Legacy DFU procedure fails when the firmware image is signed
I am currently running some tests on the Legacy DFU protocol and notice that even valid firmware images are unable to be transmitted. My setup is as follows:
  • Peripheral BLE device: nRF 52 DK advertising as example "DfuTarg"
    • The bootloader and softdevice being used are from SDK11's example directory. Specifically, the "dfu_dual_bank_ble_s132_pca10040" bootloader and the "s132" softdevice.
  • Central BLE Device: Android phone
    • Note that the reason why I use a smartphone is because legacy DFU is not supported on modern versions of nRF Connect or nrfutil
The firmware image is created using the following command:
nrfutil dfu genpkg --application .\hrs.hex --key-file .\private.pem FW.zip
Note that the "hrs.hex" file is generated by using Keil uVision5 to compile the example located here with no modifications:
C:(HOME_DIRECTORY)\nRF5_SDK_11.0.0_89a8197\examples\ble_peripheral\ble_app_hrs\pca10040\s132_with_dfu\arm5_no_packs\ble_app_hrs_s132_with_dfu_pca10040.uvprojx
However, when trying to upload the firmware image, the operation fails. Here is the log output:
nRF Connect, 2021-08-03
DfuTarg (CF:EC:59:14:F9:8E)
V	17:02:59.003	Connecting to CF:EC:59:14:F9:8E...
D	17:02:59.003	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
D	17:02:59.240	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
D	17:02:59.267	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
I	17:02:59.267	Connected to CF:EC:59:14:F9:8E
V	17:02:59.304	Discovering services...
D	17:02:59.304	gatt.discoverServices()
I	17:02:59.992	Connection parameters updated (interval: 30.0ms, latency: 0, timeout: 4000ms)
I	17:03:00.188	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
D	17:03:00.266	[Callback] Services discovered with status: 0
I	17:03:00.266	Services discovered
V	17:03:00.275	Generic Access (0x1800)
- Device Name [R W] (0x2A00)
- Appearance [R] (0x2A01)
- Peripheral Preferred Connection Parameters [R] (0x2A04)
Generic Attribute (0x1801)
- Service Changed [I] (0x2A05)
   Client Characteristic Configuration (0x2902)
Device Firmware Update Service (00001530-1212-efde-1523-785feabcd123)
- DFU Packet [WNR] (00001532-1212-efde-1523-785feabcd123)
- DFU Control Point [N W] (00001531-1212-efde-1523-785feabcd123)
- DFU Version [R] (00001534-1212-efde-1523-785feabcd123)
D	17:03:00.275	gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
I	17:03:00.318	Connection parameters updated (interval: 30.0ms, latency: 0, timeout: 4000ms)
I	17:03:00.903	Connection parameters updated (interval: 30.0ms, latency: 0, timeout: 4000ms)
V	17:03:03.783	[DFU] DFU service started
V	17:03:03.784	[DFU] Opening file...
I	17:03:03.784	[DFU] Firmware file opened successfully
V	17:03:03.784	[DFU] Connecting to DFU target...
D	17:03:03.784	[DFU] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferredPhy = LE_1M | LE_2M)
I	17:03:03.791	[DFU] Connected to CF:EC:59:14:F9:8E
V	17:03:03.791	[DFU] Discovering services...
D	17:03:03.791	[DFU] gatt.discoverServices()
I	17:03:03.794	[DFU] Services discovered
D	17:03:03.802	[DFU] wait(1000)
V	17:03:04.818	[DFU] Reading DFU version number...
D	17:03:04.819	[DFU] gatt.readCharacteristic(00001534-1212-efde-1523-785feabcd123)
I	17:03:04.878	[DFU] Read Response received from 00001534-1212-efde-1523-785feabcd123, value (0x): 08-00
A	17:03:04.878	[DFU] Version number read: 0.8
D	17:03:04.878	[DFU] wait(1000)
V	17:03:05.897	[DFU] Enabling notifications for 00001531-1212-efde-1523-785feabcd123
D	17:03:05.897	[DFU] gatt.setCharacteristicNotification(00001531-1212-efde-1523-785feabcd123, true)
D	17:03:05.897	[DFU] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
I	17:03:05.941	[DFU] Data written to descr.00001531-1212-efde-1523-785feabcd123, value (0x): 01-00
V	17:03:05.941	[DFU] Notifications enabled for 00001531-1212-efde-1523-785feabcd123
A	17:03:05.942	[DFU] Notifications enabled
D	17:03:05.943	[DFU] wait(1000)
V	17:03:06.959	[DFU] Writing to characteristic 00001531-1212-efde-1523-785feabcd123
D	17:03:06.959	[DFU] gatt.writeCharacteristic(00001531-1212-efde-1523-785feabcd123)
I	17:03:07.000	[DFU] Data written to 00001531-1212-efde-1523-785feabcd123, value (0x): 01-04
A	17:03:07.000	[DFU] DFU Start sent (Op Code = 1, Upload Mode = 4)
V	17:03:07.000	[DFU] Writing to characteristic 00001532-1212-efde-1523-785feabcd123
D	17:03:07.000	[DFU] gatt.writeCharacteristic(00001532-1212-efde-1523-785feabcd123)
I	17:03:07.004	[DFU] Data written to 00001532-1212-efde-1523-785feabcd123, value (0x): 00-00-00-00-00-00-00-00-F4-5B-00-00
A	17:03:07.004	[DFU] Firmware image size sent (0b, 0b, 23540b)
I	17:03:07.839	[DFU] Notification received from 00001531-1212-efde-1523-785feabcd123, value (0x): 10-01-01
A	17:03:07.840	[DFU] Response received (Op Code = 1 Status = 1)
A	17:03:07.840	[DFU] Writing Initialize DFU Parameters...
