porting softdevice s140 for nrf52811
hello!
im using sdk 17.0.2 with softdevice s112 in our customized board as i want to work for long range mode,so i need extended advertisement  ie no available in s112 so i need pca10056e ble app blincky example work with soft device s140 if you have any ported example that would be helpful.
thanks & regards
siva
  • CHANGE THE BELOW SETTINGS ,THEN WE CAN ABLE TO USE PCA10056 FOR NRF52811.
    diff --git a/pca10056e/s140/config/sdk_config.h b/pca10056e/s140/config/sdk_config.h
    index 0d7d106..62dbdcd 100644
    --- a/pca10056e/s140/config/sdk_config.h
    +++ b/pca10056e/s140/config/sdk_config.h
    @@ -2788,7 +2788,7 @@
    // <e> NRFX_PRS_ENABLED - nrfx_prs - Peripheral Resource Sharing module
    #ifndef NRFX_PRS_ENABLED
    -#define NRFX_PRS_ENABLED 1
    +#define NRFX_PRS_ENABLED 0
    // <q> NRFX_PRS_BOX_0_ENABLED - Enables box 0 in the module.
    @@ -6124,7 +6124,7 @@
    #ifndef UART_LEGACY_SUPPORT
    -#define UART_LEGACY_SUPPORT 1
    +#define UART_LEGACY_SUPPORT 0
    // <e> UART0_ENABLED - Enable UART0 instance
    @@ -6138,14 +6138,6 @@
    #ifndef UART0_CONFIG_USE_EASY_DMA
    #define UART0_CONFIG_USE_EASY_DMA 1
    -// </e>
    -// <e> UART1_ENABLED - Enable UART1 instance
    -#ifndef UART1_ENABLED
    -#define UART1_ENABLED 0
    -#endif
    // </e>
    // </e>
    diff --git a/pca10056e/s140/ses/ble_app_uart_c_pca10056e_s140.emProject b/pca10056e/s140/ses/ble_app_uart_c_pca10056e_s140.emProject
    index f24198e..62b0392 100644
    --- a/pca10056e/s140/ses/ble_app_uart_c_pca10056e_s140.emProject
    +++ b/pca10056e/s140/ses/ble_app_uart_c_pca10056e_s140.emProject
    @@ -1,41 +1,41 @@
    <!DOCTYPE CrossStudio_Project_File>
    -<solution Name="ble_app_uart_c_pca10056_s140" target="8" version="2">
    - <project Name="ble_app_uart_c_pca10056_s140">
    +<solution Name="ble_app_uart_c_pca10056e_s140" target="8" version="2">
    + <project Name="ble_app_uart_c_pca10056e_s140">
    <configuration
    Name="Common"
    arm_architecture="v7EM"
    arm_core_type="Cortex-M4"
    arm_endian="Little"
    - arm_fp_abi="Hard"
    - arm_fpu_type="FPv4-SP-D16"
    - arm_linker_heap_size="8192"
    + arm_fp_abi="Soft"
    + arm_fpu_type="Soft"
    + arm_linker_heap_size="2048"
    arm_linker_process_stack_size="0"
    - arm_linker_stack_size="8192"
    + arm_linker_stack_size="2048"
    arm_linker_treat_warnings_as_errors="No"
    arm_simulator_memory_simulation_parameter="RWX 00000000,00100000,FFFFFFFF;RWX 20000000,00010000,CDCDCDCD"
    - arm_target_device_name="nRF52840_xxAA"
    + arm_target_device_name="nRF52811_xxAA"
    arm_target_interface_type="SWD"
    + c_preprocessor_definitions="APP_TIMER_V2;APP_TIMER_V2_RTC1_ENABLED;BOARD_PCA10056;DEVELOP_IN_NRF52840;NRFX_COREDEP_DELAY_US_LOOP_CYCLES=3;CONFIG_GPIO_AS_PINRESET;FLOAT_ABI_SOFT;INITIALIZE_USER_SECTIONS;NO_VTOR_CONFIG;NRF52811_XXAA;NRF_SD_BLE_API_VERSION=7;S140;SOFTDEVICE_PRESENT;"
    c_user_include_directories="../../../config;../../../../../../components;../../../../../../components/ble/ble_advertising;../../../../../../components/ble/ble_db_discovery;../../../../../../components/ble/ble_dtm;../../../../../../components/ble/ble_racp;../../../../../../components/ble/ble_services/ble_ancs_c;../../../../../../components/ble/ble_services/ble_ans_c;../../../../../../components/ble/ble_services/ble_bas;../../../../../../components/ble/ble_services/ble_bas_c;../../../../../../components/ble/ble_services