Hi.
I'm trying to run an application using a custom SPM module in a nRF5340 where I get an error while running it. I'm using nRF Connect SDK. The terminal gives me this output:
[00:01:43.704,071] <err> os: Exception occurred in Secure State[00:01:43.704,071] <err> os: ***** HARD FAULT *****[00:01:43.704,071] <err> os: Fault escalation (see below)[00:01:43.704,071] <err> os: ***** BUS FAULT *****[00:01:43.704,101] <err> os: Precise data bus error[00:01:43.704,101] <err> os: BFAR Address: 0x50008158[00:01:43.704,101] <err> os: r0/a1: 0x0000002b r1/a2: 0x00000000 r2/a3: 0x00000000[00:01:43.704,101] <err> os: r3/a4: 0xaaaaaaaa r12/ip: 0xaaaaaaaa r14/lr: 0x5f534c42[00:01:43.704,101] <err> os: xpsr: 0x31534c00[00:01:43.704,101] <err> os: Faulting instruction address (r15/pc): 0x5f474953[00:01:43.704,132] <err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0[00:01:43.704,132] <err> os: Current thread: 0x20008538 (shell_uart)
I've been trying to debug the program, but I found no solution. It just jumps to the exception in a library function call from blst (https://github.com/supranational/blst), which works fine in the non-secure side. While debugging it, I just clarified the error was "Usage fault", but I can't specify what is causing it.
Is there any way to approach to the problem?
Thanks.
