Unable to store scene on nRF Mesh App
I'm developing a multi-scene application by reference to the "Light switch" example in nRF SDK for Mesh 5.0. The first screenshot show my Elements & Models structrue.
The Scene (Setup) Server works fine in Element 0, but when I try to store scene in Scene Setup Server in Element 1,  it failed without debug terminal ouput.
I have no idea what to do.
Regards.
  • Hei Charmin,
    Could you check if there is any log on the nRF52 ?
    I suspect that it crashed for some reasons. Please check if there is any assertion ? Did it disconnect with the phone ?
  • /* Copyright (c) 2010 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
     * list of conditions and the following disclaimer.
    #include <stdint.h>
    #include <string.h>
    /* HAL */
    #include "boards.h"
    #include "simple_hal.h"
    #include "app_timer.h"
    /* Core */
    #include "nrf_mesh_config_core.h"
    #include "nrf_mesh_gatt.h"
    #include "nrf_mesh_configure.h"
    #include "nrf_mesh_events.h"
    #include "nrf_mesh.h"
    #include "mesh_stack.h"
    #include "device_state_manager.h"
    #include "access_config.h"
    #include "proxy.h"
    /* Provisioning and configuration */
    #include "mesh_provisionee.h"
    #include "mesh_app_utils.h"
    /* Models */
    #include "generic_onoff_server.h"
    #include "scene_setup_server.h"
    #include "model_config_file.h"
    //#include "simple_on_off_server.h"
    /* Logging and RTT */
    #include "log.h"
    #include "rtt_input.h"
    /* Example specific includes */
    #include "app_config.h"
    #include "example_common.h"
    #include "nrf_mesh_config_examples.h"
    #include "light_switch_example_common.h"
    #include "app_onoff.h"
    #include "ble_softdevice_support.h"
    #include "app_dtt.h"
    #include "app_scene.h"
     * Definitions
    #define ONOFF_SERVER_0_LED          (BSP_LED_0)
    #define ONOFF_SERVER_1_LED          (BSP_LED_1)
    #define APP_ONOFF_ELEMENT_INDEX     (0)
    /* Controls if the model instance should force all mesh messages to be segmented messages. */
    #define APP_FORCE_SEGMENTATION      (false)
    /* Controls the MIC size used by the model instance for sending the mesh messages. */
    #define APP_MIC_SIZE                (NRF_MESH_TRANSMIC_SIZE_SMALL)
     * Forward declaration of static functions
    static void mesh_events_handle(const nrf_mesh_evt_t * p_evt);
    static void app_onoff_server_set_cb(const app_onoff_server_t * p_server, bool onoff);
    static void app_onoff_server_get_cb(const app_onoff_server_t * p_server, bool * p_present_onoff);
    static void app_onoff_server_set_cb1(const app_onoff_server_t * p_server, bool onoff);
    static void app_onoff_server_get_cb1(const app_onoff_server_t * p_server, bool * p_present_onoff);
    static void app_onoff_server_transition_cb(const app_onoff_server_t * p_server,
                                                    uint32_t transition_time_ms, bool target_onoff);
    #if SCENE_SETUP_SERVER_INSTANCES_MAX > 0
    static void app_onoff_scene_transition_cb(const app_scene_setup_server_t * p_app,
                                              uint16_t target_scene);
     * Static variables
    static bool m_device_provisioned;
    static nrf_mesh_evt_handler_t m_event_handler =
        .evt_cb = mesh_events_handle,
    /* Defaut Transition Time server structure definition and initialization */
    APP_DTT_SERVER_DEF(m_dtt_server_0,
                       APP_FORCE_SEGMENTATION,
                       APP_MIC_SIZE,
                       NULL)
    APP_DTT_SERVER_DEF(m_dtt_server_1,
                       APP_MIC_SIZE,
                       NULL)
    /* Scene Setup server structure definition and initialization */
    APP_SCENE_SETUP_SERVER_DEF(m_scene_server_0,
                               APP_MIC_SIZE,
                               app_onoff_scene_transition_cb,
                               &m_dtt_server_0.server)
    APP_SCENE_SETUP_SERVER_DEF(m_scene_server_1,
                               APP_MIC_SIZE,
                               &m_dtt_server_1.server)
    /* Generic OnOff server structure definition and initialization */
    APP_ONOFF_SERVER_DEF(m_onoff_server_0,
                         APP_MIC_SIZE,
                         app_onoff_server_set_cb,
                         app_onoff_server_get_cb,
                         app_onoff_server_transition_cb)
    APP_ONOFF_SERVER_DEF(m_onoff_server_1,
                         APP_MIC_SIZE,
                         app_onoff_server_set_cb1,
                         app_onoff_server_get_cb1,
    /* Callback for updating the hardware state */
        /* Resolve the server instance here if required, this example uses only 1 instance. */
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Setting GPIO value: %d\n", onoff)
        hal_led_pin_set(ONOFF_SERVER_0_LED, onoff);
        hal_led_pin_set(ONOFF_SERVER_1_LED, onoff);
    /* Callback for reading the hardware state */
        *p_present_onoff = hal_led_pin_get(ONOFF_SERVER_0_LED);