V	17:03:07.840	[DFU] Writing to characteristic 00001531-1212-efde-1523-785feabcd123
D	17:03:07.840	[DFU] gatt.writeCharacteristic(00001531-1212-efde-1523-785feabcd123)
I	17:03:07.897	[DFU] Data written to 00001531-1212-efde-1523-785feabcd123, value (0x): 02-00
V	17:03:07.903	[DFU] Writing to characteristic 00001532-1212-efde-1523-785feabcd123
D	17:03:07.905	[DFU] gatt.writeCharacteristic(00001532-1212-efde-1523-785feabcd123)
I	17:03:07.909	[DFU] Data written to 00001532-1212-efde-1523-785feabcd123, value (0x): FF-FF-FF-FF-FF-FF-FF-FF-01-00-FE-FF-02-00-00-00-F4-5B-00-00
V	17:03:07.911	[DFU] Writing to characteristic 00001532-1212-efde-1523-785feabcd123
D	17:03:07.911	[DFU] gatt.writeCharacteristic(00001532-1212-efde-1523-785feabcd123)
I	17:03:07.917	[DFU] Data written to 00001532-1212-efde-1523-785feabcd123, value (0x): CA-47-1C-0B-00-C7-CA-34-D6-D3-30-6C-4F-9E-E7-56-2F-09-7C-5E
V	17:03:07.918	[DFU] Writing to characteristic 00001532-1212-efde-1523-785feabcd123
D	17:03:07.919	[DFU] gatt.writeCharacteristic(00001532-1212-efde-1523-785feabcd123)
I	17:03:07.922	[DFU] Data written to 00001532-1212-efde-1523-785feabcd123, value (0x): 7A-C5-E5-D6-14-B5-66-BA-38-80-16-55-ED-C5-38-24-2F-F0-E0-80
V	17:03:07.923	[DFU] Writing to characteristic 00001532-1212-efde-1523-785feabcd123
D	17:03:07.923	[DFU] gatt.writeCharacteristic(00001532-1212-efde-1523-785feabcd123)
I	17:03:07.926	[DFU] Data written to 00001532-1212-efde-1523-785feabcd123, value (0x): 2B-67-BF-0A-EA-17-88-53-7C-F6-22-64-1D-AF-CF-05-CC-F1-60-19
V	17:03:07.926	[DFU] Writing to characteristic 00001532-1212-efde-1523-785feabcd123
D	17:03:07.927	[DFU] gatt.writeCharacteristic(00001532-1212-efde-1523-785feabcd123)
I	17:03:07.929	[DFU] Data written to 00001532-1212-efde-1523-785feabcd123, value (0x): 49-F3-CC-96-89-3C-AC-D6-ED-3D-7C-26-91-B5-02-A7-EB-B5-92-EE
V	17:03:07.929	[DFU] Writing to characteristic 00001532-1212-efde-1523-785feabcd123
D	17:03:07.930	[DFU] gatt.writeCharacteristic(00001532-1212-efde-1523-785feabcd123)
I	17:03:07.936	[DFU] Data written to 00001532-1212-efde-1523-785feabcd123, value (0x): BA-B8-DC-C4-7B-BB-8C-EA-B0-CF-26-BD-2E-92-86-9E
V	17:03:07.940	[DFU] Writing to characteristic 00001531-1212-efde-1523-785feabcd123
D	17:03:07.940	[DFU] gatt.writeCharacteristic(00001531-1212-efde-1523-785feabcd123)
D	17:03:11.993	[Callback] Connection state changed with status: 8 and new state: DISCONNECTED (0)
E	17:03:11.993	Error 8 (0x8): GATT CONN TIMEOUT
I	17:03:11.993	Disconnected
E	17:03:11.996	[DFU] Error (0x85): GATT ERROR
D	17:03:12.034	[DFU] gatt.refresh() (hidden)
D	17:03:12.034	[DFU] gatt.disconnect()
D	17:03:12.034	[DFU] gatt.close()
It seems that the update process stops halfway through due to a GATT Error. What exactly is causing this issue? I've tested this problem multiple times and have seen that simply not signing the Firmware results in a successful update. However, it is when the firmware is signed in which this error occurs.
Any help or insight would be deeply appreciated!
