Unable to build TF-M sample for nRF9160DK on Windows
Hi.
I've tried to build the TF-M Hello World sample using nRF Connect SDK and I get these two errors (which I think are related):
  • opening dependency file secure_fw\partitions\crypto\mbedcrypto\nrf_security_src\mbedtls\CMakeFiles\crypto_service_mbedcrypto_base_vanilla.dir\C_\Users\mario\ncs\v1.6.0\mbedtls\library\memory_buffer_alloc.o.d: No such file or directory
  • Combining ‘modules/trusted-firmware-m/CMakeFiles/tfm_cmake’
I hope it can be solved.
Thanks.
  • Hi.
    This is the log. I've highlighted the parts where I think the issue may reside:
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/aes.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/aesni.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/arc4.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/aria.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/asn1.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/asn1write.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/base64.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/bignum.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/blowfish.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/bn_mul.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/camellia.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/ccm.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/certs.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/chacha20.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/chachapoly.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/check_config.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/cipher.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/cipher_internal.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/cmac.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/compat-1.3.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/config.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/config_psa.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/ctr_drbg.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/debug.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/des.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/dhm.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/ecdh.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/ecdsa.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/ecjpake.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/ecp.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/ecp_internal.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/entropy.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/entropy_poll.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/error.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/gcm.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/havege.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/hkdf.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/hmac_drbg.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/md.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/md2.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/md4.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/md5.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/md_internal.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/memory_buffer_alloc.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/net.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/net_sockets.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/nist_kw.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/oid.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/padlock.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/pem.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/pk.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/pk_internal.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/pkcs11.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/pkcs12.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/pkcs5.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/platform.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/platform_time.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/platform_util.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/poly1305.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/psa_util.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/ripemd160.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/rsa.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/rsa_internal.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/sha1.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/sha256.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/sha512.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/ssl.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/ssl_cache.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/ssl_ciphersuites.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/ssl_cookie.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/ssl_internal.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/ssl_ticket.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/threading.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/timing.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/version.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/x509.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/x509_crl.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/x509_crt.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/x509_csr.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/include/mbedtls_copied/mbedtls/xtea.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/CMakeFiles/tfm_mbedtls_headers_copy’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/tfm_mbedtls_headers_copy’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_mbedcrypto_base_vanilla’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_mbedcrypto_oberon_noglue’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/src/objects/oberon.mon’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/oberon_extract’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/src/oberon_extract’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_mbedcrypto’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/trusted-firmware-m/CMakeFiles/tfm_cmake’ from solution ‘build’ in configuration ‘Common’
    1> Combining ‘modules/trusted-firmware-m/CMakeFiles/tfm_cmake’
    1> Start to generate PSA manifests:
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\secure_fw/partitions/protected_storage/psa_manifest/tfm_protected_storage.h
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\secure_fw/partitions/protected_storage/auto_generated/intermedia_tfm_protected_storage.c
