I am currently developing an application around the CAF BLE state and advertising components.
My setup consists of a nRF9160DK that uses the nRF52840 onboard for BLE.
The components themselves work mostly OK, but I run into a problem with the following assertion found in ble_state.c:367:
BUILD_ASSERT(!IS_ENABLED(CONFIG_BT_PERIPHERAL) || (ARRAY_SIZE(active_conn) == 1));
My application does the following two things:
- Advertise so that a device can connect
- Be a central so that I can scan for advertising packets from other BLE sensors. I will never connect, I just need to be able to parse the advertisement data.
So in my prj.conf I have the following lines:
# # Copyright (c) 2019 Nordic Semiconductor ASA # # SPDX-License-Identifier: LicenseRef-Nordic-5-Clause # # General config CONFIG_NEWLIB_LIBC=y CONFIG_ASSERT=y CONFIG_REBOOT=y # Enable Bluetooth stack and libraries CONFIG_BT=y #CONFIG_BT_GATT_CLIENT=y #CONFIG_BT_GATT_DM=y #CONFIG_BT_LL_SOFTDEVICE=y # Bluetooth general settings CONFIG_BT_DIS=y # device information service CONFIG_BT_SMP=y CONFIG_BT_MAX_CONN=2 CONFIG_BT_MAX_PAIRED=4 # Bluetooth appearance CONFIG_BT_PERIPHERAL=y CONFIG_BT_DEVICE_NAME="nRF Device" CONFIG_BT_DEVICE_APPEARANCE=1856 # Enable bonding # CONFIG_BT_SETTINGS=y # CONFIG_FLASH=y # CONFIG_FLASH_PAGE_LAYOUT=y # CONFIG_FLASH_MAP=y # CONFIG_NVS=y # CONFIG_SETTINGS=y # CONFIG_SETTINGS_NVS=y # Enable the BMS service CONFIG_BT_BMS=y # Heap and stacks CONFIG_HEAP_MEM_POOL_SIZE=65536 CONFIG_MAIN_STACK_SIZE=65536 # Configuration required by Event Manager CONFIG_EVENT_MANAGER=y CONFIG_LINKER_ORPHAN_SECTION_PLACE=y CONFIG_REBOOT=y ## Config related to CAF (common application framework) CONFIG_CAF=y CONFIG_CAF_BLE_STATE=y # CONFIG_CAF_BLE_BOND_SUPPORTED=y # CAF BLE ADVERTISING CONFIG_CAF_BLE_ADV=y CONFIG_CAF_BLE_ADV_DEF_PATH="ble_adv_def.h" #CONFIG_CAF_BLE_ADV_PM_EVENTS=y CONFIG_CAF_BLE_ADV_DIRECT_ADV=n CONFIG_CAF_BLE_ADV_FAST_ADV=y # CAF debug CONFIG_CAF_BLE_ADV_LOG_LEVEL_DBG=y CONFIG_CAF_BLE_STATE_LOG_LEVEL_DBG=y ## Logger configuration CONFIG_LOG=y CONFIG_LOG_DEFAULT_LEVEL=4 CONFIG_LOG_BACKEND_UART=y CONFIG_LOG_STRDUP_BUF_COUNT=10 CONFIG_BOOT_BANNER=n ## HC-SR04 CONFIG_SENSOR=y CONFIG_GPIO=y CONFIG_HC_SR04=y # ultrasonic service, CONFIG_BT_L2CAP_TX_BUF_COUNT needed? CONFIG_BT_L2CAP_TX_BUF_COUNT=5 # Required for Bluetooth HCI to external nRF52840 CONFIG_NRF_SW_LPUART=y CONFIG_NRF_SW_LPUART_INT_DRIVEN=y CONFIG_UART_2_ASYNC=y CONFIG_UART_2_INTERRUPT_DRIVEN=n CONFIG_UART_2_NRF_HW_ASYNC=y CONFIG_UART_2_NRF_HW_ASYNC_TIMER=2 CONFIG_BT_H4=y CONFIG_BT_WAIT_NOP=y CONFIG_BT_GATT_CLIENT=y CONFIG_BT_GATT_DM=y CONFIG_UART_INTERRUPT_DRIVEN=y # ultrasonic service, CONFIG_BT_L2CAP_TX_BUF_COUNT needed? CONFIG_BT_L2CAP_TX_BUF_COUNT=5 # Enable scanning CONFIG_BT_SCAN=y CONFIG_BT_CENTRAL=y CONFIG_BT_GATT_CLIENT=y # Allow for bigger packets to include all TPMS in one packet CONFIG_BT_USER_DATA_LEN_UPDATE=y CONFIG_BT_L2CAP_TX_MTU=253 CONFIG_BT_BUF_CMD_TX_SIZE=255 CONFIG_BT_BUF_ACL_RX_SIZE=251
Since I have both CONFIG_BT_PERIPHERAL and CONFIG_BT_CENTRAL, zephyr requies CONFIG_BT_MAX_CONN to be at least 2, I guess because it reserves a connection for the internal central as well? Although from the peripheral point of view I only require one 'connection' to an external central at a time.
Is there a way around this build assert or am I stuck?
I have uncommented the lines from ble_state.c and now the application 'works' but I doubt this is the right way.
Stef