/ble_cscs;../../../../../../components/ble/ble_services/ble_cts_c;../../../../../../components/ble/ble_services/ble_dfu;../../../../../../components/ble/ble_services/ble_dis;../../../../../../components/ble/ble_services/ble_gls;../../../../../../components/ble/ble_services/ble_hids;../../../../../../components/ble/ble_services/ble_hrs;../../../../../../components/ble/ble_services/ble_hrs_c;../../../../../../components/ble/ble_services/ble_hts;../../../../../../components/ble/ble_services/ble_ias;../../../../../../components/ble/ble_services/ble_ias_c;../../../../../../components/ble/ble_services/ble_lbs;../../../../../../components/ble/ble_services/ble_lbs_c;../../../../../../components/ble/ble_services/ble_lls;../../../../../../components/ble/ble_services/ble_nus;../../../../../../components/ble/ble_services/ble_nus_c;../../../../../../components/ble/ble_services/ble_rscs;../../../../../../components/ble/ble_services/ble_rscs_c;../../../../../../components/ble/ble_services/ble_tps;../../../../../../components/ble/common;../../../../../../components/ble/nrf_ble_gatt;../../../../../../components/ble/nrf_ble_gq;../../../../../../components/ble/nrf_ble_qwr;../../../../../../components/ble/nrf_ble_scan;../../../../../../components/ble/peer_manager;../../../../../../components/boards;../../../../../../components/libraries/atomic;../../../../../../components/libraries/atomic_fifo;../../../../../../components/libraries/balloc;../../../../../../components/libraries/bootloader/ble_dfu;../../../../../../components/libraries/bsp;../../../../../../components/libraries/button;../../../../../../components/libraries/cli;../../../../../../components/libraries/crc16;../../../../../../components/libraries/crc32;../../../../../../components/libraries/crypto;../../../../../../components/libraries/csense;../../../../../../components/libraries/csense_drv;../../../../../../components/libraries/delay;../../../../../../components/libraries/ecc;../../../../../../components/libraries/experimental_section_vars;../../../../../../components/libraries/experimental_task_manager;../../../../../../components/libraries/fds;../../../../../../components/libraries/fifo;../../../../../../components/libraries/fstorage;../../../../../../components/libraries/gfx;../../../../../../components/libraries/gpiote;../../../../../../components/libraries/hardfault;../../../../../../components/libraries/hci;../../../../../../components/libraries/led_softblink;../../../../../../components/libraries/log;../../../../../../components/libraries/log/src;../../../../../../components/libraries/low_power_pwm;../../../../../../components/libraries/mem_manager;../../../../../../components/libraries/memobj;../../../../../../components/libraries/mpu;../../../../../../components/libraries/mutex;../../../../../../components/libraries/pwm;../../../../../../components/libraries/pwr_mgmt;../../../../../../components/libraries/queue;../../../../../../components/libraries/ringbuf;../../../../../../components/libraries/scheduler;../../../../../../components/libraries/sdcard;../../../../../../components/libraries/slip;../../../../../../components/libraries/sortlist;../../../../../../components/libraries/spi_mngr;../../../../../../components/libraries/stack_guard;../../../../../../components/libraries/strerror;../../../../../../components/libraries/svc;../../../../../../components/libraries/timer;../../../../../../components/libraries/twi_mngr;../../../../../../components