Setting interrupt priority levels
Hi, the specification of nRF5 SDK for Mesh v5.0.0. says the interrupt priority has two levels, named priority_lowest and priority_thread.
I am not clear on some things.
Number1:  Does the interrupt operation wait for a period of time? If does, what's the waiting time? Can if setting the waiting time? Does it have a range?
Number2: What's the difference between the two levels?  Are they having the same functions?
    It's hard to answer this answer. It will wait for other high-priority tasks to finish the jobs.
    If you have a look here, you can find that if you call mesh_init() with NRF_MESH_IRQ_PRIORITY_LOWEST , then you would need to call mesh APIs from the interrupt handler at NRF_MESH_IRQ_PRIORITY_LOWEST level. You can't call Mesh API in the main loop.
    Otherwise you need to initialize mesh with NRF_MESH_IRQ_PRIORITY_THREAD then you should not call Mesh APIs in an interrupt handler.
    If you want to call mesh API in both contexts, you would need to either use a software interrupt and call the interrupt from the main loop when you use NRF_MESH_IRQ_PRIORITY_LOWEST  , or the opposite, use app_scheduler if you use NRF_MESH_IRQ_PRIORITY_THREAD .
    -Amanda H.
