app_pwm_disable doesn't work
Hi all ,
I have a buzzer that I will order using the library pwm and it works succefully .
 But Now I want to turn on the PWM  if the temperature value is greater than 40  and turn off pwm otherwise  unfortunately the app_pwm_disable doesn't work  that is to say the buzzer starts ringing as soon as the temperature value exceeds 40 and does not stop .
is there any solution to do that ?
there is my main code
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nrf.h"
#include "nrf_drv_saadc.h"
#include "nrf_drv_ppi.h"
#include "nrf_drv_timer.h"
#include "boards.h"
#include "app_error.h"
#include "nrf_delay.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "bsp.h"
#include "app_pwm.h"
 ret_code_t err_code;
APP_PWM_INSTANCE(PWM1,1);                   // Create the instance "PWM1" using TIMER1.
#define buzzer NRF_GPIO_PIN_MAP(1, 11)
static volatile bool ready_flag;            // A flag indicating PWM status.
void pwm_ready_callback(uint32_t pwm_id)    // PWM callback function
    ready_flag = true;
void saadc_callback_handler(nrf_drv_saadc_evt_t const * p_event)
 // Empty handler function
void saadc_init(void)
	// A variable to hold the error code
  nrf_saadc_channel_config_t channel_config = NRFX_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN2);
  err_code = nrf_drv_saadc_init(NULL, saadc_callback_handler);
// Initialize the Channel which will be connected to that specific pin.
  err_code = nrfx_saadc_channel_init(0, &channel_config);
// A function which will initialize the Log module for us
void log_init(void)
	// check if any error occurred during its initialization
	// Initialize the log backends module
	// call the log initialization function
  log_init();
// call the saadc initialization function created above
  saadc_init();
  nrf_saadc_value_t adc_val;
// Print a simple msg that everything started without any error
  NRF_LOG_INFO("Application Started!!!");
                 /* 1-channel PWM, 200Hz, output on DK LED pins. */
    app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_1CH(25000000L, buzzer);
    /* Switch the polarity of the second channel. */
    pwm1_cfg.pin_polarity[1] = APP_PWM_POLARITY_ACTIVE_HIGH;
    /* Initialize and enable PWM. */
// Inifinite loop
    while (1)
      nrfx_saadc_sample_convert(0, &adc_val);
	float voltage = adc_val * (3300 / 1024.0);
        float temperature = (voltage - 500) / 10;
           NRF_LOG_RAW_INFO(" temperature: " NRF_LOG_FLOAT_MARKER , NRF_LOG_FLOAT(temperature));
		 NRF_LOG_RAW_INFO(" \xB0"); // shows degree symbol
                  NRF_LOG_RAW_INFO("C");
                  NRF_LOG_RAW_INFO(" ");
                   nrf_delay_ms(1000);
                  if (temperature> 40)
                 NRF_LOG_RAW_INFO("hiiiiiiiiiiiiii ");
                  err_code = app_pwm_init(&PWM1,&pwm1_cfg,pwm_ready_callback);
                app_pwm_enable(&PWM1);
                  else  {
                  err_code = app_pwm_uninit(&PWM1);
                  app_pwm_disable(&PWM1);
         NRF_LOG_RAW_INFO("heeeeeeere ");
