debugging sd_ble_gatts_hvx
Hi
I am trying to get to the bottom of a problem I am having with sending a buffer of data on connection and indication enable. Here's what I do: I have a process running, which is capturing sensor data every 10 seconds, and keeping it in a circular buffer. When a master connects, I want to send the circular buffer to the master app. I am doing that by triggering on the event that the CCCD is written to enable indications (I am using indication because I want to make sure that the values end up in the app). When this CCCD write is happening, I send the first item in my circular buffer, and then use the BLE_GATTS_EVT_HVC event to see if I have gotten a confirmation, just as in the health thermometer example.
I am running into a number of problems
  • when I trigger on the CCCD write and immediately do a sd_ble_gatts_hvx, I get an error 8 (illegal state); if I start a timer and do the same after 10 ms, then it is ok
  • I sometimes also have a BLE_ERROR_GATTS_SYS_ATTR_MISSING error, how can I avoid that? when should I normally do a sd_ble_gatts_sys_attr_set(m_conn_handle, NULL, 0) (i do not use bonding)
I have the impression that timing issues or race conditions are causing my problems, can anyone give me hint on how to solve this?
