BT_SETTINGS CCCD creates more flash storage
HI,
i have enabled CONFIG_BT_SETTINGS_CCC_STORE_ON_WRITE=y
so after power cycle the device automatically connects with iphone and the service also works fine
after this
I found that RAM flash memory
gets increase at every disconnect and connect
Example
I connect the device with nrf connect app desktop -> programmer
i read the device and found
flash NVM size  25 bytes from F8000
                          24 bytes from F8FF7.
after connected and paired with iphone 8 plus
flash NVM size  158 bytes from F8000
                          72 bytes from F8FF7.
again read the device
flash NVM size  195 bytes from F8000
                          104 bytes from F8FF7.
I need to work on DFU and also NVM flash storage to store 5KB data. My concern is because of this memory increase . where it get collapse or not
to memories the CCCD where only enable is memorize and disable is not to be memorize is it possible
because
when device is out of bound then it will disconnect at the time memory will increase and then in bound it auto connect and that also write .
i want to control this only write the enable function
2. How to delete the particular CCCD stored flash page
3. how to delete the pair bond stored flash page . peer bond data is controlled by softdevice
