NRF52840 SPIM3 extended config ss_duration not changing CSN inactive duration?
By changing ss_duration the duration CSN is high doesn't seem to be effected?
ss_duration = 2
CSN
SCK
ss_duration = 64
CSN
SCK
Setup
SPI Config
#define SS_DURATION_SHORT 2
#define SS_DURATION_LONG 64
nrfx_spim_config_t spi_config = NRFX_SPIM_DEFAULT_CONFIG;
spi_config.ss_pin = DEVICE_CS;
spi_config.miso_pin = SPI_MISO;
spi_config.mosi_pin = NRFX_SPIM_PIN_NOT_USED;
spi_config.sck_pin = SPI_SCK;
spi_config.ss_active_high = false;
spi_config.frequency = NRF_SPIM_FREQ_1M;
spi_config.mode = NRF_SPIM_MODE_0;
spi_config.bit_order = NRF_SPIM_BIT_ORDER_MSB_FIRST;
spi_config.dcx_pin = NRFX_SPIM_PIN_NOT_USED;
spi_config.use_hw_ss = true;
spi_config.ss_duration = SS_DURATION_SHORT;
nrfx_spim_init(&spi, &spi_config, NULL, NULL);
spi.p_reg->RXD.PTR = (uint32_t)sample_buffer;
spi.p_reg->RXD.MAXCNT = sizeof(sample_buffer[0]); //Size of transaction
spi.p_reg->RXD.LIST = 1; //Use ARRAY List
PPI
SPIM3 END EVENT -> SPIM3 START TASK
SPIM3 END EVENT -> TIMER2 COUNT TASK
Example Code Below
 * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup blinky_example_main main.c
 * @ingroup blinky_example
 * @brief Blinky Example Application main file.
 * This file contains the source code for a sample application to blink LEDs.
#include <stdbool.h>
#include <stdint.h>
#include "nrf_delay.h"
//Nordic
#include "nrf_gpio.h"
#include "nrfx_spim.h"
#include "nrfx_timer.h"
#include "nrfx_ppi.h"
#include "nrf_drv_ppi.h"
#define SAMPLES 1001
#define SAMPLE_BUFFER_SIZE SAMPLES + 100
static uint8_t sample_buffer[SAMPLE_BUFFER_SIZE][3];
static volatile uint32_t sample_buffer_count = 0;
static const nrfx_spim_t spi = NRFX_SPIM_INSTANCE(3);
static const nrfx_timer_t count_timer = NRFX_TIMER_INSTANCE(2);
static nrf_ppi_channel_t spi_start_ppi_channel;
static nrf_ppi_channel_t spi_sample_ppi_channel;
static nrf_ppi_channel_t spi_count_ppi_channel;
#define DEVICE_CS NRF_GPIO_PIN_MAP(1,10)
#define SPI_MISO NRF_GPIO_PIN_MAP(1,11)
#define SPI_SCK NRF_GPIO_PIN_MAP(0,28)
static void start() {
  //Enable sample looping channel
  nrf_drv_ppi_channel_enable(spi_sample_ppi_channel);
  //Reset pointer
  nrf_spim_task_trigger(spi.p_reg, NRF_SPIM_TASK_START);
static void timer_handler(nrf_timer_event_t event_type, void * p_context) {
static volatile uint32_t sample_buffer_count;
 * @brief Function for application main entry.
  nrf_gpio_cfg_output(DEVICE_CS);
  nrf_gpio_cfg_output(SPI_SCK);
  nrf_gpio_cfg_input(SPI_MISO, NRF_GPIO_PIN_NOPULL);
  spi_config.ss_duration = SS_DURATION_LONG;
  uint32_t err_code = nrf_drv_ppi_init();
  //Sample
  err_code = nrf_drv_ppi_channel_alloc(&spi_sample_ppi_channel);
  uint32_t spi_end_evt_addr        = nrfx_spim_end_event_get(&spi);
  uint32_t spi_start_task_addr       = nrfx_spim_start_task_get(&spi);
  //Trigger SPI start on a SPI end
  err_code = nrf_drv_ppi_channel_assign(spi_sample_ppi_channel, spi_end_evt_addr, spi_start_task_addr);
  err_code = nrf_drv_ppi_channel_enable(spi_sample_ppi_channel);
  //Count
  //Setup timer in counter mode
  nrfx_timer_config_t timer_cfg = NRFX_TIMER_DEFAULT_CONFIG;
  timer_cfg.frequency = NRF_TIMER_FREQ_16MHz;
  timer_cfg.mode = NRF_TIMER_MODE_LOW_POWER_COUNTER;
  err_code = nrfx_timer_init(&count_timer, &timer_cfg, timer_handler);
  //Count PPI
  err_code = nrf_drv_ppi_channel_alloc(&spi_count_ppi_channel);
  uint32_t timer_count_evt_addr       = nrfx_timer_task_address_get(&count_timer, NRF_TIMER_TASK_COUNT);
  err_code = nrf_drv_ppi_channel_assign(spi_count_ppi_channel, spi_end_evt_addr, timer_count_evt_addr);
  err_code = nrf_drv_ppi_channel_enable(spi_count_ppi_channel);
  //Start Sampling
  start();
  while(true) {
    nrfx_timer_capture(&count_timer, NRF_TIMER_CC_CHANNEL1);
    sample_buffer_count = nrfx_timer_capture_get(&count_timer, NRF_TIMER_CC_CHANNEL1);
    if(sample_buffer_count >= SAMPLES) {
      //Stop SPI
      nrf_drv_ppi_channel_disable(spi_sample_ppi_channel);
      //Reset counter timer
      nrfx_timer_clear(&count_timer);
      nrf_delay_ms(100);
      //Start Again
      start();
Jonathan
  • Maybe double check that it is the SPIM3 you are configuring, and readback the CSNDUR register before executing the SPI transfer to ensure it is set correctly.
    Kenneth
  • ss_duration = 2
    ss_duration = 64
    The idle time of SCK does change just not the idle time of CSN as per the screenshots above.
  • Seems like this is a error in the documentation. It should say:
    Delay between CSN low to first SCK edge and last SCK edge to CSN high. Also used as CSN high time between two transfers, but only when the short is enabled (END_START).
  • I have updated my code below to use short (END_START). But it the timing looks the same as with PPI.
    ss_duration = 2
    ss_duration = 64
    /** @file
    #include <stdint.h>
    //Nordic
    static void enable_continuous_spi() {
      spi.p_reg->SHORTS = 1 << 17;
    static void disable_continuous_spi() {
      spi.p_reg->SHORTS = 0;
      enable_continuous_spi();
      //Reset pointer
      //Count
      //Count PPI
      //Start Sampling
      start();
      while(true) {
          //Stop SPI
          disable_continuous_spi();
          nrf_delay_ms(100);
          //Start Again
          start();
  • I will have to create an internal jira for it, for now I suggest you add a application delay between SPI transfers to ensure a minimum delay.
    Kenneth
