nRF52840 - Zephyr OS - Flash Protection
I'm looking to enable the flash protection for an nRF52 application running on Zephyr RTOS:
  • Basically looking to disable flash reads from the JTAG/SWD interface: Only erase or reprogram should be possible.
My understanding is that this can be achieved by configuring the APPPROTECT in the UICR register and restarting the device (NVMC need to be enabled).
Any insight into how to achieve this on Zephyr RTOS would be greatly appreciated.
  • To provide an update on the state of this ticket:
    I'm currently able to protect with the known nrfjprog command:
    nrfjprog --rbp ALL -f NRF52
    But I'm looking for a way to do this from the application code. I've set CONFIG_SOC_FLASH_NRF_UICR=y from the bootloader configuration as well as application and I'm currently able to read in run time using:
    NRF_UICR->APPROTECT
    But this reference doesn't seem to allow for writing or clearing. I've tried using the flash API in the following manner to read/write but no success in even being able to read:
    #define PER_UICR 0x10001000UL
    #define UICR_REG_APPROTECT 0x208UL
    void uicr_reg_approtect_read(void){
    	const struct device* flash_dev = device_get_binding(DT_CHOSEN_ZEPHYR_FLASH_CONTROLLER_LABEL);
        uint32_t reg_approtect = 0UL;
        if (flash_dev == NULL) {
            LOG_ERR("Nordic nRF52 flash driver was not found!\n");
            return;
        }  // Check status
        LOG_WRN("Found flash controller %s", log_strdup(DT_CHOSEN_ZEPHYR_FLASH_CONTROLLER_LABEL));
        err = flash_read(flash_dev, PER_UICR + UICR_REG_APPROTECT, &reg_approtect, sizeof(uint32_t));
        if (err != 0) {
            LOG_WRN("Flash read of REG_APPROTECT failed! %d\n", err);
        } else {
            LOG_WRN("UICR - REG_APPROTECT 0x%X", reg_approtect);
  • Any insight into how to achieve this on Zephyr RTOS would be greatly appreciated.
     There are no Kconfig or similar in Zephyr for this, but we are looking into adding this.
    Here are some code on how to enable it:
    void nrf_bootloader_debug_port_disable(void)
        if (NRF_UICR->APPROTECT != 0x0)
            nrf_nvmc_write_word((uint32_t)&NRF_UICR->APPROTECT, 0x0);
            NVIC_SystemReset();
    #if (!defined (NRF52810_XXAA) && !defined (NRF52811_XXAA) && !defined (NRF52832_XXAA) && !defined (NRF52832_XXAB))
        if (NRF_UICR->DEBUGCTRL != 0x0)
            nrf_nvmc_write_word((uint32_t)&NRF_UICR->DEBUGCTRL, 0x0);
            NVIC_SystemReset();
  • Thanks for the insight, much appreciated!
    I'll look into getting that to run on Zephyr using the HAL, looking forward for when this gets added as a Kconfig!
    Thanks for the help
     A PR have been created for this now.
    https://github.com/zephyrproject-rtos/zephyr/pull/37732
  • Thanks for all the help and the following up! Smiley
