nrf5340 Internal Capacitors CL for HFXO
I'm a little confused about how to determine the value to set in the registers for the internal capacitors. If I select 10pF, that means that there is an internal C1 and C2 which I use in the equation to get C1' and C2' to then calculate CL, correct? For instance, I am trying to get CL to be 6pF. Cpin is 2.5pF. Cpcb is 0.5pF. So, I select 9pF for the internal capacitors and get a CL of 6pF. Could you please verify? And perhaps an example in the datasheet would clear it up, or maybe a simple table?
