Multiprotocol and radio RXIDLE state
Hi nrf51 developers,
I'm developing multiprotocol application by combining BLE and a proprietary protocol. I'm using concurrent multiprotocol timeslots API. Started with the ble_app_hrs_with_timeslot example. In that example timer0 generates interrupt, but I modified a little to generate radio interrupt.
My callback function is bellow
nrf_radio_signal_callback_return_param_t * m_radio_callback(uint8_t signal_type)
    switch(signal_type)
        case NRF_RADIO_CALLBACK_SIGNAL_TYPE_START:
            signal_callback_return_param.params.request.p_next = NULL;
            signal_callback_return_param.callback_action = NRF_RADIO_SIGNAL_CALLBACK_ACTION_NONE;
            radio_configure();
	    /* Enable interrupt on events */
	        NRF_RADIO->INTENSET = RADIO_INTENSET_ADDRESS_Msk | RADIO_INTENSET_DISABLED_Msk | RADIO_INTENSET_READY_Msk;
	   /* Enable RADIO interrupts */
	  		NVIC_ClearPendingIRQ(RADIO_IRQn);
			NVIC_EnableIRQ(RADIO_IRQn);
			NRF_RADIO->PACKETPTR = (uint32_t)&packet;
			NRF_RADIO->EVENTS_READY = 0U;
			/* Enable RX */
            NRF_RADIO->TASKS_RXEN = 1U;
            while (NRF_RADIO->EVENTS_READY == 0U)
                // **I DON'T UNDERSTAND WHY, IT ALWAYS STAYS HERE**
	       start_timer();
	    case NRF_RADIO_CALLBACK_SIGNAL_TYPE_RADIO:
		  //**NEVER COMES HERE**
    return (&signal_callback_return_param);
I tried to debug and figured out that it never goes to RXIDLE state and stays in a while loop (NRF_RADIO->EVENTS_READY == 0U), I cannot understand why.
I'd really appreciate, if someone could help me. Thanks in advance for your time,
Best regards, Gor
  • Hi Gor,
    For these things it is a good idea to debug using printf statements, as the SoftDevice may cause hanging when you step or stop the debugger.
    Note that if you want to recieve a packet you will want to do this as well after getting NRF_RADIO->EVENTS_READY:
        // Enable radio and wait for ready
            // wait
        NRF_RADIO->EVENTS_END = 0U;
        // Start listening and wait for address received event
        NRF_RADIO->TASKS_START = 1U;
        // Wait for end of packet or buttons state changed
        while (NRF_RADIO->EVENTS_END == 0U)
            // wait
        if (NRF_RADIO->CRCSTATUS == 1U)
            result = packet;
        NRF_RADIO->EVENTS_DISABLED = 0U;
        // Disable radio
        NRF_RADIO->TASKS_DISABLE = 1U;
        while (NRF_RADIO->EVENTS_DISABLED == 0U)
            // wait
    Øyvind
  • Hi Øyvind, Thanks for you response and advice. But my problem is that I'm not getting out of the while(NRF_RADIO->EVENTS_READY == 0U) {} loop. It seems that it never become 1U. If I understand timslots currectly, I assume my program should work in a following way. In one timeslot the m_radio_callback function should be called 3 times. First NRF_RADIO_CALLBACK_SIGNAL_TYPE_START Indicate start of the timeslot and wait for the interrupt, than radio interrupt should occur and it should go NRF_RADIO_CALLBACK_SIGNAL_TYPE_RADIO case statement and wait for the packages and when the timeslot time is done, timer interrupt should occur and NRF_RADIO_CALLBACK_SIGNAL_TYPE_TIMER0 brench should execute and request a new timeslot. My problem is that I'm not getting NRF_RADIO->EVENTS_READY. Please correct me if I'm thinking wrong way. Thanks again for your help.
    It might be that you have requested a timeslot that is too short, so that your application will not have time to finish. Could you post the configuration of the radio and the timeslot setup?
    Thanks for your response, Please find source code bellow.
    void m_configure_earliest_timeslot(void)
        m_timeslot_request.request_type                = NRF_RADIO_REQ_TYPE_EARLIEST;
        m_timeslot_request.params.earliest.hfclk       = NRF_RADIO_HFCLK_CFG_DEFAULT;
        m_timeslot_request.params.earliest.priority    = NRF_RADIO_PRIORITY_HIGH;
        m_timeslot_request.params.earliest.length_us   = 50000;
        m_timeslot_request.params.earliest.timeout_us  = 1000000;
    void m_configure_normal_timeslot(void)
        m_timeslot_request.request_type                = NRF_RADIO_REQ_TYPE_NORMAL;
        m_timeslot_request.params.normal.hfclk         = NRF_RADIO_HFCLK_CFG_DEFAULT;
        m_timeslot_request.params.normal.priority      = NRF_RADIO_PRIORITY_HIGH;
        m_timeslot_request.params.normal.length_us     = 50000;
        m_timeslot_request.params.normal.distance_us   = 1000000;
  • void read_packet(void)
            // wait
            // wait
        // Disable radio
            // wait