/libraries/twi_sensor;../../../../../../components/libraries/uart;../../../../../../components/libraries/usbd;../../../../../../components/libraries/usbd/class/audio;../../../../../../components/libraries/usbd/class/cdc;../../../../../../components/libraries/usbd/class/cdc/acm;../../../../../../components/libraries/usbd/class/hid;../../../../../../components/libraries/usbd/class/hid/generic;../../../../../../components/libraries/usbd/class/hid/kbd;../../../../../../components/libraries/usbd/class/hid/mouse;../../../../../../components/libraries/usbd/class/msc;../../../../../../components/libraries/util;../../../../../../components/nfc/ndef/conn_hand_parser;../../../../../../components/nfc/ndef/conn_hand_parser/ac_rec_parser;../../../../../../components/nfc/ndef/conn_hand_parser/ble_oob_advdata_parser;../../../../../../components/nfc/ndef/conn_hand_parser/le_oob_rec_parser;../../../../../../components/nfc/ndef/connection_handover/ac_rec;../../../../../../components/nfc/ndef/connection_handover/ble_oob_advdata;../../../../../../components/nfc/ndef/connection_handover/ble_pair_lib;../../../../../../components/nfc/ndef/connection_handover/ble_pair_msg;../../../../../../components/nfc/ndef/connection_handover/common;../../../../../../components/nfc/ndef/connection_handover/ep_oob_rec;../../../../../../components/nfc/ndef/connection_handover/hs_rec;../../../../../../components/nfc/ndef/connection_handover/le_oob_rec;../../../../../../components/nfc/ndef/generic/message;../../../../../../components/nfc/ndef/generic/record;../../../../../../components/nfc/ndef/launchapp;../../../../../../components/nfc/ndef/parser/message;../../../../../../components/nfc/ndef/parser/record;../../../../../../components/nfc/ndef/text;../../../../../../components/nfc/ndef/uri;../../../../../../components/nfc/platform;../../../../../../components/nfc/t2t_lib;../../../../../../components/nfc/t2t_parser;../../../../../../components/nfc/t4t_lib;../../../../../../components/nfc/t4t_parser/apdu;../../../../../../components/nfc/t4t_parser/cc_file;../../../../../../components/nfc/t4t_parser/hl_detection_procedure;../../../../../../components/nfc/t4t_parser/tlv;../../../../../../components/softdevice/common;../../../../../../components/softdevice/s140/headers;../../../../../../components/softdevice/s140/headers/nrf52;../../../../../../components/toolchain/cmsis/include;../../../../../../external/fprintf;../../../../../../external/segger_rtt;../../../../../../external/utf_converter;../../../../../../integration/nrfx;../../../../../../integration/nrfx/legacy;../../../../../../modules/nrfx;../../../../../../modules/nrfx/drivers/include;../../../../../../modules/nrfx/hal;../../../../../../modules/nrfx/mdk;../config;"
    - c_preprocessor_definitions="APP_TIMER_V2;APP_TIMER_V2_RTC1_ENABLED;BOARD_PCA10056;CONFIG_GPIO_AS_PINRESET;FLOAT_ABI_HARD;INITIALIZE_USER_SECTIONS;NO_VTOR_CONFIG;NRF52840_XXAA;NRF_SD_BLE_API_VERSION=7;S140;SOFTDEVICE_PRESENT;"
    - debug_target_connection="J-Link"
    - gcc_entry_point="Reset_Handler"
    - macros="CMSIS_CONFIG_TOOL=../../../../../../external_tools/cmsisconfig/CMSIS_Configuration_Wizard.jar"
    - debug_register_definition_file="../../../../../../modules/nrfx/mdk/nrf52840.svd"
    debug_additional_load_file="../../../../../../components/softdevice/s140/hex/s140_nrf52_7.2.0_softdevice.hex"
    + debug_register_definition_file="../../../../../../modules/nrfx/mdk/nrf52811.svd"
    debug_start_from_entry_point_symbol="No"
