PPK2 strange current reporting after DUT goes into low power state
Hello!
I am starting to profile our device using the PPK2 and I am seeing some strange measurements when the device goes into its low power mode.
I'm attaching an image of what I mean:
The dense set of "spikes" at the end of the capture don't seem to correspond to anything in my system.
If I DON'T have the device go into its low power mode the capture looks like:
I am assuming the auto-ranging is struggling in this case, as the device moves from the mA range to 1-2uA in the low power state.
Is there something I can try to do to get rid of the "spikes" the current probe is reporting?
Bonus question:
Are the sample duration limits in the Power Profiler app set by some constraint in the PPK2 hardware or just the amount of RAM the host PC has to spare?  I have seen how I can modify the JS of the Power Profiler app to increase the sample duration's but I'm not confident enough to really try using it.
Thank you so much!
Cheers,
Devin
  • Attaching the ppk of the same capture here now!
    I'm not sure why but every time I tried to upload the file with the .ppk extension it would fail with this error:
    {"jsonrpc":"2.0", "error": {"code":101, "message":"The file's name could not be determined.  The file cannot be accepted."}, "id":"id"}
    As such I am uploading it with the .csv extension which DOES seem to be working.  When you download it you will need to rename it with the proper .ppk extension.
    MeasurementWithJunk_ppk.csv
    Thank you!
  • Hi
    Thank you. I've reported that DevZone is not able to upload .ppk files. Thank you for providing the error message. I have reported this issue internally.
    As for the PPK trace, I had one of the PPK developers take a look at it, and he does indeed seem to think that this is one of the switches causing this current consumption. You can also see that the measurements between these 700uA spikes are all the way to 0, indicating that there are some negative currents as well. These samples are not to be trusted I'm afraid. Our recommendation is to ignore these measurements, as the sleep current seems to run as expected after this "noisy period". Unfortunately, this is the greatest weakness of the PPK2, as the bandwidth does not support the switching occurring here.
    Simon
  • Thank you so much for looking into it!  Its not a problem for us at the end of the day and I'm relieved I don't have to go track down whatever could be consuming current like that!  The PPK2 is still doing a fantastic job for us over all.
    Cheers!
    Devin
