PPK2 strange current reporting after DUT goes into low power state
Hello!
I am starting to profile our device using the PPK2 and I am seeing some strange measurements when the device goes into its low power mode.
I'm attaching an image of what I mean:
The dense set of "spikes" at the end of the capture don't seem to correspond to anything in my system.
If I DON'T have the device go into its low power mode the capture looks like:
I am assuming the auto-ranging is struggling in this case, as the device moves from the mA range to 1-2uA in the low power state.
Is there something I can try to do to get rid of the "spikes" the current probe is reporting?
Bonus question:
Are the sample duration limits in the Power Profiler app set by some constraint in the PPK2 hardware or just the amount of RAM the host PC has to spare?  I have seen how I can modify the JS of the Power Profiler app to increase the sample duration's but I'm not confident enough to really try using it.
Thank you so much!
Cheers,
Devin
  • Hi Devin
    Due to the summer vacation period here in Norway we are short on staff and delayed replies must be expected. I'm sorry for any inconvenience this might cause.
    This behavior seems strange indeed. First off, are you measuring in Source meter mode or Ampere meter mode? If you're in Source meter mode, make sure that the source output voltage is set to a value suitable for your device. Can you also provide some details on how exactly you go into "low power mode"? Are you going into System OFF mode, or in an idle system ON mode of some kind?
    Depending on the sampling rate you'd like, you can increase the sample duration up to 500 days as explained in this YouTube video. We can't guarantee the behavior if you start modifying the JS yourself, but there shouldn't be any restrictions in the HW keeping you from setting this sample period yourself.
    Simon
  • Hey Simon,
    Thank you for the response!
    The PPK is configured as an ampere meter for this setup.
    The supply being measured in this instance is a 3V regulated supply that we use as VDD_GPIO for the nrf9160, as well as VCC for the other microcontrollers we have on our design.  The microcontroller turning on in this instance is an MSP430 which is being put into its low power mode.  That is done manually in its firmware and is indicated by the digital pin 7 going "low" in the capture.
  • Hi again
    Thank you! We've not seen this issue on our side before, there might be one of the switches that are struggling indeed. With the PPK2 it's possible to export the Power Profiler data as a file (see the video in my last reply). Can you do so and upload it here so we could analyze this "noisy part" on our side? I know there is a switch at ~50µA, but if the MSP430 is steady below this, it should be fine.
    Simon
  • I have a .csv showing off the capture here now.  I am not 100% convinced the excess consumption isn't from something else waking up on our device, but the signature of the "spiky" current is very different from everything else I have seen.
    Let me know if I can try to capture something else!
    MeasurementWithJunk.csv
  • Sorry, could you save it as a ".ppk" file instead, as I'd like to take a look at it in the Power Profiler app on my end.
    Simon
