BT_SETTINGS CCCD creates more flash storage
HI,
i have enabled CONFIG_BT_SETTINGS_CCC_STORE_ON_WRITE=y
so after power cycle the device automatically connects with iphone and the service also works fine
after this
I found that RAM flash memory
gets increase at every disconnect and connect
Example
I connect the device with nrf connect app desktop -> programmer
i read the device and found
flash NVM size  25 bytes from F8000
                          24 bytes from F8FF7.
after connected and paired with iphone 8 plus
flash NVM size  158 bytes from F8000
                          72 bytes from F8FF7.
again read the device
flash NVM size  195 bytes from F8000
                          104 bytes from F8FF7.
I need to work on DFU and also NVM flash storage to store 5KB data. My concern is because of this memory increase . where it get collapse or not
to memories the CCCD where only enable is memorize and disable is not to be memorize is it possible
because
when device is out of bound then it will disconnect at the time memory will increase and then in bound it auto connect and that also write .
i want to control this only write the enable function
2. How to delete the particular CCCD stored flash page
3. how to delete the pair bond stored flash page . peer bond data is controlled by softdevice
    I think the best way to solve this is to set CONFIG_BT_MAX_PAIRED to the max number of devices/Bluetooth bonds you want to support.
    If you set CONFIG_BT_KEYS_OVERWRITE_OLDEST=y the Bluetooth Host will overwrite oldest keys with new ones if key storage is full.
  • currently i have used prj.conf is
    #CONFIG_NCS_SAMPLES_DEFAULTS=y
    #BT config
    CONFIG_BT=y
    CONFIG_BT_DEBUG_LOG=y
    CONFIG_BT_MAX_CONN=2
    CONFIG_BT_MAX_PAIRED=1
    CONFIG_BT_SMP=y
    CONFIG_BT_L2CAP_TX_BUF_COUNT=5
    CONFIG_BT_PERIPHERAL=y
    #Devie Name config
    CONFIG_BT_DEVICE_NAME="Headset"
    CONFIG_BT_DEVICE_APPEARANCE=961
    #Device Info service config
    CONFIG_BT_DIS=y
    CONFIG_BT_DIS_PNP=y
    CONFIG_BT_DIS_MANUF="NordicSemiconductor"
    CONFIG_BT_DIS_PNP_VID_SRC=2
    CONFIG_BT_DIS_PNP_VID=0x1915
    CONFIG_BT_DIS_PNP_PID=0xEEEF
    CONFIG_BT_DIS_PNP_VER=0x0100
    #Battery Service Config
    CONFIG_BT_BAS=y
    #HID config
    CONFIG_BT_HIDS=y
    CONFIG_BT_HIDS_MAX_CLIENT_COUNT=1
    CONFIG_BT_HIDS_DEFAULT_PERM_RW_ENCRYPT=y
    CONFIG_BT_GATT_UUID16_POOL_SIZE=40
    CONFIG_BT_GATT_CHRC_POOL_SIZE=20
    CONFIG_BT_LL_SOFTDEVICE_DEFAULT=y
    CONFIG_BT_CONN_CTX=y
    # Enable the NUS service
    CONFIG_BT_NUS=y
    CONFIG_BT_NUS_UART_BUFFER_SIZE=300
    # Enable bonding
    CONFIG_BT_SETTINGS=y
    CONFIG_FLASH=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_FLASH_MAP=y
    CONFIG_NVS=y
    CONFIG_SETTINGS=y
    # Enable DK LED and Buttons library
    CONFIG_DK_LIBRARY=y
    # This example requires more workqueue stack
    # Enable the UART driver
    CONFIG_UART_ASYNC_API=y
    CONFIG_NRFX_UARTE1=y
    CONFIG_SERIAL=y
    CONFIG_GPIO=y
    # Make sure printk is not printing to the UART console
    CONFIG_CONSOLE=y
    CONFIG_RTT_CONSOLE=n
    CONFIG_UART_CONSOLE=y
    CONFIG_PRINTK=y
    CONFIG_HEAP_MEM_POOL_SIZE=2048
    # Config logger
    CONFIG_LOG=y
    CONFIG_LOG_BUFFER_SIZE=2048
    CONFIG_LOG_PRINTK=y
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_LOG_BACKEND_RTT=y
    CONFIG_LOG_BACKEND_UART=n
    CONFIG_ASSERT=y
    # Clock configuration
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH=y
    # I2C Enable
    CONFIG_I2C=y
    CONFIG_SENSOR=y
    #MLX90393 Enable
    CONFIG_MLX90393=y
    CONFIG_MLX90393_TRIGGER_GLOBAL_THREAD=y
    # NFC configuration
    CONFIG_NFC_OOB_PAIRING=n
    # Optimize for debug
    CONFIG_DEBUG_OPTIMIZATIONS=y
    # Added
    CONFIG_BT_GATT_CLIENT=y
    CONFIG_BT_USER_DATA_LEN_UPDATE=y
    CONFIG_BT_RX_BUF_LEN=260
    CONFIG_BT_ATT_TX_MAX=10
    CONFIG_BT_ATT_PREPARE_COUNT=2
    CONFIG_BT_CONN_TX_MAX=10
    CONFIG_BT_L2CAP_TX_BUF_COUNT=10
    CONFIG_BT_L2CAP_TX_MTU=252
    CONFIG_BT_L2CAP_RX_MTU=252
    CONFIG_BT_CTLR_TX_BUFFER_SIZE=251
    CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
    # Added for FOTA
    CONFIG_BOOTLOADER_MCUBOOT=y
    CONFIG_MCUMGR=y
    CONFIG_MCUMGR_CMD_OS_MGMT=y
    CONFIG_MCUMGR_CMD_IMG_MGMT=y
    CONFIG_MCUMGR_SMP_BT=y
    CONFIG_IMG_ERASE_PROGRESSIVELY=y
    CONFIG_MCUMGR_SMP_BT_AUTHEN=n
    1 . if i set max_pair to be 1 when i connect second device it will over write  if i enable keys_overwrite_oldest?
    2. what will happen for CCCD flash writes how to over write the CCCD enable disable in same flash address
    3. Is it possible to delete the pairing data from flash storage . and how?
    i have enabled DFU
    before dfu the flash starts at 0xF8000 and now it starts at 0xFE000 why?
  • Hi Sigurd,
    I have tried
    and set max paired as 1.
    program initaial shows 25 bytes storage
    Mobile 1 paired 132 bytes   and delete bond from mobile phone 1
    paired with mobile 2 and flash increase to 241 bytes .
    it doesn't overwrite the previous flash area . i want to use that 132 bytes for all pairing devices .
  • Looking at the documentation for NVS, https://docs.zephyrproject.org/latest/reference/storage/nvs/nvs.html it seem to be erased first when a sector is full.
    "Elements are appended to a sector until storage space in the sector is exhausted. Then a new sector in the flash area is prepared for use (erased)."
     Yes, or marked it as invalid and erase it later when it needs the space.
     You should not manually change this value from the application. The Bluetooth Host takes care of keeping this value correct.
     If you want to remove the bond/pair, use bt_unpair()
     Perhaps NVS started to use a new sector. The flash space reserved for storage can be found in the dts. E.g.
    					storage_partition: partition@f8000 {
    						label = "storage";
    						reg = < 0xf8000 0x8000 >;
  • Hi Sigurd,
    Yes, In board files .dts
    having storage partition @f8000
    0xf8000 -  0x8000
    without dfu the peer bond date starts at f8000
    and same config
    while using dfu
    the starting address is changed from f8000 to fe000
    how it is happening