    - gcc_debugging_level="Level 3" linker_output_format="hex"
    - linker_printf_width_precision_supported="Yes"
    + debug_target_connection="J-Link"
    + gcc_debugging_level="Level 3"
    + gcc_entry_point="Reset_Handler"
    + linker_output_format="hex"
    linker_printf_fmt_level="long"
    + linker_printf_width_precision_supported="Yes"
    linker_scanf_fmt_level="long"
    linker_section_placement_file="flash_placement.xml"
    - linker_section_placement_macros="FLASH_PH_START=0x0;FLASH_PH_SIZE=0x100000;RAM_PH_START=0x20000000;RAM_PH_SIZE=0x40000;FLASH_START=0x27000;FLASH_SIZE=0xd9000;RAM_START=0x20002a38;RAM_SIZE=0x3d5c8"
    - linker_section_placements_segments="FLASH RX 0x0 0x100000;RAM1 RWX 0x20000000 0x40000"
    + linker_section_placement_macros="FLASH_PH_START=0x0;FLASH_PH_SIZE=0x30000;RAM_PH_START=0x20000000;RAM_PH_SIZE=0x6000;FLASH_START=0x27000;FLASH_SIZE=0x9000;RAM_START=0x20002a38;RAM_SIZE=0x35c8"
    + linker_section_placements_segments="FLASH RX 0x0 0x30000;RAM1 RWX 0x20000000 0x6000"
    + macros="CMSIS_CONFIG_TOOL=../../../../../../external_tools/cmsisconfig/CMSIS_Configuration_Wizard.jar"
    project_directory=""
    project_type="Executable" />
    - <folder Name="Segger Startup Files">
    - <file file_name="$(StudioDir)/source/thumb_crt0.s" />
    - </folder>
    + <folder Name="Segger Startup Files">
    + <file file_name="$(StudioDir)/source/thumb_crt0.s" />
    + </folder>
    <folder Name="nRF_Log">
    <file file_name="../../../../../../components/libraries/log/src/nrf_log_backend_rtt.c" />
    <file file_name="../../../../../../components/libraries/log/src/nrf_log_backend_serial.c" />
    @@ -71,9 +71,9 @@
    <file file_name="../../../../../../components/libraries/uart/retarget.c" />
    </folder>
    <folder Name="None">
    - <file file_name="../../../../../../modules/nrfx/mdk/ses_startup_nrf52840.s" />
    + <file file_name="../../../../../../modules/nrfx/mdk/ses_startup_nrf52811.s" />
    <file file_name="../../../../../../modules/nrfx/mdk/ses_startup_nrf_common.s" />
    - <file file_name="../../../../../../modules/nrfx/mdk/system_nrf52840.c" />
    + <file file_name="../../../../../../modules/nrfx/mdk/system_nrf52811.c" />
    </folder>
    <folder Name="Board Definition">
    <file file_name="../../../../../../components/boards/boards.c" />
    @@ -84,7 +84,6 @@
    <file file_name="../../../../../../modules/nrfx/soc/nrfx_atomic.c" />
    <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_clock.c" />
    <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_gpiote.c" />
    - <file file_name="../../../../../../modules/nrfx/drivers/src/prs/nrfx_prs.c" />
    <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_uart.c" />
    <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_uarte.c" />
    </folder>
    @@ -121,11 +120,13 @@
    <file file_name="../../../../../../components/softdevice/common/nrf_sdh_soc.c" />
    </folder>
    </project>
    - <configuration Name="Release"
    + <configuration
    + Name="Release"
    c_preprocessor_definitions="NDEBUG"
    - link_time_optimization="No" gcc_optimization_level="Optimize For Size" />
    - <configuration Name="Debug"
    + gcc_optimization_level="Optimize For Size"
    + link_time_optimization="No" />
    + <configuration
    + Name="Debug"
    c_preprocessor_definitions="DEBUG; DEBUG_NRF"
    - gcc_optimization_level="None"/>
    + gcc_optimization_level="None" />
    </solution>