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\secure_fw/partitions/internal_trusted_storage/psa_manifest/tfm_internal_trusted_storage.h
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\secure_fw/partitions/internal_trusted_storage/auto_generated/intermedia_tfm_internal_trusted_storage.c
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\secure_fw/partitions/audit_logging/psa_manifest/tfm_audit_logging.h
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\secure_fw/partitions/audit_logging/auto_generated/intermedia_tfm_audit_logging.c
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\secure_fw/partitions/crypto/psa_manifest/tfm_crypto.h
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\secure_fw/partitions/crypto/auto_generated/intermedia_tfm_crypto.c
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\secure_fw/partitions/platform/psa_manifest/tfm_platform.h
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\secure_fw/partitions/platform/auto_generated/intermedia_tfm_platform.c
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\secure_fw/partitions/initial_attestation/psa_manifest/tfm_initial_attestation.h
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\secure_fw/partitions/initial_attestation/auto_generated/intermedia_tfm_initial_attestation.c
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\test_services\tfm_core_test\psa_manifest\tfm_ss_core_test.h
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\test_services\tfm_core_test\auto_generated\intermedia_tfm_ss_core_test.c
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\test_services\tfm_core_test_2\psa_manifest\tfm_ss_core_test_2.h
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\test_services\tfm_core_test_2\auto_generated\intermedia_tfm_ss_core_test_2.c
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\test_services\tfm_secure_client_service\psa_manifest\tfm_secure_client_service.h
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\test_services\tfm_secure_client_service\auto_generated\intermedia_tfm_secure_client_service.c
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\test_services\tfm_ipc_service\psa_manifest\tfm_ipc_service_test.h
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\test_services\tfm_ipc_service\auto_generated\intermedia_tfm_ipc_service_test.c
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\test_services\tfm_ipc_client\psa_manifest\tfm_ipc_client_test.h
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\test_services\tfm_ipc_client\auto_generated\intermedia_tfm_ipc_client_test.c
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\test_services\tfm_irq_test_service_1\psa_manifest\tfm_irq_test_service_1.h
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\test_services\tfm_irq_test_service_1\auto_generated\intermedia_tfm_irq_test_service_1.c
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\test_services\tfm_ps_test_service\psa_manifest\tfm_ps_test_service.h
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\test_services\tfm_ps_test_service\auto_generated\intermedia_tfm_ps_test_service.c
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\test_services\tfm_secure_client_2\psa_manifest\tfm_secure_client_2.h
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\test_services\tfm_secure_client_2\auto_generated\intermedia_tfm_secure_client_2.c
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\secure_fw/partitions/psa_proxy/psa_manifest/tfm_psa_proxy.h
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\secure_fw/partitions/psa_proxy/auto_generated/intermedia_tfm_psa_proxy.c
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\secure_fw/partitions/firmware_update/psa_manifest/tfm_firmware_update.h
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\secure_fw/partitions/firmware_update/auto_generated/intermedia_tfm_firmware_update.c
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\secure_fw/partitions/tfm_ffm11_partition/psa_manifest/tfm_ffm11_partition.h
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\secure_fw/partitions/tfm_ffm11_partition/auto_generated/intermedia_tfm_ffm11_partition.c
    1> Start to generate file from the generated list:
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\secure_fw/spm/cmsis_func/tfm_spm_db_func.inc
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\secure_fw/spm/cmsis_psa/tfm_spm_db_ipc.inc
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\secure_fw/partitions/tfm_service_list.inc
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\secure_fw/spm/cmsis_func/tfm_veneers.c
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\interface/include/tfm_veneers.h
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\secure_fw/spm/cmsis_func/tfm_secure_irq_handlers.inc
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\secure_fw/spm/cmsis_psa/tfm_secure_irq_handlers_ipc.inc
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\interface/include/psa_manifest/sid.h
    1> Generating C:\ncs\v1.6.0\nrf\samples\tfm\tfm_hello_world\build_nrf9160dk_nrf9160ns\tfm\generated\interface/include/psa_manifest/pid.h
    1> Generation of files done
    1> CMake Warning (dev) at C:/ncs/v1.6.0/toolchain/opt/share/cmake-3.17/Modules/FindPackageHandleStandardArgs.cmake:272 (message):
    1> The package name passed to `find_package_handle_standard_args` (PY_M2R)
    1> does not match the name of the calling package (PythonModules). This can
    1> lead to problems in calling code that expects `find_package` result
    1> variables (e.g., `_FOUND`) to follow a certain pattern.
    1> Call Stack (most recent call first):
    1> cmake/FindPythonModules.cmake:60 (find_package_handle_standard_args)
    1> docs/CMakeLists.txt:14 (find_package)
    1> This warning is for project developers. Use -Wno-dev to suppress it.
    1>
    1> (PY_SPHINX-RTD-THEME) does not match the name of the calling package
    1> (PythonModules). This can lead to problems in calling code that expects
    1> `find_package` result variables (e.g., `_FOUND`) to follow a certain
    1> pattern.
    1>
    1> -- Can not find Python module m2r (missing: PY_M2R)
    1> (PY_SPHINXCONTRIB.PLANTUML) does not match the name of the calling package
    1> pattern.
    1>
    1> -- Can not find Python module sphinxcontrib.plantuml (missing: PY_SPHINXCONTRIB.PLANTUML)
    1> -- PLANTUML_JAR_PATH variable is missing, PlantUML jar location is unknown.
    1> -- Could NOT find Plantuml (missing: PLANTUML_JAR_PATH PLANTUML_VERSION)
    1> The package name passed to `find_package_handle_standard_args` (Plantuml)
    1> does not match the name of the calling package (PlantUML). This can lead
    1> to problems in calling code that expects `find_package` result variables
    1> (e.g., `_FOUND`) to follow a certain pattern.
