SES no long knows the $(Target), the simulator or the device register maps.
I recently moved my custom board definition from the zephyr board dir to the nrf board dir, to unify my changes into on git repo for internal use.  I think that's when the Segger Embedded Studio stopped knowing the $Target and the JLINK debug interface.  Along with the nrf53 device register groups.
If I manually set the target and the debugger to jlink, it can debug find, but it loses this when I exec SES.  It also does not know about other register groups such as GPIOTE and all others.
Is there a fix for this?  Where does SES store that infomation?
  • Hi Jordan,
    I've tried to open your project a few times now, unfortunately I have not been able to do so. Are you using the toolchain manager? or some different installation?
  • This thread may be relevant: https://devzone.nordicsemi.com/f/nordic-q-a/80029/failed-to-write-memory-when-using-segger-embedded-studio-and-nrf-connect-sdk/331863. You may want to check if the chip variant in your board file matches the one used in the python script I refered to.
  • Can you open the project under?  And it appears that if you run cmake, SES loses all of the device and jlink info.
    nrf\projects\onedrop_pod\build_onedrop_cpuapp_pod1
    The files:
    CMakeCache.txt Output build.ninja mcuboot onedrop_pod.emSession regions.yml zephyr_modules.txt
    CMakeFiles app cmake_install.cmake modules partitions.yml rules.ninja zephyr_settings.txt
    Kconfig build.emProject hci_rpmsg onedrop_pod.emProject pm.config zephyr
  • I was able to build 'build_onedrop_cpuapp_pod1' after I ran a 'west update'. It appeared to be an issue with the Zephyr repo.
    Anyway. I think I found the issue now: the python script responsible for generating the Segger project assumes the board file will include the SoC devicetree file at the top of the file, but your onedrop_cpuapp_pod1.dts file does not do that. Instead it includes it via your onedrop_cpuapp_base.dts file.
    Here is the part from the script that attempts to parse the include string from the board file:
        file = open(boardDir + "/" + boardName + ".dts", "r")
        dtsfile = file.read()
        file.close()
        deviceName = ""
        segments = ""
        svdFile = ""
        n = dtsfile.find("#include <nordic/")
        if n != -1:
            m = dtsfile.find(".dtsi>")
            if m != -1:
                device = dtsfile[n + 17:m]
                if device == "nrf51822_qfaa":
                    deviceName = "nRF51822_xxAA"
                    segments = ("FLASH RX 0x00000000 0x00040000;"
                                "RAM RWX 0x20000000 0x00004000")
                    svdFile = "nrf51.svd"
    To fix this, please use the following includes in onedrop_cpuapp_pod1.dts:
    /dts-v1/;
    #include <nordic/nrf5340_cpuapp_qkaa.dtsi>
    #include "onedrop_cpuapp_base.dts"
    Then remove the SoC include from onedrop_cpuapp_base.dts:
     * Copyright (c) 2020 Nordic Semiconductor ASA
    #include "nrf5340_cpuapp_common.dts"
        compatible = "OneDrop";
