nrf9160 takes tens of minutes to finish searching and connect to LTE after hard fault
I've had intermittent issues with the nrf9160 modem using mfw 1.3.0 with an iBASIS SIM getting stuck in "searching" state when first powering on. The symptoms are similar to this thread:
https://devzone.nordicsemi.com/f/nordic-q-a/57105/nrf9160-modem-stuck-in-searching
but different enough that it doesn't help.
After many days of debugging, I think I see a pattern:
  1. Modems works fine for a while, set in GPS + LTE mode, connecting and communicating of CAT-M1 and obtaining a GPS fix. This is through many flash and reboot cycles as I develop the software.
  2. A hard fault occurs during execution due to a software bug. Typically a stack overflow or similar.
  3. On next boot the modem behaviour is the same, except it does not leave "searching" mode and therefore does not connect.
  4. Nothing seems to restore normal behaviour, including re-flashing; rebooting; restoring Asset Tracker or Asset Tracker v2 or the AT client firmware and running the LTE Link Monitor; removing and replacing the SIM; running every AT command I can think of including every setting for and combination of CFUN and XSYSTEMMODE; leaving unpowered for a while; reseting various things in nRF Connect for Cloud.
  5. The only fix I've found is to leave the unit "searching" for around 30 minutes. The unit finally connects as normal and all is well - until I reboot. Then the problem is as it was originally.
  6. The only persistent fix I've found is to leave the unit "searching" for its requisite 30 minutes or so, then issuing "AT+CFUN=0". After that I can re-flash whatever firmware I like and connections occurs within a few seconds after power on. At least until the next hard fault...
A relevant sample of the log from the LTE Link Monitor appears below:
AT+CFUN?
+CFUN: 1
OK
AT+CGSN=1
+CGSN: "352656106125639"
OK
AT+CGMI
Nordic Semiconductor ASA
OK
AT+CGMM
nRF9160-SICA
OK
AT+CGMR
mfw_nrf9160_1.3.0
OK
AT+CEMODE?
+CEMODE: 2
OK
AT%XCBAND=?
%XCBAND: (1,2,3,4,5,8,12,13,18,19,20,25,26,28,66)
OK
AT+CMEE?
+CMEE: 0
OK
AT+CMEE=1
OK
AT+CNEC?
+CNEC: 0
OK
AT+CNEC=24
OK
AT+CGEREP?
+CGEREP: 0,0
OK
AT+CGDCONT?
OK
AT+CGACT?
OK
AT+CGEREP=1
OK
AT+CIND=1,1,1
OK
AT+CEREG=5
OK
AT+CEREG?
+CEREG: 5,2,"20CA","0808F50D",7
OK
AT%CESQ=1
OK
AT+CESQ
+CESQ: 99,99,255,255,3,45
OK
AT%XSIM=1
OK
AT%XSIM?
%XSIM: 1
OK
AT+CPIN?
+CPIN: READY
OK
AT+CPINR="SIM PIN"
+CPINR: "SIM PIN",3
OK
AT+CIMI
204080813633144
OK
%CESQ: 45,2,3,0
AT+CESQ
+CESQ: 99,99,255,255,5,45
OK
AT+CESQ
+CESQ: 99,99,255,255,2,44
There doesn't seem to be any issues with the APN, network selection or band selection, although the AT+CGDCONT? and AT+COPS? commands take many minutes to return.
AT%XCBAND
%XCBAND: 28
Otherwise there doesn't appear to be any reported issues at all. Even if I turn on AT+CMEE=1, AT+CGEREP=1, AT+CNEC=24 and AT+CEINFO=1, there's never any error.
Any ideas to skip this awful inoperable period?