    1> cmake/FindPlantUML.cmake:63 (find_package_handle_standard_args)
    1> docs/CMakeLists.txt:15 (find_package)
    1>
    1> -- Could NOT find Doxygen (missing: DOXYGEN_EXECUTABLE) (Required is at least version "1.8.0")
    1> -- Could NOT find LATEX (missing: LATEX_COMPILER PDFLATEX)
    1> -- ---------- Display crypto configuration - start --------------
    1> -- CRYPTO_RNG_MODULE_DISABLED is set to FALSE
    1> -- CRYPTO_KEY_MODULE_DISABLED is set to TRUE
    1> -- CRYPTO_AEAD_MODULE_DISABLED is set to TRUE
    1> -- CRYPTO_MAC_MODULE_DISABLED is set to TRUE
    1> -- CRYPTO_CIPHER_MODULE_DISABLED is set to TRUE
    1> -- CRYPTO_HASH_MODULE_DISABLED is set to FALSE
    1> -- CRYPTO_GENERATOR_MODULE_DISABLED is set to TRUE
    1> -- CRYPTO_ASYMMETRIC_MODULE_DISABLED is set to TRUE
    1> -- CRYPTO_ENGINE_BUF_SIZE is set to 0x2080
    1> -- CRYPTO_CONC_OPER_NUM is set to 8
    1> -- CRYPTO_IOVEC_BUFFER_SIZE is set to 5120
    1> -- ---------- Display crypto configuration - stop ---------------
    1> -- Configuring done
    1> CMake Warning in C:/ncs/v1.6.0/nrfxlib/nrf_security/src/mbedtls/CMakeLists.txt:
    1> The object file directory
    1>
    1> C:/ncs/v1.6.0/nrf/samples/tfm/tfm_hello_world/build_nrf9160dk_nrf9160ns/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/./
    1>
    1> has 196 characters. The maximum full path to an object file is 250
    1> characters (see CMAKE_OBJECT_PATH_MAX). Object file
    1>
    1> C_/ncs/v1.6.0/mbedtls/library/psa_crypto_driver_wrappers.o
    1>
    1> cannot be safely placed under this directory. The build may not work
    1> correctly.
    1>
    1>
    1> -- Generating done
    1> -- Build files have been written to: C:/ncs/v1.6.0/nrf/samples/tfm/tfm_hello_world/build_nrf9160dk_nrf9160ns/tfm
    Building ‘modules/trusted-firmware-m/tfm_cmake’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/trusted-firmware-m/tfm-prefix/src/tfm-stamp/tfm-mkdir’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/trusted-firmware-m/tfm-prefix/src/tfm-stamp/tfm-download’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/trusted-firmware-m/tfm-prefix/src/tfm-stamp/tfm-update’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/trusted-firmware-m/tfm-prefix/src/tfm-stamp/tfm-patch’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/trusted-firmware-m/tfm-prefix/src/tfm-stamp/tfm-configure’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/trusted-firmware-m/tfm-prefix/src/tfm-stamp/tfm-build’ from solution ‘build’ in configuration ‘Common’
    1> Combining ‘modules/trusted-firmware-m/tfm-prefix/src/tfm-stamp/tfm-build’
    1> [1/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/memory_buffer_alloc.o
    1> [2/96] Generating objects/cc3xx.mon
    1> [3/96] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/platform/tfm_platform_secure_api.o
    1> [4/96] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/crypto/tfm_crypto_secure_api.o
    1> [5/96] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_cipher.o
    1> [6/96] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_init.o
    1> [7/96] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_alloc.o
    1> [8/96] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_mac.o
    1> [9/96] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key.o
    1> [10/96] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_aead.o
    1> [11/96] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_asymmetric.o
    1> [12/96] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_hash.o
    1> [13/96] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key_derivation.o
    1> [14/96] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/generated/secure_fw/partitions/crypto/auto_generated/intermedia_tfm_crypto.o
    1> [15/96] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_rng.o
    1> [16/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/aesni.o
    1> [17/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/aria.o
    1> [18/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/arc4.o
    1> [19/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/asn1parse.o
    1> [20/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/asn1write.o
    1> [21/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/blowfish.o
    1> [22/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/cipher.o
    1> [23/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/bignum.o
    1> [24/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/base64.o
    1> [25/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/camellia.o
    1> [26/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/cipher_wrap.o
    1> [27/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/ctr_drbg.o
    1> [28/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/debug.o
    1> [29/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/gcm.o
    1> [30/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/entropy_poll.o
    1> [31/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/error.o
    1> [32/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/entropy.o
    1> [33/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/des.o
    1> [34/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/havege.o
    1> [35/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/md4.o
    1> [36/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/hkdf.o
    1> [37/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/hmac_drbg.o
    1> [38/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/oid.o
    1> [39/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/md5.o
    1> [40/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/md.o
    1> [41/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/md2.o
    1> [42/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/nist_kw.o
    1> [43/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/pk.o
    1> [44/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/pkwrite.o
    1> [45/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/padlock.o
    1> [46/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/pk_wrap.o
    1> [47/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/pkcs5.o
    1> [48/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/pkcs12.o
    1> [49/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/pkparse.o
    1> [50/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/timing.o
    1> [51/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/platform_util.o
    1> [52/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/platform.o
    1> [53/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/ripemd160.o
    1> [54/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/psa_crypto_slot_management.o