        *p_present_onoff = hal_led_pin_get(ONOFF_SERVER_1_LED);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Transition time: %d, Target OnOff: %d\n",
                                           transition_time_ms, target_onoff);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Transition time: %d, Target Scene: %d\n",
                                           transition_time_ms, target_scene);
    static void app_model_init(void)
        /* Instantiate onoff server on element index APP_ONOFF_ELEMENT_INDEX */
        ERROR_CHECK(app_onoff_init(&m_onoff_server_0, APP_ONOFF_ELEMENT_INDEX));
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "App OnOff Model Handle: %d\n", m_onoff_server_0.server.model_handle);
        ERROR_CHECK(app_onoff_init(&m_onoff_server_1, 1));
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "App OnOff Model Handle: %d\n", m_onoff_server_1.server.model_handle);
        /* Instantiate Generic Default Transition Time server as needed by Scene models */
        ERROR_CHECK(app_dtt_init(&m_dtt_server_0, APP_ONOFF_ELEMENT_INDEX));
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "App DTT Model Handle: %d\n", m_dtt_server_0.server.model_handle);
        ERROR_CHECK(app_dtt_init(&m_dtt_server_1, 1));
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "App DTT Model Handle: %d\n", m_dtt_server_1.server.model_handle);
        /* Instantiate scene server and register onoff server to have scene support */
        ERROR_CHECK(app_scene_model_init(&m_scene_server_0, APP_ONOFF_ELEMENT_INDEX));
        ERROR_CHECK(app_scene_model_add(&m_scene_server_0, &m_onoff_server_0.scene_if));
        ERROR_CHECK(app_onoff_scene_context_set(&m_onoff_server_0, &m_scene_server_0));
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "App Scene Model Handle: %d\n", m_scene_server_0.scene_setup_server.model_handle);
        ERROR_CHECK(app_scene_model_init(&m_scene_server_1, 1));
        ERROR_CHECK(app_scene_model_add(&m_scene_server_1, &m_onoff_server_1.scene_if));
        ERROR_CHECK(app_onoff_scene_context_set(&m_onoff_server_1, &m_scene_server_1));
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "App Scene Model Handle: %d\n", m_scene_server_1.scene_setup_server.model_handle);
        if (p_evt->type == NRF_MESH_EVT_ENABLED)
            APP_ERROR_CHECK(app_onoff_value_restore(&m_onoff_server_0));
    static void node_reset(void)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- Node reset  -----\n");
        model_config_file_clear();
        hal_led_blink_ms(HAL_LED_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_RESET);
        /* This function may return if there are ongoing flash operations. */
        mesh_stack_device_reset();
    static void config_server_evt_cb(const config_server_evt_t * p_evt)
        if (p_evt->type == CONFIG_SERVER_EVT_NODE_RESET)
            node_reset();
    #if NRF_MESH_LOG_ENABLE
    static const char m_usage_string[] =
        "\n"
        "\t\t-------------------------------------------------------------------------------\n"
        "\t\t Button/RTT 1) LED state will toggle and inform clients about the state change.\n"
        "\t\t Button/RTT 4) Clear all the states to reset the node.\n"
        "\t\t-------------------------------------------------------------------------------\n";
    static void button_event_handler(uint32_t button_number)
        /* Increase button number because the buttons on the board is marked with 1 to 4 */
        button_number++;
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Button %u pressed\n", button_number);
        switch (button_number)
            /* Pressing SW1 on the Development Kit will result in LED state to toggle and trigger
            the STATUS message to inform client about the state change. This is a demonstration of
            state change publication due to local event. */
            case 1:
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "User action \n");
                hal_led_pin_set(ONOFF_SERVER_0_LED, !hal_led_pin_get(ONOFF_SERVER_0_LED));
                app_onoff_status_publish(&m_onoff_server_0);
            /* Initiate node reset */
            case 4:
                /* Clear all the states to reset the node. */
                if (mesh_stack_is_device_provisioned())
    #if MESH_FEATURE_GATT_PROXY_ENABLED
                    (void) proxy_stop();
                    mesh_stack_config_clear();
                    node_reset();
                    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "The device is unprovisioned. Resetting has no effect.\n");
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, m_usage_string);
    static void app_rtt_input_handler(int key)
        if (key >= '1' && key <= '4')
            uint32_t button_number = key - '1';
            button_event_handler(button_number);
    static void device_identification_start_cb(uint8_t attention_duration_s)
        hal_led_mask_set(HAL_LED_MASK, false);
        hal_led_blink_ms(HAL_LED_MASK_HALF,
                         LED_BLINK_ATTENTION_INTERVAL_MS,
