Writing the simplest possible implementation of buttonless dfu
I'm trying to integrate buttonless dfu to our project. We don't have any security concerns and given the existing project constraints, it's not desirable to use peer_manager and power_management (which uses app_timer....) libraries. We don't use bonding. So the use case looks pretty simple.
We'd like to be able to perform OTA DFUs using nordic secure bootloader and nrfconnect app. So I'd like to implement a simpler dfu service which could work with secure bootloader and nrfconnect.
Regarding power_management library, it looked that its only use was in the ble_dfu_buttonless_bootloader_start_finalize() function in ble_dfu.c. Hence it seems easily replaceable with the following code snippet :
NRF_LOG_INFO("Shutdown complete.");
NRF_LOG_FINAL_FLUSH();
NVIC_SystemReset();
The main interrogations come from peer_manager and nrf_dfu_ble_svci_bond_sharing.h ... I disabled bond support as mentioned at https://infocenter.nordicsemi.com/index.jsp?topic=%2Fsdk_nrf5_v17.0.2%2Fservice_dfu.html&cp=7_1_3_3_5_6&anchor=secure_dfu_buttonless_app and tried to dfu without peer manager (which seems not to be used for unbonded dfu). It failed.
To get it work I had to (at least) initialize peer manager. I say at least because I didn't initialize svci interface at all by calling ble_dfu_buttonless_async_svci_init() and it was sufficient to get buttonless dfu work.
Could you please explain a bit deeper what is absolutely needed to make my minimal implementation of unbonded dfu service ?
***EDIT*** I'm using nRF5 SDK 17.0.2 with softdevice s140_nrf52_7.2.0 on a nRF52840 devkit
Hugo
    The absolute simplest way is to ensure that the bootloader is built with NRF_BL_DFU_ENTER_METHOD_GPREGRET set to 1 in it's  sdk_config.h and then write to GPREGRET and reset as explained in this post from the application to enter DFU mode.
    Note that this is only possible when not using bonding, and it will not be possible to set a different advertising name which is useful for iOS as the (API does not expose the BLE address). With this approach there is no dependency on peer manager at all, or anything else for that matter.
  • Thanks you for confirming my guesses :) I have an almost working simplified version of buttonless dfu now.
    So the only issue I'm experiencing now is a BLE relative one :
    Once I trigger DFU through nrfconnect desktop app, I can't do anything on the buttonless service characteristics. As a result the DFU can't be triggered.
    This happens when I remove peer manager initialization (from the buttonless template app) :
    static void peer_manager_init()
        ret_code_t           err_code;
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
        err_code                 = pm_sec_params_set(&sec_param);
    I believe it's a security matter regarding the characteristic configuration... However I didn't touch the original code from ble_dfu_unbonded.c :
    uint32_t ble_dfu_buttonless_char_add(ble_dfu_buttonless_t *p_dfu)
        ble_add_char_params_t add_char_params;
        memset(&add_char_params, 0, sizeof(add_char_params));
        add_char_params.uuid                = BLE_DFU_BUTTONLESS_CHAR_UUID;
        add_char_params.uuid_type           = p_dfu->uuid_type;
        add_char_params.char_props.indicate = 1;
        add_char_params.char_props.write    = 1;
        add_char_params.is_defered_write    = true;
        add_char_params.is_var_len          = true;
        add_char_params.max_len             = BLE_GATT_ATT_MTU_DEFAULT;
        add_char_params.cccd_write_access   = SEC_OPEN;
        add_char_params.write_access        = SEC_OPEN;
        add_char_params.read_access         = SEC_OPEN;
        return characteristic_add(p_dfu->service_handle, &add_char_params, &p_dfu->control_point_char);
    What's the relationship between the peer manager configuration and the buttonless dfu's characteristic behaviour ?
    Should I adjust some settings in ble_dfu_buttonless_char_add() ?
    Best regards
    Hugo
  • Hi Hugo,
    If you want to use the buttonless DFU BLE service, then I suggest using it as it is demonstrated by the Buttonless DFU Template Application. As long as NRF_DFU_BLE_BUTTONLESS_SUPPORTS_BONDS is set to 0 this does not use any bond sharing with the bootloader. The example application itself relies on the peer manager, but that can be removed here, as it has no use with buttonless DFU.