    1> [55/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/xtea.o
    1> [56/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/version.o
    1> [57/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/psa_crypto_client.o
    1> [58/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/psa_crypto.o
    1> [59/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/version_features.o
    1> [60/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/psa_crypto_driver_wrappers.o
    1> [61/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/replacements/pem.o
    1> [62/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/psa_crypto_storage.o
    1> [63/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/psa_crypto_ecp.o
    1> [64/96] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/mbedtls/CMakeFiles/crypto_service_mbedcrypto_base_vanilla.dir/C_/ncs/v1.6.0/mbedtls/library/psa_crypto_rsa.o
    1> [65/96] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/generated/secure_fw/partitions/platform/auto_generated/intermedia_tfm_platform.o
    1> [66/96] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/platform_sp.o
    1> [67/96] Building C object secure_fw/partitions/tfm_ffm11_partition/CMakeFiles/tfm_app_rot_partition_ffm11.dir/28a144f750d1c0613a1199394e6f3783/auto_generated/intermedia_tfm_ffm11_partition.o
    1> [68/96] Building C object secure_fw/partitions/tfm_ffm11_partition/CMakeFiles/tfm_app_rot_partition_ffm11.dir/tfm_ffm11_partition.o
    1> [69/96] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/tfm_boot_data.o
    1> [70/96] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/psa_client_service_apis.o
    1> [71/96] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/spm_ipc.o
    1> [72/96] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/tfm_core_svcalls_ipc.o
    1> [73/96] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/spm_psa_client_call.o
    1> [74/96] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/main.o
    1> [75/96] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/arch/tfm_arch_v8m_main.o
    1> [76/96] Linking C static library secure_fw\spm\libtfm_spm.a
    1> [77/96] Linking C static library secure_fw\partitions\tfm_ffm11_partition\libtfm_app_rot_partition_ffm11.a
    1> [78/96] Linking C static library secure_fw\partitions\platform\libtfm_psa_rot_partition_platform.a
    1> [79/96] Linking C static library secure_fw\partitions\crypto\mbedcrypto\nrf_security_src\libcrypto_service_mbedcrypto.a
    1> [80/96] Linking C static library secure_fw\partitions\crypto\libtfm_psa_rot_partition_crypto.a
    1> [81/96] Linking C static library secure_fw\partitions\lib\sprt\libtfm_sprt.a
    1> [82/96] Linking C executable bin\tfm_s.axf
    1> Memory region Used Size Region Size %age Used
    1> FLASH: 32 KB 32 KB 100.00%
    1> RAM: 41680 B 64 KB 63.60%
    1> [83/96] Generating ../bin/tfm_s.hex
    1> [84/96] Generating ../bin/tfm_s.elf
    1> [85/96] Generating ../bin/tfm_s.bin
    1> [86/96] Linking C static library secure_fw\libtfm_s_veneers.a
    1> [87/96] Building C object app/CMakeFiles/tfm_api_ns.dir/C_/ncs/v1.6.0/modules/tee/tfm/trusted-firmware-m/interface/src/tfm_initial_attestation_ipc_api.o
    1> [88/96] Building C object app/CMakeFiles/tfm_api_ns.dir/C_/ncs/v1.6.0/modules/tee/tfm/trusted-firmware-m/interface/src/tfm_platform_ipc_api.o
    1> [89/96] Building C object app/CMakeFiles/tfm_api_ns.dir/C_/ncs/v1.6.0/modules/tee/tfm/trusted-firmware-m/interface/src/tfm_ps_ipc_api.o
    1> [90/96] Building C object app/CMakeFiles/tfm_api_ns.dir/C_/ncs/v1.6.0/modules/tee/tfm/trusted-firmware-m/interface/src/tfm_its_ipc_api.o
    1> [91/96] Building C object app/CMakeFiles/tfm_api_ns.dir/C_/ncs/v1.6.0/modules/tee/tfm/trusted-firmware-m/interface/src/tfm_crypto_ipc_api.o
    1> [92/96] Linking C static library app\libtfm_api_ns.a
    1> [93/96] Linking C executable bin\tfm_ns.axf
    1> FLASH: 10800 B 992 KB 1.06%
    1> RAM: 14080 B 192 KB 7.16%
    1> [94/96] Generating ../bin/tfm_ns.bin
    1> [95/96] Generating ../bin/tfm_ns.elf
    1> [96/96] Generating ../bin/tfm_ns.hex
    Building ‘modules/trusted-firmware-m/tfm-prefix/src/tfm-stamp/tfm-install’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/trusted-firmware-m/CMakeFiles/tfm-complete’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/trusted-firmware-m/CMakeFiles/tfm’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/trusted-firmware-m/tfm-prefix/src/tfm-stamp/tfm-done’ from solution ‘build’ in configuration ‘Common’
    Building ‘tfm/secure_fw/s_veneers.o’ from solution ‘build’ in configuration ‘Common’
    Building ‘tfm/app/libtfm_api_ns.a’ from solution ‘build’ in configuration ‘Common’
    Building ‘tfm/generated/interface/include/psa_manifest/sid.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘tfm/platform/libplatform_ns.a’ from solution ‘build’ in configuration ‘Common’
    Building ‘tfm/bin/tfm_s.bin’ from solution ‘build’ in configuration ‘Common’
    Building ‘tfm/bin/tfm_s.hex’ from solution ‘build’ in configuration ‘Common’
    Building ‘tfm/bin/tfm_ns.bin’ from solution ‘build’ in configuration ‘Common’
    Building ‘tfm/bin/tfm_ns.hex’ from solution ‘build’ in configuration ‘Common’
    Building ‘tfm/bin/tfm_s_signed.bin’ from solution ‘build’ in configuration ‘Common’
    Building ‘tfm/bin/tfm_ns_signed.bin’ from solution ‘build’ in configuration ‘Common’
    Building ‘tfm/bin/tfm_s_ns_signed.bin’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/trusted-firmware-m/tfm’ from solution ‘build’ in configuration ‘Common’
    Building ‘C:/ncs/v1.6.0/zephyr/include/dt-bindings/gpio/gpio.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘C:/ncs/v1.6.0/zephyr/include/dt-bindings/i2c/i2c.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/misc/generated/syscalls.json’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/misc/generated/struct_tags.json’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/parse_syscalls_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/parse_syscalls_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/driver-validation.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/kobj-types-enum.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/otype-to-str.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/otype-to-size.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/syscall_list.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/syscall_dispatch.c’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_offsets’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/mbedcrypto_base_vanilla’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/oberon/mbedcrypto_oberon_noglue’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/src/libmbedcrypto.a’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/offsets’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/offsets.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/offsets_h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/offsets_h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/zephyr_generated_headers’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_app’ from solution ‘build’ in configuration ‘Common’
