Hi
I play with watchdog.
After a watchdog reset the debugger does no longer stop on a breakpoint or generate a hardfault on a __BKPT()
How can I config the Chip to handle breakpoints correct after watchdog reset?
Hi
Which IDE/debugger do you use? usually the debugger is able to catch a reset, but not normally re-attach to the process properly.
Do you see a fault when the device resets? This could be a timing issue in your application (for instance, when init'ing an external device or similar)
Håkon
Hi Håkon
I use SES an nRF9160DK
Attached is my project.5707.buttonWdt.zip
The watchdog is refreshed until button1 is pressed.
After Watchdog timeout a reset is generated and then __BKPT() is called.
Then the debugger doesn't stop and a Hardfault is generated.
The Output from the consol is attached ZOC20210803.LOG
On line 47 is a RESETPIN
On line 100 is a DOG
On line 159 is SREQ
When I set a breakpoint on line 87 nothing happends after DOG Reset
When I remove __BKPT() no hardfault is generated.
A __BKPT() instruction will cause a fault when no debugger (or semi-hosting not enabled) is connected:
In this case, the wdt reset allows the device to run, and you need to re-attach the debugger.
Håkon
Hi Håkon
SES is still in debugging mode.
The target handle a reset from the debugger correct.
How can I re-attach the debugger in SES?
Can this be done automatically?
Canastra said:Hi Håkon
Yes, the debug session is still open, but it goes into the running state after a wdt reset has occurred. If you halt the cpu, you can see that it has faulted (set CONFIG_RESET_ON_FATAL_ERROR=n to enable blocking assertions/faults), but you're not able to connect in such a time that the bpkt instruction is executed as you intend.
Håkon