    The advantage of using the approach of the example and buttonless DFU service implementation is that you get the support for setting advertising name, which is important in order to get a good user experience with iOS. This is used by the nRF Connect apps etc to filter on the correct device while scanning to connect again to the device after it enters DFU mode. (you can search for DFU_OP_SET_ADV_NAME in ble_dfu_unbonded.c to see how this is used). In this case SVCI is used not do share bonding information, but to set the device name.
    Einar
  • I just tried removing calls to peer_manager_init() in the buttonless dfu template application, configured with NRF_DFU_BLE_BUTTONLESS_SUPPORTS_BONDS set to 0 as you suggested.
    It leads to the same result as with my simplified buttonless dfu service -> I can't do anything on the buttonless service characteristics. As a result the DFU can't be triggered.
    I'm really stuck on this...
    I suspect you are seeing a general problem when removing the peer manager, which is that you need to add handling of a few events in your code that is otherwise handled by the peer manager. Specifically, you should add this in your handling of BLE events:
                // Pairing not supported
    I tested by modifying the SDK 17.0.2 ble_app_buttonless_dfu example by setting PEER_MANAGER_ENABLED to 0 in sdk_config.h and adding the code snippet from above and removing everything related to peer manager and pairing/bonding:
     * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
    /** @example examples/ble_peripheral/ble_app_buttonless_dfu
     * @brief Secure DFU Buttonless Service Application main file.
     * This file contains the source code for a sample application using the proprietary
     * Secure DFU Buttonless Service. This is a template application that can be modified
     * to your needs. To extend the functionality of this application, please find
     * locations where the comment "// YOUR_JOB:" is present and read the comments.
    #include <stdbool.h>
    #include <stdint.h>
    #include <string.h>
    #include "nrf_dfu_ble_svci_bond_sharing.h"
    #include "nrf_svci_async_function.h"
    #include "nrf_svci_async_handler.h"
    #include "nordic_common.h"
    #include "nrf.h"
    #include "app_error.h"
    #include "ble.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "app_timer.h"
    #include "bsp_btn_ble.h"
    #include "ble_conn_state.h"
    #include "ble_dfu.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "fds.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_drv_clock.h"
    #include "nrf_power.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_bootloader_info.h"
    #define DEVICE_NAME                     "Nordic_Buttonless"                         /**< Name of device. Will be included in the advertising data. */
    #define MANUFACTURER_NAME               "NordicSemiconductor"                       /**< Manufacturer. Will be passed to Device Information Service. */
    #define APP_ADV_INTERVAL                300                                         /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)            /**< Minimum acceptable connection interval (0.1 seconds). */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)            /**< Maximum acceptable connection interval (0.2 second). */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                            /**< Handle of the current connection. */
    static void advertising_start();                                                    /**< Forward declaration of advertising start function */
    // YOUR_JOB: Use UUIDs for service(s) used in your application.
    static ble_uuid_t m_adv_uuids[] = {{BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}};
    /**@brief Handler for shutdown preparation.
     * @details During shutdown procedures, this function will be called at a 1 second interval
     *          untill the function returns true. When the function returns true, it means that the
     *          app is ready to reset to DFU mode.
     * @param[in]   event   Power manager event.
     * @retval  True if shutdown is allowed by this power manager handler, otherwise false.
    static bool app_shutdown_handler(nrf_pwr_mgmt_evt_t event)
        switch (event)
            case NRF_PWR_MGMT_EVT_PREPARE_DFU:
                NRF_LOG_INFO("Power management wants to reset to DFU mode.");
                // YOUR_JOB: Get ready to reset into DFU mode
                // If you aren't finished with any ongoing tasks, return "false" to
                // signal to the system that reset is impossible at this stage.
                // Here is an example using a variable to delay resetting the device.
                // if (!m_ready_for_reset)
                //      return false;
                // else
                //    // Device ready to enter
                //    uint32_t err_code;
                //    err_code = sd_softdevice_disable();
                //    APP_ERROR_CHECK(err_code);
                //    err_code = app_timer_stop_all();
                // YOUR_JOB: Implement any of the other events available from the power management module:
                //      -NRF_PWR_MGMT_EVT_PREPARE_SYSOFF
                //      -NRF_PWR_MGMT_EVT_PREPARE_WAKEUP
                //      -NRF_PWR_MGMT_EVT_PREPARE_RESET
                return true;
        NRF_LOG_INFO("Power management allowed to reset to DFU mode.");
        return true;
    //lint -esym(528, m_app_shutdown_handler)
    /**@brief Register application shutdown handler with priority 0.
