Int the website:
FEATURES show the nordice nRF51822 has 3 data rates (2Mbps/1Mbps/250kbps).
But , I set
number of packets transmitted per connection event 20
Connection interval 7.5
I can't achieve 2Mbps throughput ?
Int the website:
But , I set
If you are trying to get this thru-put with BLE it is not possible. 2Mbps is only possible with proprietary protocol
How can I obtain/get the BLE with “proprietary protocol” ?
Does the BLE with 1Mbps/0.25Mbps data rates also need to use “proprietary protocol” ?
How can I obtain/get the BLE with “proprietary protocol” ? Does the BLE with 1Mbps/0.25Mbps data rates also need to use “proprietary protocol” ?
BLE is its own protocol. Proprietary or other protocol's like ANT are different
There is no BLE with 'proprietary protocol', you're either using BLE, or you're not using BLE. BLE is defined over an underlying 1Mbps link, however the actual throughput after you take into consideration
This thread does a good job of summarising what's actually even possible
with the best combination available it's about .5Mbps