    Building ‘app/libapp.a’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/tfm_primary.hex’ from solution ‘build’ in configuration ‘Common’
    1> Combining ‘zephyr/tfm_primary.hex’
    Building ‘CMakeFiles/tfm_primary_hex’ from solution ‘build’ in configuration ‘Common’
    Building ‘tfm_primary_hex’ from solution ‘build’ in configuration ‘Common’
    Building ‘C:/ncs/v1.6.0/zephyr/misc/empty_file.c’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_..__nrf__lib__fatal_error’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_arch__arm__core__aarch32’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_arch__arm__core__aarch32__cortex_m’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_arch__arm__core__aarch32__cortex_m__cmse’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_arch__arm__core__aarch32__mpu’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_isr_tables’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_arch__common’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_boards__arm__nrf9160dk_nrf9160’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_drivers__entropy’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_drivers__gpio’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_drivers__serial’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_kernel’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_lib__libc__minimal’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_lib__posix’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_mbedtls_zephyr’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_modules__hal_nordic__nrfx’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_soc__arm__common__cortex_m’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_subsys__random’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_tfm_api’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_zephyr’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/linker_zephyr_prebuilt.cmd’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/linker_zephyr_prebuilt_script_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/linker_zephyr_prebuilt_script_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_zephyr_prebuilt’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/libzephyr.a’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/arch/common/libisr_tables.a’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/arch/common/libarch__common.a’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/lib/libc/minimal/liblib__libc__minimal.a’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/lib/posix/liblib__posix.a’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/boards/boards/arm/nrf9160dk_nrf9160ns/libboards__arm__nrf9160dk_nrf9160.a’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/subsys/random/libsubsys__random.a’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/drivers/gpio/libdrivers__gpio.a’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/drivers/serial/libdrivers__serial.a’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/drivers/entropy/libdrivers__entropy.a’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/trusted-firmware-m/libtfm_api.a’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/src/zephyr/libmbedtls_zephyr.a’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/kernel/libkernel.a’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/zephyr_prebuilt.elf’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/linker.cmd’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/linker_zephyr_final_script_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/linker_zephyr_final_script_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/dev_handles.c’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/isrList.bin’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/isr_tables.c’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_zephyr_final’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/zephyr.elf’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/zephyr.hex’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/app_primary.hex’ from solution ‘build’ in configuration ‘Common’
    Building ‘CMakeFiles/app_primary_hex’ from solution ‘build’ in configuration ‘Common’
    Building ‘app_primary_hex’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/merged.hex’ from solution ‘build’ in configuration ‘Common’
    1> Combining ‘zephyr/merged.hex’
    Building ‘CMakeFiles/merged_hex’ from solution ‘build’ in configuration ‘Common’
    Building ‘merged_hex’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/arch/common/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/arch/arch/arm/core/aarch32/cortex_m/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/arch/arch/arm/core/aarch32/cortex_m/tz/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/arch/arch/arm/core/aarch32/mpu/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/arch/arch/arm/core/aarch32/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/arch/arch/arm/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/arch/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/lib/libc/minimal/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/lib/libc/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/lib/posix/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/lib/gui/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/lib/os/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/lib/util/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/lib/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/soc/arm/common/cortex_m/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/soc/arm/nordic_nrf/nrf91/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/soc/arm/nordic_nrf/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/soc/arm/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/boards/boards/arm/nrf9160dk_nrf9160ns/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/boards/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/subsys/debug/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/subsys/logging/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/subsys/fs/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