    NRF_PWR_MGMT_HANDLER_REGISTER(app_shutdown_handler, 0);
    static void buttonless_dfu_sdh_state_observer(nrf_sdh_state_evt_t state, void * p_context)
        if (state == NRF_SDH_EVT_STATE_DISABLED)
            // Softdevice was disabled before going into reset. Inform bootloader to skip CRC on next boot.
            nrf_power_gpregret2_set(BOOTLOADER_DFU_SKIP_CRC);
            //Go to system off.
            nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
    /* nrf_sdh state observer. */
    NRF_SDH_STATE_OBSERVER(m_buttonless_dfu_state_obs, 0) =
        .handler = buttonless_dfu_sdh_state_observer,
    static void advertising_config_get(ble_adv_modes_config_t * p_config)
        memset(p_config, 0, sizeof(ble_adv_modes_config_t));
        p_config->ble_adv_fast_enabled  = true;
        p_config->ble_adv_fast_interval = APP_ADV_INTERVAL;
        p_config->ble_adv_fast_timeout  = APP_ADV_DURATION;
    static void disconnect(uint16_t conn_handle, void * p_context)
        UNUSED_PARAMETER(p_context);
        ret_code_t err_code = sd_ble_gap_disconnect(conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        if (err_code != NRF_SUCCESS)
            NRF_LOG_WARNING("Failed to disconnect connection. Connection handle: %d Error: %d", conn_handle, err_code);
            NRF_LOG_DEBUG("Disconnected connection handle %d", conn_handle);
    // YOUR_JOB: Update this code if you want to do anything given a DFU event (optional).
    /**@brief Function for handling dfu events from the Buttonless Secure DFU service
     * @param[in]   event   Event from the Buttonless Secure DFU service.
    static void ble_dfu_evt_handler(ble_dfu_buttonless_evt_type_t event)
        switch (event)
            case BLE_DFU_EVT_BOOTLOADER_ENTER_PREPARE:
                NRF_LOG_INFO("Device is preparing to enter bootloader mode.");
                // Prevent device from advertising on disconnect.
                ble_adv_modes_config_t config;
                advertising_config_get(&config);
                config.ble_adv_on_disconnect_disabled = true;
                ble_advertising_modes_config_set(&m_advertising, &config);
                // Disconnect all other bonded devices that currently are connected.
                // This is required to receive a service changed indication
                // on bootup after a successful (or aborted) Device Firmware Update.
                uint32_t conn_count = ble_conn_state_for_each_connected(disconnect, NULL);
                NRF_LOG_INFO("Disconnected %d links.", conn_count);
            case BLE_DFU_EVT_BOOTLOADER_ENTER:
                // YOUR_JOB: Write app-specific unwritten data to FLASH, control finalization of this
                //           by delaying reset by reporting false in app_shutdown_handler
                NRF_LOG_INFO("Device will enter bootloader mode.");
            case BLE_DFU_EVT_BOOTLOADER_ENTER_FAILED:
                NRF_LOG_ERROR("Request to enter bootloader mode failed asynchroneously.");
                // YOUR_JOB: Take corrective measures to resolve the issue
                //           like calling APP_ERROR_CHECK to reset the device.
            case BLE_DFU_EVT_RESPONSE_SEND_ERROR:
                NRF_LOG_ERROR("Request to send a response to client failed.");
                APP_ERROR_CHECK(false);
                NRF_LOG_ERROR("Unknown event from ble_dfu_buttonless.");
    /**@brief Callback function for asserts in the SoftDevice.
     * @param[in] line_num   Line number of the failing ASSERT call.
     * @param[in] file_name  File name of the failing ASSERT call.
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module. This creates and starts application timers.
    static void timers_init(void)
        // Initialize timer module.
        uint32_t err_code = app_timer_init();
        // Create timers.
        /* YOUR_JOB: Create any timers to be used by the application.
                     Below is an example of how to create a timer.
                     For every new timer needed, increase the value of the macro APP_TIMER_MAX_TIMERS by
                     one.
           uint32_t err_code;
           err_code = app_timer_create(&m_app_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler);
           APP_ERROR_CHECK(err_code); */
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
        uint32_t                err_code;
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
        /* YOUR_JOB: Use an appearance value matching the application's use case.
           err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_);
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the YYY Service events.
