Writing to GPIO on nrf5340-DK
I'm working with the latest v1.6.1 nrf SDK, and was able to get the Blinky sample code to work.. But trying to translate that to toggling other GPIO isn't working.  I also tried the code here:  https://devzone.nordicsemi.com/f/nordic-q-a/67810/reading-and-writing-to-gpio-pins-from-a-sample-zephyr-project  but when that code is loaded, nothing happens.
main.c
 * Copyright (c) 2016 Intel Corporation
#include <zephyr.h>
#include <device.h>
#include <devicetree.h>
#include <drivers/gpio.h>
/* 1000 msec = 1 sec */
#define SLEEP_TIME_MS   1000
/* The devicetree node identifier for the "led0" alias. */
#define LED1_NODE DT_ALIAS(led1)
#if DT_NODE_HAS_STATUS(LED1_NODE, okay)
#define LED1	DT_GPIO_LABEL(LED1_NODE, gpios)
#define PIN	DT_GPIO_PIN(LED1_NODE, gpios)
#define FLAGS	DT_GPIO_FLAGS(LED1_NODE, gpios)
#else
/* A build error here means your board isn't set up to blink an LED. */
#error "Unsupported board: led0 devicetree alias is not defined"
#define LED0	""
#define PIN	0
#define FLAGS	0
void main(void)
	const struct device *dev;
        const struct device *dev0;
	bool led_is_on = true;
	int ret;
        dev0= device_get_binding("GPIO_0");
        gpio_pin_configure(dev0,27,GPIO_OUTPUT);
	dev = device_get_binding(LED1);
	if (dev == NULL) {
		return;
	ret = gpio_pin_configure(dev, PIN, GPIO_OUTPUT_ACTIVE | FLAGS);
	if (ret < 0) {
		return;
	while (1) {
                gpio_pin_toggle(dev0,27);
		gpio_pin_set(dev, PIN, (int)led_is_on);
		led_is_on = !led_is_on;
		k_msleep(SLEEP_TIME_MS);
In the above code, the LED blinks properly, but P0.27 remains pulled high by the pullup resistors on my board.  I've tried other GPIO as well with the same results.
