Serial pass-through on PCA10059 (nRF58240) dongle
I am sending data over air from an XBee in transparent mode to an nRF52840 dongle as ZC.
The data is going over the air from the source and destination addresses using a sniffer and
the network is properly joined to by the XBee router
How do I see the serial data coming out on the serial port ?
  • Hi again
    A suggestion from one of my colleagues was to run the following command:
    log enable info zigbee.report
    Can you give this a go and see if you can see the incoming messages?
    Best regards
    Torbjørn
  • I have enabled reporting as follows:
    bdb start
    bdb legacy enable
    log enable info app
    No don't see any frames arriving from XCTU which are verified as going over the air with my sniffer
    If I was sending data from an XBee on cluster address 11, SE=E8, DE=E8 in transparent (or API mode) is there a CLI command to read the buffered message back to CLI ?
    The back end code is written in Python and sends the data to Azure, I just want to check the messages from our device are arriving.
    I think it may use the zdo command ? Too much to do to read 5000 pages of documentation, I just want to know how to read messages that I see going over air to 16 bit address 0x0000 on the same network, that is the ZC receiving data from my XBee device.
  • Hi
    I will have to wait for my colleagues with more Zigbee experience to get back next week, and get some help with this.
    Sorry for the delay.
    Best regards
    Torbjørn
    I have taken over your case, but I see that you have multiple cases with similar issue. Are your other cases related to this, and do you still need help with this issue?
    I see you write that you are using the firmware that was shipped with the Dongle, but I also see you have other cases where you mention using the CLI Agent example, so I assume that is what you are using currently. Handling of incoming packets is handled internally by the Zigbee stack in our SDK. If you want to handle incoming packets differently, or to perform additional tasks when receiving a packet, then you will have to override the default handling and create a custom handler. This is what is done in the CLI Agent example. Please see our documentation for more information about how to do this yourself: Configuring default ZCL command handler override. You can also look at the Zigbee CLI library files to see examples of how it is done there. These can be found in <SDK_ROOT>/components/zigbee/cli.
    Marte