     * YOUR_JOB implement a service handler function depending on the event the service you are using can generate
     * @details This function will be called for all YY Service events which are passed to
     *          the application.
     * @param[in]   p_yy_service   YY Service structure.
     * @param[in]   p_evt          Event received from the YY Service.
       static void on_yys_evt(ble_yy_service_t     * p_yy_service,
                              ble_yy_service_evt_t * p_evt)
        switch (p_evt->evt_type)
            case BLE_YY_NAME_EVT_WRITE:
                APPL_LOG("[APPL]: charact written with value %s. ", p_evt->params.char_xx.value.p_str);
                // No implementation needed.
        uint32_t                  err_code;
        nrf_ble_qwr_init_t        qwr_init  = {0};
        ble_dfu_buttonless_init_t dfus_init = {0};
        dfus_init.evt_handler = ble_dfu_evt_handler;
        err_code = ble_dfu_buttonless_init(&dfus_init);
        /* YOUR_JOB: Add code to initialize the services used by the application.
           uint32_t                           err_code;
           ble_xxs_init_t                     xxs_init;
           ble_yys_init_t                     yys_init;
           // Initialize XXX Service.
           memset(&xxs_init, 0, sizeof(xxs_init));
           xxs_init.evt_handler                = NULL;
           xxs_init.is_xxx_notify_supported    = true;
           xxs_init.ble_xx_initial_value.level = 100;
           err_code = ble_bas_init(&m_xxs, &xxs_init);
           // Initialize YYY Service.
           memset(&yys_init, 0, sizeof(yys_init));
           yys_init.evt_handler                  = on_yys_evt;
           yys_init.ble_yy_initial_value.counter = 0;
           err_code = ble_yy_service_init(&yys_init, &yy_init);
    /**@brief Function for handling the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module which
     *          are passed to the application.
     *          @note All this function does is to disconnect. This could have been done by simply
     *                setting the disconnect_on_fail config parameter, but instead we use the event
     *                handler mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling a Connection Parameters error.
    /**@brief Function for starting timers.
    static void application_timers_start(void)
        /* YOUR_JOB: Start your timers. below is an example of how to start a timer.
           uint32_t err_code;
           err_code = app_timer_start(m_app_timer_id, TIMER_INTERVAL, NULL);
        // Prepare wakeup buttons.
        //Disable SoftDevice. It is required to be able to write to GPREGRET2 register (SoftDevice API blocks it).
        //GPREGRET2 register holds the information about skipping CRC check on next boot.
        err_code = nrf_sdh_disable_request();
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code = NRF_SUCCESS;
            case BLE_GAP_EVT_CONNECTED:
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
        uint32_t ram_start = 0;
        // Enable BLE stack.
     * @param[in]   event   Event generated when button is pressed.
    static void bsp_event_handler(bsp_event_t event)
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
                break; // BSP_EVENT_SLEEP
            case BSP_EVENT_DISCONNECT:
                break; // BSP_EVENT_DISCONNECT
            case BSP_EVENT_WHITELIST_OFF:
                break; // BSP_EVENT_KEY_0
        ble_advertising_init_t init;
        init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance      = true;
        init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
        advertising_config_get(&init.config);
    static void buttons_leds_init()
        uint32_t err_code;
        bsp_event_t startup_event;
        err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    /**@brief Function for the Power manager.
    static void log_init(void)
        uint32_t err_code = NRF_LOG_INIT(NULL);
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            uint16_t data_len = p_evt->params.att_mtu_effective;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", data_len, data_len);
            NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                          p_gatt->att_mtu_desired_central,
                          p_gatt->att_mtu_desired_periph);
    /**@brief   Function for initializing the GATT module.
     * @details The GATT module handles ATT_MTU and Data Length update procedures automatically.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        NRF_LOG_DEBUG("advertising is started");
        uint32_t err_code = nrf_pwr_mgmt_init();
            nrf_pwr_mgmt_run();
    /**@brief Function for application main entry.
        log_init();
        // Initialize the async SVCI interface to bootloader before any interrupts are enabled.
        err_code = ble_dfu_buttonless_async_svci_init();
        timers_init();
        power_management_init();
        buttons_leds_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        advertising_init();
        services_init();
        conn_params_init();
        NRF_LOG_INFO("Buttonless DFU Application started.");
        // Start execution.
        application_timers_start();
        // Enter main loop.
        for (;;)
            idle_state_handle();
    This seems to work.
