I'm downloading a firmware image from AWS via cell onto the nRF9160. I want to perform a serial DFU over UART. The DFU target is the nRF52840. Are there any existing samples outlining this process?
Yes, I'm actually using a nRF52820 but shouldn't make a significant difference. Anyway, I assume it means that it boots the image successfully and reverts but not entirely certain. Currently, I cannot enable UART logging for MCUBoot because it interferes with the UART communication between the 9160 and 820 during the DFU process which is strange. I assume it has something to do with the UART queue having data still in it from the MCUBoot log, not sure on this though. Maybe if I flushed the queue I could see the log and communicate between the two chips successfuly, but I can't find anything in the docs about flushing the queue using NCS EDIT: I actually don't think that it's trying to boot the new image at all. I set CONFIG_UART_CONSOLE=n on the current image, then changed that to y, reloaded the project in SES and rebuilt, and put the new app_update.bin on AWS. So if MCUBoot was actually trying to boot the new image it would show the MCUBoot header right? But it does not on boot and I actually just get a 0 error from boot_write_img_confirm() which is very confusing.
Is there maybe an issue with pm_static.yml not lining up with the flash partitions I defined in our board file? The partitions.yml file generated in the build directory (which is what I made pm_static) does not really make sense to me
Also, not sure if this makes a difference, but I'm using an overlay config for MCUBoot. Would that affect functionality somehow?
esisk said:Yes, I'm actually using a nRF52820 but shouldn't make a significant difference.
This makes a difference on the max. size of the partitions. The mcuboot_primary size must match the mcuboot_secondary partition size.
esisk said:But it does not on boot and I actually just get a 0 error from boot_write_img_confirm() which is very confusing.
0 is success, and if you are able to run this function on the updated device; it means that the image was booted.
Could you please be explicit on which nRF-device is being updated, and is calling this function? What you are stating now indicates that you have both booted and not booted the new firmware.
Can you please share some logs / debug info related to your current scenario?
Håkon
Yes I understand this. I'm testing the ability to perform a DFU on the nRF52820 given our board constraints, so I'm attempting this with a simple hello world program. There should be more than enough flash space on the 820 to successfully do this.
I understand; I'm confused because the hello world print statement should be different if I do not receive an error code from this function because MCUBoot would have booted the new application with a different print statement.
I am downloading the file with the nRF9160. There is a UART connection between the 9160 and an nRF52820. The 9160 receives a 2KB fragment of the update, sends it via UART, the 820 receives the fragment and uses the dfu_target_mcuboot library accordingly. This process repeats until the last 2KB fragment has been downloaded and transmitted to the 820, and at this point, the 820 calls dfu_target_mcuboot_done(true) and reboots.
Here are print statements generated by the dfu_target library. The print statement "err is 0" corresponds to the return value generated by boot_write_img_confirmed(), "init err" is from dfu_target_mcuboot_init, "write err" is from dfu_target_mcuboot_write(), and the offset of the update is printed before every write.
*** Booting Zephyr OS build v2.4.99-ncs2 ***
00> err is 0
00> Hello there, this is main app :)
00> init err: 0
00> offset: 0
00> write err: 0
00> offset: 2048
00> write err: 0
00> offset: 4096
00> write err: 0
00> offset: 6144
00> write err: 0
00> offset: 8192
00> write err: 0
00> offset: 10240
00> write err: 0
00> offset: 12288
00> write err: 0
00> offset: 14336
00> write err: 0
00> offset: 16384
00> write err: 0
00> offset: 18432
00> write err: 0
00> offset: 20480
00> write err: 0
00> offset: 22528
00> write err: 0
00> offset: 24576
00> write err: 0
00> done err is 0
00> *** Booting Zephyr OS build v2.4.99-ncs2 ***
00> err is 0
Thanks for your help Håkon!
