I'm downloading a firmware image from AWS via cell onto the nRF9160. I want to perform a serial DFU over UART. The DFU target is the nRF52840. Are there any existing samples outlining this process?
Try flashing the build/zephyr/app_test_update.hex directly to the device you're updating. This will show if the configuration that mcuboot expects is followed in the new application image.
Håkon
I flashed it directly and the update worked as expected
What is the error message that you get? Do you have a debug trace or similar?
Is your new update image calling "boot_write_img_confirmed()" ?
Håkon
The strange thing is I get no error message. No I don't have a trace, but whenever I print the error messages from dfu_target_mcuboot library functions, I get 0s. Yes I'm calling boot_write_img_confirmed(). EDIT: Ok double checked and I am not getting any errors from dfu_target_mcuboot functions but I am getting -5 as an error from boot_write_img_confirmed() on reboot. EDIT 2: printed the value returned by boot_set_confirmed() and it is -4 which stands for BOOT_MAGIC_BAD
esisk said:I am not getting any errors from dfu_target_mcuboot functions but I am getting -5 as an error from boot_write_img_confirmed() on reboot
This is on the nRF52840 side, right? Does this mean that it boots the image successfully, but is not able to verify itself, meaning that it will revert back after a reset?
Could you please share the uart log?
Håkon
