BLE NUS data not sending > 20bytes
I have tested the ble_nus code in NCS v1.4.2
where i can't send 250 bytes
I want to send 250 bytes to ble nus data send for 100 ms once
How to enable data send of 250 bytes 100ms once
  • Hi
    One way to do this is to create a union, similar to this:
    #define NUM_SENSORS 10
    #define NUM_AXIS    3
    typedef union
    	int16_t mlx_reading[NUM_SENSORS][NUM_AXIS];
    	uint8_t raw_buffer[NUM_SENSORS * NUM_AXIS * sizeof(int16_t)];
    } my_compound_type_t;
    Then you can simply refer to the mlx_reading array when you assign the values from the sensor, and then refer to the raw_buffer when sending the data to the NUS service.
    Because it is a union the mlx_reading array and the raw_buffer array will use the same area in RAM.
    Best regards
    Torbjørn
