */
        time_stamp = k_uptime_get();
                                          uint32_t rssi;
                                          char buf2[30];
        while(1){
        k_sleep(K_MSEC(10));
        /* compute how long the work took (also updates the time stamp) */
        milliseconds_spent = k_uptime_delta(&time_stamp);
        sprintf(buf2,"%012d\t%llu\r\n",rssi,milliseconds_spent);
        //sprintf(buf2,"%012d\r\n",rssi);
        bt_nus_send(NULL,buf2,20);
    The peripheral code looks like this, but I don't think this code is able to get the rsi according to the "connection interval".
    When this code is executed, the rssi is obtained, but the time repeats between "11" and "39".
    I want to get the polling packets from central and record the rssi and timestamp, what library should I use?
    /** @file
    #include <stdio.h>
    #include <zephyr.h>
    #include <device.h>
    #include <soc.h>
    #include <stdio.h>
    #define PRIORITY 7
    	uint16_t len;
    	ARG_UNUSED(dev);
    	case UART_TX_DONE:
    			return;
    		if (aborted_buf) {
    					   data);
    			aborted_buf = NULL;
    			aborted_len = 0;
    		} else {
    					   data);
    		k_free(buf);
    		if (!buf) {
    			return;
    	case UART_RX_RDY:
    			buf_release = true;
    		if (buf) {
    			buf->len = 0;
    		} else {
    			return;
    			       UART_WAIT_FOR_RX);
    		if (buf) {
    			buf->len = 0;
    		} else {
    				   data);
    			k_free(buf);
    			current_buf = NULL;
    			if (!aborted_buf) {
    					   data);
    	if (buf) {
    		buf->len = 0;
    	} else {
    		return;
    	int err;
    	if (!uart) {
    		return -ENXIO;
    	if (rx) {
    		rx->len = 0;
    	} else {
    		return -ENOMEM;
    	if (err) {
    		return err;
    	if (err) {
    		return;
    	if (auth_conn) {
    		auth_conn = NULL;
    	if (current_conn) {
    	if (!err) {
    			level);
    	} else {
    			level, err);
    		bonded);
    		reason);
    #else
    			  uint16_t len)
    	int err;
    		if (!tx) {
    			return;
    		} else {
    		pos += tx->len;
    			tx->len++;
    		if (err) {
    void error(void)
    	while (true) {
    		/* Spin for ever */
    	if (accept) {
    	} else {
    	auth_conn = NULL;
    	if (auth_conn) {
    	int err;
    	if (err) {
    	if (err) {
    void main(void)
    	int err = 0;
    	configure_gpio();
    	err = uart_init();
    	if (err) {
    		error();
    	if (err) {
    		error();
    		settings_load();
    	if (err) {
    		return;
    			      ARRAY_SIZE(sd));
    	if (err) {
    	for (;;) {
                          #define SYS_CLOCK_HW_CYCLES_TO_NS(X) (uint32_t)(SYS_CLOCK_HW_CYCLES_TO_NS64(X))
                          /* SYS_CLOCK_HW_CYCLES_TO_NS64 converts CPU clock cycles to nanoseconds */
                          #define SYS_CLOCK_HW_CYCLES_TO_NS64(X) \
                                  (((uint64_t)(X) * NSEC_PER_SEC) / sys_clock_hw_cycles_per_sec())
                          uint32_t start_time;
                          uint32_t stop_time;
                          uint32_t cycles_spent;
                          uint32_t nanoseconds_spent;
                          start_time = k_cycle_get_32();
        uint32_t rssi;
        char buf2[30];
        while(1){
                          /* capture final time stamp */
                          stop_time = k_cycle_get_32();
                          /* compute how long the work took (assumes no counter rollover) */
                          cycles_spent = stop_time - start_time;
                          nanoseconds_spent = SYS_CLOCK_HW_CYCLES_TO_NS(cycles_spent);
                          sprintf(buf2,"%012d\t%zu\r\n",rssi,nanoseconds_spent);
        bt_nus_send(NULL,buf2,28);
    I modified the code again, and implemented a function to record rssi and timestamp when polling is received from central.
    However, I don't understand the clock settings, so I don't understand the meaning of the time lapse values displayed.
    And why does the counter sometimes skip?
    Also, I would like to know the code to control the polling interval of central.
  • Hi
    I can try to run your code on my side, but it seems you didn't include all the code, such as the implementation of the radio_rssi_get() function?
    Are you able to just add your source files as attachments, instead of copy pasting the code into the case?
    Then it is easier for me to include it in a local project and see if I can get the code running.
    Best regards
    Torbjørn
  • 8015.peripheral_uart.zip
    I use "build_nrf51dongle_nrf51422">>"peripheral_uart",and "central_uart".
    4786.central_uart.zip
    The code has changed again since last time.
    The question also changes a little. Sorry.
    The problem is as follows.
    1. The timestamp is no longer missing, but the display of teraterm is frequently wrong.
    2. Is it correct to understand that I can find the time by dividing the timestamp value by 32768 (clock frequency)?
    3.  I believe that the program in my peripheral records the rssi and timestamp in response to polling from Central, but am I correct in my understanding?
    4. How can I fix the polling interval of central to 7.5ms?
