I am using running "ble_app_uart_c" example in my Central nrf52 DK board and ruuning "ble_app_uart" example in my peripheral nrf52 dk board..
IF I am sending ASCII values ":16 03 00 00 00 02 E5 CR LF" from central dk , I can able to get in peripheral side like " :160300000002E5"
But if I send same values in hex i.e "16 03 00 00 00 02 C7 2C " from centrak dk , then in peripheral side I get " Ç,".
I changed the code in central side like this because I want If in uart side it get 8byte it should send it via bluetooth.
static uint16_t index = 0;
uint32_t ret_val;
switch (p_event->evt_type)
/**@snippet [Handling data from UART] */
case APP_UART_DATA_READY:
index++;
/* if ((data_array[index - 1] == '\n') ||
(data_array[index - 1] == '\r') ||
(index >= (m_ble_nus_max_data_len)))*/
if (index >= 8u)
do
ret_val = ble_nus_c_string_send(&m_ble_nus_c, data_array, index);
if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_RESOURCES) )
APP_ERROR_CHECK(ret_val);
} while (ret_val == NRF_ERROR_RESOURCES);
index = 0;
and in peripheral side I change it to
static uint8_t index = 0;
uint32_t err_code;
for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
do
err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
DataPos++;
if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
} while (err_code == NRF_ERROR_BUSY);
/*if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
while (app_uart_put('\n') == NRF_ERROR_BUSY);