/subsys/ipc/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/subsys/mgmt/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/subsys/random/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/subsys/storage/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/subsys/fb/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/subsys/portability/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/subsys/pm/policy/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/subsys/pm/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/subsys/stats/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/subsys/task_wdt/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/subsys/testsuite/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/subsys/tracing/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/subsys/canbus/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/subsys/modbus/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/subsys/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/drivers/console/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/drivers/interrupt_controller/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/drivers/misc/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/drivers/pcie/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/drivers/disk/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/drivers/clock_control/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/drivers/gpio/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/drivers/serial/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/drivers/entropy/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/drivers/timer/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/drivers/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/ext/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/lib/bin/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/lib/flash_patch/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/lib/fatal_error/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/lib/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/samples/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/subsys/net/lib/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/subsys/net/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/subsys/dfu/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/subsys/nonsecure/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/subsys/debug/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/subsys/partition_manager/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/subsys/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/modules/tfm/zephyr/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/modules/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/drivers/hw_cc310/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/drivers/entropy/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/drivers/gps/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/drivers/serial/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/drivers/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/tests/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/openthread/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/mcuboot/boot/bootutil/zephyr/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/mcuboot/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/trusted-firmware-m/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/cjson/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/pelion-dm/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/cddl-gen/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/memfault-firmware-sdk/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/cmsis/CMSIS/Core/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/cmsis/CMSIS/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/cmsis/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/canopennode/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/civetweb/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/fatfs/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/hal_nordic/nrfx/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/hal_nordic/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/st/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/libmetal/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/lvgl/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/mbedtls/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/mcumgr/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/open-amp/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/loramac-node/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/segger/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/tinycbor/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/tinycrypt/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/littlefs/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/mipi-sys-t/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf_hw_models/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/TraceRecorder/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/crypto/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/shared/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/oberon/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/src/zephyr/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/src/psa/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/src/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrf_802154/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/connectedhomeip/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/kernel/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/cmake/flash/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/cmake/usage/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/cmake/reports/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/all’ from solution ‘build’ in configuration ‘Common’
    Building ‘all’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/merged.hex’ from solution ‘tfm_hello_world’ in configuration ‘Common’
    Build complete
    Best regards.
    Most of those are warnings, and I do not think you need to worry about them. The only thing that might cause problems is this part:
    1>
    1>
    1>
    1>
    1> correctly.
    This happens because the path is too long, as the error states. You can solve this by shortening the name of the build directory to "build" instead of "build_nrf9160dk_nrf9160ns". This will make the path short enough to not get this error.
    Marte
  • Hi.
    I tried shortening the path and the issue seems to be solved. There are only the other warnings. Thank you very much for your support.
