My system has both PCD card reader (such as adafruit_pn532) and nrf52840 internal NFC. How to make them work together and use the same antenna?
1.when i connected the NFC pin (NFC IN1 and NFC IN2) to the reader antenna Rx path, the field can not trigger a NRFX_NFCT_EVT_FIELD_DETECTED even, because the Rx path field strength have been limited to under 2Vpp
2. but when i connected the NFC pin directed to the antenna coil and matching well, it can generate a NRFX_NFCT_EVT_FIELD_DETECTED even , and the nrf52840 NFC function working well, but my RFID system (such as adafruit_pn532) can not word, because when the reader(PN532) open antenna field , the field strength voltage turn up to 20V ,this will cause the Nrf52840 NFC pin voltage to high,and can not work any more.
3. i have try to use a different antenna of them, but when the two antenna at the same window, this make non sense。
How to deal with this problem?
thanks!