                         LED_BLINK_ATTENTION_COUNT(attention_duration_s));
    static void provisioning_aborted_cb(void)
        hal_led_blink_stop();
    static void unicast_address_print(void)
        dsm_local_unicast_address_t node_address;
        dsm_local_unicast_addresses_get(&node_address);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Node Address: 0x%04x \n", node_address.address_start);
    static void provisioning_complete_cb(void)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Successfully provisioned\n");
    #if MESH_FEATURE_GATT_ENABLED
        /* Restores the application parameters after switching from the Provisioning
         * service to the Proxy  */
        gap_params_init();
        conn_params_init();
        unicast_address_print();
        hal_led_mask_set(HAL_LED_MASK, LED_MASK_STATE_OFF);
        hal_led_blink_ms(HAL_LED_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_PROV);
    static void models_init_cb(void)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Initializing and adding models\n");
        app_model_init();
    static void mesh_init(void)
        /* Initialize the application storage for models */
        model_config_file_init();
        mesh_stack_init_params_t init_params =
            .core.irq_priority       = NRF_MESH_IRQ_PRIORITY_LOWEST,
            .core.lfclksrc           = DEV_BOARD_LF_CLK_CFG,
            .core.p_uuid             = NULL,
            .models.models_init_cb   = models_init_cb,
            .models.config_server_cb = config_server_evt_cb
        uint32_t status = mesh_stack_init(&init_params, &m_device_provisioned);
        if (status == NRF_SUCCESS)
            /* Check if application stored data is valid, if not clear all data and use default values. */
            status = model_config_file_config_apply();
        switch (status)
            case NRF_ERROR_INVALID_DATA:
                /* Clear model config file as loading failed */
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Data in the persistent memory was corrupted. Device starts as unprovisioned.\n");
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Reboot device before starting of the provisioning process.\n");
            case NRF_SUCCESS:
                ERROR_CHECK(status);
    static void initialize(void)
        __LOG_INIT(LOG_SRC_APP | LOG_SRC_FRIEND, LOG_LEVEL_DBG1, LOG_CALLBACK_DEFAULT);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- BLE Mesh Light Switch Server Demo -----\n");
        ERROR_CHECK(app_timer_init());
        hal_leds_init();
    #if BUTTON_BOARD
        ERROR_CHECK(hal_buttons_init(button_event_handler));
        ble_stack_init();
        gap_params_init();
        conn_params_init();
        mesh_init();
    static void start(void)
        rtt_input_enable(app_rtt_input_handler, RTT_INPUT_POLL_PERIOD_MS);
        if (!m_device_provisioned)
            static const uint8_t static_auth_data[NRF_MESH_KEY_SIZE] = STATIC_AUTH_DATA;
            mesh_provisionee_start_params_t prov_start_params =
                .p_static_data    = static_auth_data,
                .prov_sd_ble_opt_set_cb = NULL,
                .prov_complete_cb = provisioning_complete_cb,
                .prov_device_identification_start_cb = device_identification_start_cb,
                .prov_device_identification_stop_cb = NULL,
                .prov_abort_cb = provisioning_aborted_cb,
                .p_device_uri = EX_URI_LS_SERVER
            ERROR_CHECK(mesh_provisionee_prov_start(&prov_start_params));
        mesh_app_uuid_print(nrf_mesh_configure_device_uuid_get());
        /* NRF_MESH_EVT_ENABLED is triggered in the mesh IRQ context after the stack is fully enabled.
         * This event is used to call Model APIs for establishing bindings and publish a model state information. */
        nrf_mesh_evt_handler_add(&m_event_handler);
        ERROR_CHECK(mesh_stack_start());
        hal_led_mask_set(HAL_LED_MASK_UPPER_HALF, LED_MASK_STATE_OFF);
        hal_led_blink_ms(HAL_LED_MASK_UPPER_HALF, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_START);
        initialize();
        start();
        for (;;)
            (void)sd_app_evt_wait();
    Sir,
    There is no log output when storing scene. The phone is always connected to the device. I have attached main.c file.
  • 8686.nrf_mesh_config_app.h
    Here's another file I modified, They are located in "...\nrf5_SDK_for_Mesh_v5.0.0_src\examples\light_switch\server\".
  • Hi Charmin,
    Thanks for the project. I have compiled and run the firmware here. I didn't see the Operation time out issue that you have. Please see the attached screen recording.
    Please try to test again on a nRF52 DK.
    However, we have another issue that the stored scene is not showed up when click on the Scene Setup Server on Element #2. I am checking with the developer to see if it's a bug in the app.
  • Sir,
    The "Time out" issue no longer occurs somehow.
    But I entounted the same issue you mentioned.
    Moreover, the stored scene cannot be read on Scene Server on the second Element.
