GPIO port definition in devicetree
Dear Nordic,
Could you please help me to understand the concept of using the DTS files and board initialization sequence?
We have just one GPIO port to control some external ICs on the board. It should be set to HIGH state when the peripheral is on use and go to LOW when device is in low-power state.
For now, port is controlled by mockup code:
const struct device *gpio_dev;
void pwrct_sf_init()
gpio_dev = device_get_binding("GPIO_1");
/* Set power control pin as output */
gpio_pin_configure(gpio_dev, 9, GPIO_OUTPUT_LOW | GPIO_ACTIVE_HIGH); //p1.09 == LDO_EN active high
#if 1
void pwrct_sf_on()
gpio_pin_set(gpio_dev, 9, 1);
void pwrct_sf_off()
gpio_pin_set(gpio_dev, 9, 0);
How we should define it in DTS (e.g. like leds section) to make it defined clearly (port & pin number, active state, label should be defined in DTS).
Is there a way to add calls to this port on / off to particular functions related to SPI init / deinit and QSPI init / deinit?
    There are several ways to do this, but typically you create some sort of board.c file where you do the board specific initialization.
    Take a look at these files to see how it can be done:
    Thingy:91 , https://github.com/nrfconnect/sdk-nrf/blob/master/boards/arm/thingy91_nrf9160/board_secure.c#L16
    Thingy:53, https://github.com/nrfconnect/sdk-zephyr/blob/v2.6.0-rc1-ncs1/boards/arm/thingy53_nrf5340/board.c#L85
    Thingy:52, https://github.com/nrfconnect/sdk-zephyr/blob/v2.6.0-rc1-ncs1/boards/arm/thingy52_nrf52832/board.c
  • Hi, Sigurd,
    Many thanks for the recommendation.
    I've added regulator element in DTS file:
    pwr_sf: sensor-flash-supply {
    /* Power regulator for sensors & flash mem */
    compatible = "regulator-fixed";
    label = "sensor-flash-supply";
    regulator-name = "sensor-flash-supply";
    enable-gpios = <&gpio1 9 GPIO_ACTIVE_HIGH>;
    /* startup-delay-us = <1000>; -- uncomment this to specify the startup time delay */
    off-on-delay-us = <1000>; /* 600 us for TPS706xx */
    /* regulator-boot-on; -- uncomment this to enable the regulator in bootloader mode */
    /* regulator-always-on; -- uncomment this to enable the regulator unconditionally */
    Still, the code (regulator_enable, _disable) doen't work completely (the commented lines has been replaced by direct gpio_pin_set to check if GPIO initialization was done properly). Is there any things to check why the regulator_xxx functions don't work?
    const struct device *pwr_sf_dev;
    const struct device *pwr_gpio;
    struct onoff_client onoff_cli = {};
    #define REGULATOR_NODE DT_NODELABEL(pwr_sf)
    #define BOOT_ON DT_PROP(REGULATOR_NODE, regulator_boot_on)
    #define ALWAYS_ON DT_PROP(REGULATOR_NODE, regulator_always_on)
    #define STARTUP_DELAY_US DT_PROP(REGULATOR_NODE, startup_delay_us)
    #define OFF_ON_DELAY_US DT_PROP(REGULATOR_NODE, off_on_delay_us)
    int pwrct_sf_init()
    //!!! move to boards.c
    pwr_sf_dev = device_get_binding(DT_LABEL(REGULATOR_NODE));
    if (pwr_sf_dev == NULL) {
    return -ENODEV;
    pwr_gpio = device_get_binding(DT_GPIO_LABEL(REGULATOR_NODE, enable_gpios));
    if (pwr_gpio == NULL) {
    return -ENODEV;
    int ret = gpio_pin_configure(pwr_gpio, DT_GPIO_PIN(REGULATOR_NODE, enable_gpios), GPIO_OUTPUT_INACTIVE | DT_GPIO_FLAGS(REGULATOR_NODE, enable_gpios));
    printk("Regulator: %s%s\n", IS_ENABLED(BOOT_ON) ? ", boot-on" : "", IS_ENABLED(ALWAYS_ON) ? ", always-on" : "");
    printk("startup-delay: %u us\n", STARTUP_DELAY_US);
    printk("off-on-delay: %u us\n", OFF_ON_DELAY_US);
    return ret;
    void pwrct_sf_on()
    gpio_pin_set(pwr_gpio, DT_GPIO_PIN(REGULATOR_NODE, enable_gpios), 1);
    //regulator_enable(pwr_sf_dev, &onoff_cli);
    void pwrct_sf_off()
    gpio_pin_set(pwr_gpio, DT_GPIO_PIN(REGULATOR_NODE, enable_gpios), 0);
    //regulator_disable(pwr_sf_dev);
     Did the function call return any errors?
  • Hi, Sigurd,
    yes,
    * regulator_enable() returns -EINVAL (-22)
    * regulator_disable() returns -134
    I think this means that you have not registered a callback with sys_notify_init_callback()
1 2
