Hello Community,
I downloaded SUPL library of version 0.7.0, my ncs version is v1.5.1.
I have changed following in prj.conf
CONFIG_SUPL_CLIENT_LIB=y
I am using NB-IoT network of vodafone so I changed XSYSTEMMODE and also enabled legacy PCO using XEPCO.
#define AT_XSYSTEMMODE "AT\%XSYSTEMMODE=0,1,1,0"
#define AT_DEACTIVATE_XEPCO "AT\%XEPCO=0"
static const char *const at_commands[] = {
AT_XSYSTEMMODE,
#if defined(CONFIG_BOARD_NRF9160DK_NRF9160NS) || \
defined(CONFIG_BOARD_THINGY91_NRF9160NS)
//AT_MAGPIO,
AT_COEX0,
AT_DEACTIVATE_XEPCO, //Disable extended PCO for NB-IoT use
AT_ACTIVATE_GPS
*** Booting Zephyr OS build v2.4.99-ncs2 *** Starting GPS application GPS Socket created Getting GPS data... Tracking: 0 Using: 0 Unhealthy: 0 --------------------------------- Seconds since last fix: 0 Searching [|] NMEA strings: ---------------------------------Tracking: 0 Using: 0 Unhealthy: 0 --------------------------------- Seconds since last fix: 0 Searching [/] NMEA strings: ---------------------------------New AGPS data requested, contacting SUPL server, flags 59 Unable to connect, errno 116 Starting SUPL session ULP encoding length: 38 Sending SUPL message failed, bytes_sent: -1 SUPL session internal resources released Done Failed to close SUPL socket Tracking: 0 Using: 0 Unhealthy: 0 --------------------------------- Seconds since last fix: 42 Searching [-] NMEA strings: $GPGGA,000002.00,,,,,0,,99.99,,M,0,,*35 $GPGLL,,,,,000002.00,V,A*47 $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D ---------------------------------Tracking: 1 Using: 0 Unhealthy: 0 --------------------------------- Seconds since last fix: 43 Searching [\] NMEA strings: $GPGGA,000003.00,,,,,0,01,99.99,,M,0,,*35 $GPGLL,,,,,000003.00,V,A*46 $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D $GPGSV,1,1,1,21,,,37,1*52 $GPRMC,000003.00,V,,,,,,,060180,,,N,V*0B ---------------------------------Tracking: 1 Using: 0 Unhealthy: 0 --------------------------------- Seconds since last fix: 43 Searching [|] NMEA strings: $GPGGA,000004.00,,,,,0,01,99.99,,M,0,,*32 $GPGLL,,,,,000004.00,V,A*41 $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D $GPGSV,1,1,1,21,,,39,1*5C $GPRMC,000004.00,V,,,,,,,060180,,,N,V*0C ---------------------------------Tracking: 1 Using: 0 Unhealthy: 0 --------------------------------- Seconds since last fix: 44 Searching [/] NMEA strings: $GPGGA,000004.00,,,,,0,01,99.99,,M,0,,*32 $GPGLL,,,,,000004.00,V,A*41 $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D $GPGSV,1,1,1,21,,,39,1*5C $GPRMC,000004.00,V,,,,,,,060180,,,N,V*0C
The signal quality also good here.
It seems it is not downloading data and gives timeout error.
Anyone can suggest me how can I remove error?
Thanks in advanceg
The code did build successfully, but it shows following error,
