NFC pairing fails due to NRF_DRV_CLOCK_EVT_HFCLK_STARTED not being raised
I have trouble getting NFC-pairing to work in nRF52840 running SoftDevice 7.2 based on SDK 7.0.2.
The observed behaviour is that the NFC Field is detected but nothing more.
My RTT log looks like this:
<info> NFCT: Start
<debug> NFCT: Field detected
<debug> nfc_platform: Field detected
while the nfc pairing reference example works flawlessly, the debug output looks like that:
<info> NFCT: Initialized
<info> NFCT: Start
<info> app: NFC Connection Handover BLE peripheral device example started.
<debug> NFCT: Field lost
<debug> nfc_platform: Field lost
<debug> nfc_ble_pair: NFC_EVENT_FIELD_ON
<info> BLE_M: Fast advertising.
<debug> NFCT: Selected
<debug> NFCT: Rx fend
After some digging (and reading nrf52840 datasheet), I figured that the reason might be
missing nfc module getting set in active mode.
In nfc_platform.c that happens by calling nrfx_nfct_state_force(NRFX_NFCT_STATE_ACTIVATED);
commenting out that line and running the nfc-example again shows the same behaviour
(and debug-output) as with my app.
Debugging my app again reveals that the clock_event_handler in nfc_platform.c that would ACTIVATE NFC is never
called and neither is the nrfx_power_clock_irq_handler called.
Comparing SDK configurations between my Application and the nfc pairing example shows
no differences in CLOCK configuration or NFC-configuration. Also, both have SoftDevice active and both NRFX_CLOCK_ENABLED
as well as NRF_CLOCK_ENABLED set as well..
I would expect the SoftDevice to forward the IRQ to the application but it doesn't.
It looks to me as if joel-sc is facing the same problem here:
https://devzone.nordicsemi.com/f/nordic-q-a/75069/nfc-doesn-t-work-when-the-softdevice-is-enabled/309655#309655
So, can anyone give me a hint to why the clock IRQ is not raised (or rather forwarded) by the SoftDevice?
Thank you very much.
  • I finally figured it out:
    requesting hf clock  (nrf_drv_clock_hfclk_request) before the Softdevice is running while it is enabled (SOFTDEVICE_PRESENT) will
    call nrfx_clock_hfclk_start() and somehow enabling the interrupt or triggering the event confuses the softDevice..
    I admit not having investigated this issue further, but maybe someone at nordic may want to confirm and explain with mastery insight.
    thank you!
  • Hi
    Due to the summer vacation period we are currently understaffed, so delayed replies must be expected. I am sorry about any inconvenience this might cause.
    Glad you were able to figure it out on your own! The HF clock peripheral is one of the peripherals reserved for the SoftDevice, so if you try requesting the HF clock before the SoftDevice is started, it will fail to start properly, as the SoftDevice requires full control of the HF clock , and will be able to handle it from there.
    Simon
